ccgx:modbustcp_faq
ccgx:modbustcp_faq [2019-12-11 10:02] – [Does Modbus TCP support Hub-4?] iburger | ccgx:modbustcp_faq [2020-01-06 14:53] – [6. Error codes and trouble shooting] iburger | ||
- | ====== ModbusTCP | + | ====== |
- | ModbusTCP is a feature on our [[venus-os: | + | ModbusTCP is a feature on our [[venus-os: |
- | Through the ModbusTCP interface you can read and write date to the chargers, battery monitors, inverter/ | + | ModbusTCP is an industry standard protocol, that can be used to interface PLCs or other third party equipment with Victron products. |
- | Besides reading this FAQ, make sure to also read the ModbusTCP section in our [[https:// | + | Besides reading this GX ModbusTCP Manual, make sure to also read the ModbusTCP section in our [[https:// |
- | ==== Supported | + | By default, |
- | The supported function codes are: | + | ==== 2. Addressing, Unit-ID and Registers ==== |
- | * ReadHoldingRegisters | + | |
- | * ReadInputRegisters | + | |
- | * WriteSingleRegister | + | |
- | * WriteMultipleRegisters | + | |
- | Note that there is no difference between function code 3 and 4. | + | === 2.1 Definitions === |
+ | The ModbusTCP protocol has two fields for addressing. There is the Unit-id, also referred to as Address, Station address or Slave-address in some PLC software. And the other field is the Register address. | ||
- | ==== Product categories | + | * The **Unit-ID** is the device-selector: |
+ | * The **Register Address** then determines the parameter to read or write: ie. voltage, or current, | ||
- | The ModbusTCP Registerlist xlsx file contains a column named 'dbus-service-name' | + | === 2.2 Unit-IDs === |
- | Note that besides device-specific | + | To see a list of available devices, and their Address, go to Settings -> Services -> Modbus/TCP -> Available services: |
+ | Note that both Unit-ID 0 and Unit-ID 100 map to the same internal address. We recommend to use ID 100, since many ModbusTCP clients and PLCs do not work with ID 0. | ||
+ | The list of available | ||
^ Device class ^ Product types ^ Registers | ^ Device class ^ Product types ^ Registers | ||
Line 39: | Line 55: | ||
| com.victronenery.meteo | IMT solar irradiation sensors | 3600 to 3603 | | | com.victronenery.meteo | IMT solar irradiation sensors | 3600 to 3603 | | ||
- | (1): Check for compatible | + | (1): These are the auxiliary temperature sensors built-in to our GX devices, such as the Venus GX. For details, see [[venus-os: |
- | General note: not all list registers are available for each device. For example a BMV Battery Monitor has lots of readings: historical data such as maximum/ | + | ==== 3. Supported ModbusTCP function |
- | ==== Error codes ==== | + | |
- | ^Code^Name^Description^ | + | |
- | |0x01|IllegalFunction|The requested function is not supported.| | + | |
- | |0x02|IllegalDataAddress|The unit-id is available, but one or more of the requested register(s) does not exist.| | + | |
- | |0x03|IllegalDataValue|The requested quantity of registers is invalid. See the modbus specs, http:// | + | |
- | |0x0A|GatewayPathUnavailable|Unit-id is defined in the mapping list, but there is no device found on the mapped port. Double check the unit-id mapping list in the excel sheet, and make sure that the device is properly connected to the CCGX, switched on, and that its data is available on the CCGX display.| | + | |
- | |0x0B|GatewayTargetDeviceFailedToRespond|Requested unit-id not found in the mapping list. Double check the unit id mapping list in the excel sheet.| | + | |
- | ==== Mapping example ==== | + | The supported function codes are: |
+ | * ReadHoldingRegisters | ||
+ | * ReadInputRegisters | ||
+ | * WriteSingleRegister | ||
+ | * WriteMultipleRegisters | ||
+ | Note that there is no difference between function code 3 and 4. | ||
+ | ==== 5. Mapping example ==== | ||
The purpose of this example is to show how to interpret the information in the worksheets of the | The purpose of this example is to show how to interpret the information in the worksheets of the | ||
excel sheet containing the modbustcp mapping. This excel sheet is available for download from our website on the [[https:// | excel sheet containing the modbustcp mapping. This excel sheet is available for download from our website on the [[https:// | ||
- | To request the input voltage of a Multi or Quattro, connected to the VE.Bus sockets on the CCGX, use the following settings: | + | To request the input voltage of a Multi or Quattro, connected to the VE.Bus sockets on the CCGX, use the following settings: |
The ModbusTCP reply will contain 2302. Divide it by 10, as specified in cell E3, and then you have the voltage: 230.2 Volts AC. | The ModbusTCP reply will contain 2302. Divide it by 10, as specified in cell E3, and then you have the voltage: 230.2 Volts AC. | ||
- | ==== Enabling ModbusTCP on the CCGX ==== | + | ==== 6. Error codes and trouble shooting |
- | ==== What is a unit-id and what do I need to set it to? ==== | + | === 6.1 The common cause: Unit-ID / Register combination |
- | The unit-id, sometimes called ‘slave address’, specifies how a product connected to the CCGX needs to be addressed. Since Venus 2.40, this information is available on the CCGX under Settings -> Services -> Modbus/TCP -> Available services. | + | |
- | {{ : | + | In case a certain read or write is not successful, most likely there is an issue in the unitid/ |
- | Additionally this information | + | Besides double checking the mapping, there are two ways to see where the error lies. One is to check the last error as shown in the GX Device menus. And secondly you can look at the error code as is visible |
+ | === 6.2 Looking up the last ModbusTCP Error on the GX Device=== | ||
+ | To see why a certain register is not available, use the Settings -> Services -> ModbusTCP menu. It shows the last error, and reason for that error. | ||
+ | === 6.3 Error codes === | ||
+ | These error codes are returned by our software to the PLC; and most PLC software tools allow seeing them. | ||
+ | ^Code^Name^Description^ | ||
+ | |0x01|IllegalFunction|The requested function is not supported.| | ||
+ | |0x02|IllegalDataAddress|The | ||
+ | |0x03|IllegalDataValue|The requested quantity of registers is invalid. See the modbus specs, http:// | ||
+ | |0x0A|GatewayPathUnavailable|Unit-ID is defined in the mapping | ||
+ | |0x0B|GatewayTargetDeviceFailedToRespond|Requested Unit-ID not found in the mapping list. Double check the Unit-ID mapping list in the excel sheet.| | ||
+ | ==== 7. Support ==== | ||
+ | The recommended method for report on ModbusTCP questions is to use the [[https:// | ||
+ | Direct company support is only offered on a limited basis. For such support, contact our Victron representative. | ||
- | For the overall system data, look for com.victronenergy.system in the excel sheet, and use unit-id 100. | + | ==== 8. FAQ ==== |
- | Note that both unit-id 0 and unit-id 100 map to the same internal address. We recommend to use id 100, since many ModbusTCP clients and PLCs do not work with id 0. | + | === Q1: Which products can be interfaced via Modbus TCP? === |
- | ==== Which products can be interfaced via Modbus TCP? ==== | + | |
All products that can be connected to the [[https:// | All products that can be connected to the [[https:// | ||
- | ==== Can I change a configuration setting in a Multi - for example: the absorption voltage? | + | === Q2: Can I change a configuration setting in a Multi - for example: the absorption voltage? === |
No. | No. | ||
- | ==== Can I request multiple registers at the same time? ==== | + | === Q3: Can I request multiple registers at the same time? === |
Yes, you can! Though make sure not to include non existing registers in your query. Querying register 1 to 100 for example will not work, since registers 1 and 2 do not exist. | Yes, you can! Though make sure not to include non existing registers in your query. Querying register 1 to 100 for example will not work, since registers 1 and 2 do not exist. | ||
- | ==== Can I implement more features myself? | + | === Q4: Can I implement more features myself? === |
Yes, you can! We are, slowly, making the Color Control code open source, and the Modbus-TCP sources are already available on https:// | Yes, you can! We are, slowly, making the Color Control code open source, and the Modbus-TCP sources are already available on https:// | ||
- | ==== In a parallel or three-phase system, how can I address a single unit? ==== | + | === Q5: In a parallel or three-phase system, how can I address a single unit? === |
You cannot interface with them individually if they are configured for parallel-working; | You cannot interface with them individually if they are configured for parallel-working; | ||
+ | === Q6: Will unit-id' | ||
- | ==== Will unit-id' | + | No. |
- | It may change in the case of VEdirect Devices connected via USB - but even then our experience is that it will only change in the first reboot. | + | === Q7: Advanced debugging === |
- | Unit-id' | ||
- | ==== Advanced debugging ==== | ||
If all unit-id' | If all unit-id' | ||
Line 113: | Line 150: | ||
In most cases the problem will be found in either the unit's id address; or the register addresses. Double check the numbers shown in the output with the numbers as used in your modbustcp software or PLC. | In most cases the problem will be found in either the unit's id address; or the register addresses. Double check the numbers shown in the output with the numbers as used in your modbustcp software or PLC. | ||
- | ==== Does Modbus TCP support ESS? ==== | + | === Q8: Does Modbus TCP support ESS? === |
Yes. See the [[https:// | Yes. See the [[https:// | ||
