NMEA 2000 & MFD integration
The NMEA 2000 protocol is a plug-and-play communications standard used for connecting marine sensors and display units within ships and boats.
Many Victron Energy products can be integrated into an NMEA 2000 network. On this page, you will find an overview, as well as links to all the detailed information.
Victron Energy is a member of the NMEA 2000 organisation, and we have several of our products certified by NMEA 2000.
1. How to connect to a NMEA 2000 network
1.1 Multis, MultiPlusses and Quattros
Use the VE.Bus to NMEA 2000 interface to connect these devices to an NMEA 2000 network.
Monitoring and controlling these products from both to a NMEA 2000 network and a Color Control GX is possible. In that case, do not connect the Color Control GX to the VE.Bus network. Instead, connect it also to the NMEA2000 network, use our VE.Can to NMEA2000 cable. The CCGX will then read the MultiPlus or Quattro information from the via the NMEA 2000 network.
1.2 BMV Battery Monitors
Use the VE.Direct to NMEA 2000 interface to connect a BMV to a NMEA 2000 network.
Combining this with a CCGX on the same network is possible. Connect the CCGX to the NMEA2000 network as well, use our VE.Can to NMEA2000 cable for that. The CCGX will then read the BMV information from the via the NMEA 2000 network.
1.3 VE.Can products (Skylla-i, Skylla-IP44, Lynx Shunt, Lynx Ion+Shunt and more)
Since the Victron VE.Can communications protocol is based on NMEA 2000, the following products can all be connected directly to a NMEA 2000 network. The only thing necessary is a plug converter: the VE.Can to NMEA 2000 cable.
- Skylla-i 24V Battery Chargers
- Skylla IP44 Battery Chargers
- Lynx Shunt Battery Monitors
- Lynx Ion + Shunt all models
- BlueSolar MPPT Solar Chargers with VE.Can communications port
2. MFD integration
Using the NMEA 2000 protocol, Victron equipment can be integrated in many multi function displays. Such as the ones from Maretron, Raymarine, Garmin and many other brands
Note: working on a very large yacht featuring custom Scada and PLC networks? Consider integrating the Victron system with ModbusTCP instead of NMEA 2000.
2.1 Raymarine & EmpirBus
Any integration onto Raymarine MFDs is always done with an Empirbus NXT MCU . In the EmpirBus Studio software you will find dedicated Victron building blocks than can be drawn onto the diagram.
Next, use the EmpirBus Graphical tool to design the pages for on the Raymarine MFDs.
2.2 Maretron
All data sent out by Victron devices can be picked up by the Maretron MFDs & software. See the Maretron N2KView® vessel monitoring and control software.
3. PGN overview
Refer to our Datacommunication whitepaper, page 8 and beyond, for a list of Victron products and their supported PGNs.
4. Color Control GX & NMEA 2000
- The VE.Can port on the CCGX only reads information from the NMEA 2000 network. It does not (yet!) send any data out on the NMEA 2000 network.
5. FAQ
What about instances? Device instances, data instances?
See Changing NMEA2000 instances for details on that.
Can MPPTs with a VE.Direct port also be connected?
No, they cannot be connected. Even though the VE.Direct to NMEA 2000 interface can be physically connected to these solar chargers, it will not work.
Note that there are many more generic frequently asked questions answered in the Data communication white paper.
