Victron GX product range
Introduction
The GX-device lies at the heart of the system - providing monitoring, and operating as the communication-centre of your installation. All the other system-components - such as inverter/chargers, solar chargers, and batteries - are connected to it. The Venus-device ensures that they all work in harmony. Monitoring can be carried out locally …or remotely - via our free-to-use Victron Remote Management portal (VRM). The GX-device also provides Remote firmware updates and even allows the settings to be Changed Remotely.
- The CANvu GX is best for harsh environments - when its IP67 rating is a must.
- Octo GX - The Octo GX is particularly suited to medium size installations which have many MPPT Solar Chargers, as it has 10 VE.Direct ports
- Maxi GX - suited for systems having many MPPT Solar Chargers, as it has 25 VE.Direct ports.
Also, there is a GX device built into our MultiPlus-II GX and EasySolar-II GX Inverter/chargers. There, its referred to as the GX Card.
Available accessories
- GX GSM - A cellular modem. It connects to Venus-device via USB, and takes a simcard
- VE.Can resistive tank sender adapter Allows a standard resistive tank-level sender to be connected to the Venus-device.
Comparison table
User interface | CCGX | Venus GX | Octo GX | CANvu GX | Maxi GX | MultiPlus-II GX and EasySolar-II GX |
Appearance | ||||||
Display | LCD Display & 7 buttons | no display | no display | 4.3“ touch-screen | 2×16 character display | |
Remote Console | yes | |||||
Buzzer | yes | yes | no | yes | no | |
Documentation | CCGX | Venus GX | Octo GX | CANvu GX | Maxi GX | MultiPlus-II GX and EasySolar-II GX |
Manual | CCGX manual | VGX manual | OGX manual | CANvu manual | tbd | MultiPlus-II GX |
Product detail page | CCGX product | VGX product | OGX product | CANvu product | tbd | |
Victron comm. ports | CCGX | Venus GX | Octo GX | CANvu GX(12) | Maxi GX | MultiPlus-II GX and EasySolar-II GX |
VE.Direct ports (always isolated) | 2 (1) | 10 (1) | 3 (1) | 25 | 1 | |
VE.Can | 2 paralleled RJ45 sockets – isolated | |||||
VE.Bus | 2 paralleled RJ45 sockets – isolated | 1 isolated RJ45 socket | 2 paralleled RJ45 sockets – isolated | |||
Non Victron-products | CCGX | Venus GX | Octo GX | CANvu GX | Maxi GX | MultiPlus-II GX and EasySolar-II GX |
Canbus-BMS batteries | Many battery brands. See here for details | |||||
Fronius PV Inverters | See here for details | |||||
SMA PV Inverters | See here for details | |||||
ABB PV Inverters | See here for details | |||||
SolarEdge PV Inverters | See here for details | |||||
Communication | CCGX | Venus GX | Octo GX | CANvu GX | Maxi GX | MultiPlus-II GX and EasySolar-II GX |
USB | 2 USB Host ports – not isolated | 1 USB Host port - not isolated | ||||
Ethernet | 10/100 RJ45 socket - isolated except shield | 1 port. isolation?(12) | 10/100 RJ45 socket | |||
WiFi | optional (2) | built-in, but see (3) | built-in, external antenna (11) | optional (2) | no | built-in |
Bluetooth Smart | no | |||||
Micro SDcard slot | SDHC cards up to max. of 32GB. (5) | no | yes | no | ||
Second CAN-bus port | no | yes - non-isolated | yes - non-isolated | yes - non-isolated | no | no |
Built-in RS485 | no | no | yes - non-isolated | no | no | |
IO | CCGX | Venus GX | Octo GX | CANvu GX(12) | Maxi GX | MultiPlus-II GX and EasySolar-II GX |
Programmable relay (7) | 1x NO | 1x NO / NC (8) | 1x NO / NC | 2x NO / NC (8) | n/a | |
Resistive tank level inputs | no | 3 (9) | no | |||
Temperature sense inputs | no | 2 (10) | no | |||
Digital Inputs | no | 5 | 3 | 1 | 4 | no |
Other | CCGX | Venus GX | Octo GX | CANvu GX | Maxi GX | MultiPlus-II GX and EasySolar-II GX |
Supply voltage | 8 - 70 VDC | 8 - 32 VDC | 32 - 70 VDC | powered internally, no external supply | ||
Mounting | Panel Integration | Wall mounting | DIN Rail (35mm) | Panel | Wall mount IP65 | Built-in |
Outer dimensions ( h x w x d ) | 130 x 120 x 28 mm | 45 x 143 x 96 mm | 61 x 108 x 90 mm | ? | 600 x 380 x 210 mm | |
Operating temperature | -20 to +50°C | -20 to +70°C | -20 to +50°C | |||
Battery backuped clock | yes | no | yes | yes | ||
Standards | CCGX | Venus GX | Octo GX | CANvu GX | Maxi GX | MultiPlus-II GX and EasySolar-II GX |
Safety | EN 60950 | ? | ? | ? | ||
EMC | EN 61000-6-3, EN 55014-1, EN 61000-6-2, EN 61000-6-1, EN 55014-2 | |||||
Automotive | E4-10R-053535 | In progress | ? | ? | no |
Notes
- The maximum number of VE.Direct devices which can be attached to a CCGX is 5 (2 direct, and 3 via USB); on a Venus GX the number is 6 (2 direct and 4 via USB); on an Octo GX it is 10 (all attached directly). VE.Direct ports on a Venus-device are isolated.
- The hardware of the Venus GX and Octo GX includes a built-in Bluetooth Smart chipset which hasn't proved satisfactory. Bluetooth Smart for Venus-devices is coming soon but will not use built-in chipsets.
- The Venus GX has two temperature terminals which can be used to measure & monitor all kinds of temperature-inputs. Temperature senders are not included. The required sensor is ASS000001000 - Temperature Sensor QUA/PMP/Venus GX. (Note that this is not the same as the BMV temperature accessory.)
- Requires the CANvu GX IO Extender and wiring kit
