ve.can:nmea-2000:start
ve.can:nmea-2000:start [2021-03-15 20:07] – [2.3 Tank monitoring] mvader | ve.can:nmea-2000:start [2021-09-09 16:58] – [2.4 NMEA 2000 GPS integration] mvader | ||
Line 4: | Line 4: | ||
==== 1.1 Summary ==== | ==== 1.1 Summary ==== | ||
- | This document explains how to integrate a Victron system onto a Marine | + | This document explains how to integrate a Victron system onto a marine |
- | There are multiple options, and how to best integrate depends on the customer requirements, | + | There are multiple options, and how to best integrate depends on the customer requirements, |
Make sure to closely read this full document to find the best method for your type of system. | Make sure to closely read this full document to find the best method for your type of system. | ||
==== 1.2 What is NMEA 2000? ==== | ==== 1.2 What is NMEA 2000? ==== | ||
- | NMEA2000 | + | NMEA 2000 is a communications standard used for connecting marine sensors and display units within ships and boats. |
Line 52: | Line 52: | ||
==== 2.2 Products with a VE.Can port ==== | ==== 2.2 Products with a VE.Can port ==== | ||
- | Some of our products feature a VE.Can port; which can be directly connected to the NMEA 2000 network. No electronic converter is necessary. The conversion cable required is the [[https:// | + | All Victron |
- | These products include our Skylla-i | + | * Skylla-i |
+ | * Skylla IP65 Battery Chargers | ||
+ | * Lynx Shunt VE.Can | ||
+ | * Lynx Smart BMS | ||
+ | * SmartSolar MPPT Solar Chargers with VE.Can communications port | ||
- | ==== 2.3 Tank monitoring ==== | + | {{ :ve.can: |
- | The GX devices can measure tank levels, and make the resulting data available on the NMEA2000 network. | + | ==== 2.3 Tank monitoring integration ==== |
- | Also, they can read tank leven data from the network, when there are other tank senders connected. It will be shows it on the Victron screens as well as transmitted to the VRM Portal for remote monitoring. | + | The GX devices can measure tank levels, and make the resulting data available on the NMEA2000 network. |
Below sections explain the details of each integration type. | Below sections explain the details of each integration type. | ||
Line 82: | Line 86: | ||
Compatible tank senders are listed in the [[https:// | Compatible tank senders are listed in the [[https:// | ||
- | TODO ADD SCREENSHOTS | + | {{ : |
- | ==== 2.4 Using our converter interfaces (DEPRECATED!) ==== | + | //Above picture: GX Touch 50, showing multiple tank levels. Coming from either the NMEA2000 network, directly connected resistive tank senders or via the GX Tank 140 accessory.// |
Line 91: | Line 107: | ||
Note that the use of both those interfaces is deprecated. Use a GX device instead. | Note that the use of both those interfaces is deprecated. Use a GX device instead. | ||
+ | ===== 3. NMEA2000 Details ===== | ||
+ | Refer to our [[https:// | ||
+ | ==== 3.2 NMEA 2000 instancing ==== | ||
- | ===== 3. Varia ===== | + | NMEA 2000 Instances are used to identify multiple similar products connected on the same network. |
+ | More information as well as how to configure them is explained in [[ve.can: | ||
- | ==== 3.1 VE.Can products (Skylla-i, Skylla-IP44, | + | ==== 3.3 Terminators |
- | Since the Victron VE.Can communication protocol is based on N2K, the following products can all be connected directly | + | A N2K CAN-bus network needs to be laid out as in a backbone configuration, using drop cables |
- | * Skylla-i 24V Battery Chargers | + | * Use the NMEA 2000 cable as the backbone. |
- | * Skylla IP44 Battery Chargers | + | * Run a separate drop cable separately to each Victron device [[https://nocache.victronenergy.com/ |
- | * Lynx Shunt Battery Monitors | + | * Only terminate the NMEA 2000 backbone, do not terminate on the VE.Can side. |
- | * Lynx Ion + Shunt all models | + | |
- | * SmartSolar MPPT Solar Chargers with VE.Can communications port | + | |
+ | ==== 3.4 Further reading on Victron and NMEA 2000 ==== | ||
+ | * [[https:// | ||
- | ==== 3.2 Raymarine & EmpirBus ==== | + | ===== 4. Varia ===== |
Besides using NMEA 2000 and/or the Lighthouse App, integration onto Raymarine MFDs can also be done with an [[http:// | Besides using NMEA 2000 and/or the Lighthouse App, integration onto Raymarine MFDs can also be done with an [[http:// | ||
Line 121: | Line 145: | ||
- | ==== 3.3 Maretron ==== | + | All data sent out by Victron devices |
- | All data sent out by Victron devices can be picked up by the Maretron MFDs & software. See the [[http:// | + | |
- | ===== 4. NMEA2000 PGN overview ===== | + | |
- | Refer to our [[https:// | + | |
===== 5. FAQ ===== | ===== 5. FAQ ===== | ||
- | Note that there are many more generic frequently asked questions answered in the [[https:// | + | === Q1: Can/must both Ethernet and and N2K connection be made between |
- | ==== Q1: What about instances? Device instances, data instances? ==== | + | Both can be made at the same time. |
- | See [[ve.can: | + | |
- | ==== Q2: What about terminators and network layout? ==== | + | |
- | A N2K CAN bus network needs to be laid out as in a backbone configuration, | + | |
- | * Use the NMEA 2000 cable as the backbone. | + | |
- | * Run a separate drop cable separately to each Victron device. The drop cable will be one of these three products: | + | |
- | * [[https:// | + | |
- | * Only terminate the NMEA 2000 backbone, do not terminate on the VE.Can side. | + | |
- | ==== Q3: What PGNs does a GX Device transmit on N2K? ==== | + | Ethernet is needed to get the MFD App, as explained above. |
- | See the [[https:// | + | And an N2K connection is needed to get data to show in other fields on the MFD. |
- | ==== Q4: Can integration onto Raymarine displays also be done without Empirbus NXT? ==== | + | See annotated screenshot above for which is what. |
- | Yes, see [[https:// |
