ve.can:nmea-2000:start
ve.can:nmea-2000:start [2021-03-15 20:07] – [2.3 Tank monitoring] mvader | ve.can:nmea-2000:start [2022-03-16 12:07] – [3.4 DC Voltage compatibility] mvader | ||
Line 4: | Line 4: | ||
==== 1.1 Summary ==== | ==== 1.1 Summary ==== | ||
- | This document explains how to integrate a Victron system onto a Marine | + | This document explains how to integrate a Victron system onto a marine |
- | There are multiple options, and how to best integrate depends on the customer requirements, | + | There are multiple options, and how to best integrate depends on the customer requirements, |
Make sure to closely read this full document to find the best method for your type of system. | Make sure to closely read this full document to find the best method for your type of system. | ||
==== 1.2 What is NMEA 2000? ==== | ==== 1.2 What is NMEA 2000? ==== | ||
- | NMEA2000 | + | NMEA 2000 is a communications standard used for connecting marine sensors and display units within ships and boats. |
Line 52: | Line 52: | ||
==== 2.2 Products with a VE.Can port ==== | ==== 2.2 Products with a VE.Can port ==== | ||
- | Some of our products feature a VE.Can port; which can be directly connected to the NMEA 2000 network. No electronic converter is necessary. The conversion cable required is the [[https:// | + | All Victron |
- | These products include our Skylla-i | + | * Skylla-i |
+ | * Skylla IP65 Battery Chargers | ||
+ | * Lynx Shunt VE.Can | ||
+ | * Lynx Smart BMS | ||
+ | * SmartSolar MPPT Solar Chargers with VE.Can communications port | ||
- | ==== 2.3 Tank monitoring ==== | + | {{ :ve.can: |
- | The GX devices can measure tank levels, and make the resulting data available on the NMEA2000 network. | + | ==== 2.3 Tank monitoring integration ==== |
- | Also, they can read tank leven data from the network, when there are other tank senders connected. It will be shows it on the Victron screens as well as transmitted to the VRM Portal for remote monitoring. | + | The GX devices can measure tank levels, and make the resulting data available on the NMEA2000 network. |
Below sections explain the details of each integration type. | Below sections explain the details of each integration type. | ||
Line 82: | Line 86: | ||
Compatible tank senders are listed in the [[https:// | Compatible tank senders are listed in the [[https:// | ||
- | TODO ADD SCREENSHOTS | + | {{ : |
- | ==== 2.4 Using our converter interfaces (DEPRECATED!) ==== | + | //Above picture: GX Touch 50, showing multiple tank levels. Coming from either the NMEA2000 network, directly connected resistive tank senders or via the GX Tank 140 accessory.// |
Line 91: | Line 107: | ||
Note that the use of both those interfaces is deprecated. Use a GX device instead. | Note that the use of both those interfaces is deprecated. Use a GX device instead. | ||
+ | ===== 3. NMEA2000 Details ===== | ||
+ | Refer to our [[https:// | ||
+ | ==== 3.2 NMEA 2000 instancing ==== | ||
- | ===== 3. Varia ===== | + | NMEA 2000 Instances are used to identify multiple similar products connected on the same network. |
+ | There are several types of instances, the most important ones being the **Device instance** as well as the **Data instances**. | ||
- | ==== 3.1 VE.Can products (Skylla-i, Skylla-IP44, Lynx Shunt, Lynx Ion+Shunt and more) ==== | + | More information about instances is in [[https:// |
- | Since the Victron VE.Can communication protocol is based on N2K, the following products can all be connected directly to a N2K network. The only thing necessary is a plug converter: the [[https:// | + | === What settings need to be made? For example instances? === |
- | * Skylla-i 24V Battery Chargers | + | That is a commonly asked question. The answer depends on the used brand of MFD: |
- | * Skylla IP44 Battery Chargers | + | |
- | * Lynx Shunt Battery Monitors | + | |
- | * Lynx Ion + Shunt all models | + | |
- | * SmartSolar MPPT Solar Chargers with VE.Can communications port | + | |
- | {{ :ve.can: | + | |
+ | For **Garmin, Furuno, Maretron and Navico (B&G, Lowrance, Simrad) systems**: none. No instances, also not data instances such as the DC Detailed instance, need to be changed. It all works out of the box, other than configuring what field to show where on the MFD. | ||
+ | For **Raymarine**, | ||
- | ==== 3.2 Raymarine & EmpirBus | + | ==== 3.3 Terminators and network layout |
- | Besides | + | A N2K CAN-bus network needs to be laid out as in a backbone configuration, |
- | In the [[http://www.empirbus.com/clickOnce/EmpirBusStudio-Demo/|EmpirBus Studio software]] you will find dedicated Victron building blocks than can be drawn onto the diagram. | + | * Use the NMEA 2000 cable as the backbone. |
+ | * Run a separate drop cable separately to each Victron device | ||
+ | * Only terminate | ||
- | Next, use the [[http:// | + | Or: |
- | The EmpirBus system requires | + | * Have the N2K network on one side, with one terminator. On the other end, change |
- | ==== 3.3 Maretron ==== | + | The Victron VE.Can network is accepts 9 to 70VDC. |
- | All data sent out by Victron devices can be picked up by the Maretron MFDs & software. See the [[http:// | + | The NMEA-2000 network used to be 9 to 16VDC, which is, or will be, expanded to also include 24 V. Which means that some NMEA-2000 devices are 9 to 16 VDC, some are 9 to 30VDC, |
- | ===== 4. NMEA2000 | + | Also, the Victron VE.Can network will (in most cases) be powered with battery voltage. So for a 48V system, the voltage on the VE.Can network **exceeds** the NMEA2000 |
- | Refer to our [[https:// | + | Therefore, it is important |
- | ===== 5. FAQ ===== | + | The Victron cable used to connect both networks together, the [[https:// |
- | Note that there are many more generic frequently asked questions answered in the [[https:// | + | ==== 3.5 Further reading on Victron |
- | ==== Q1: What about instances? Device instances, data instances? ==== | + | * [[https:// |
+ | * [[https:// | ||
- | See [[ve.can: | + | ===== 4. Varia ===== |
- | ==== Q2: What about terminators and network layout? | + | ==== 4.1 Raymarine & EmpirBus |
- | A N2K CAN bus network needs to be laid out as in a backbone configuration, | + | Besides |
- | * Use the NMEA 2000 cable as the backbone. | + | In the [[https:// |
- | * Run a separate drop cable separately to each Victron device. The drop cable will be one of these three products: | + | |
- | * [[https:// | + | Next, use the [[http://www.empirbus.com/#empirbus-graphic|EmpirBus Graphical tool]] to design the pages for on the Raymarine MFDs. |
- | | + | The EmpirBus system requires the data instance of battery status and dc detailed status to be unique when using multiple sources. ([[ve.can: |
- | * Only terminate the NMEA 2000 backbone, do not terminate on the VE.Can side. | + | |
+ | All data sent out by Victron devices on the N2K network can be picked up by the Maretron MFDs & software. See the [[http://www.maretron.com/products/N2KView.php|Maretron N2KView® vessel monitoring and control software]]. | ||
+ | ===== 5. FAQ ===== | ||
+ | === Q1: Can/must both Ethernet and and N2K connection be made between Victron GX and MFD? === | ||
+ | Both can be made at the same time. | ||
- | ==== Q3: What PGNs does a GX Device transmit on N2K? ==== | + | Ethernet is needed to get the MFD App, as explained above. |
- | See the [[https:// | + | And an N2K connection is needed to get data to show in other fields on the MFD. |
- | ==== Q4: Can integration onto Raymarine displays also be done without Empirbus NXT? ==== | + | See annotated screenshot above for which is what. |
- | Yes, see [[https:// |
