Connect the battery charger to the battery or batteries.
Connect the battery charger to the wall socket using the AC cable (can be ordered separately).
All the LEDs light up briefly and once the charger has been activated the relevant status LEDs light up, depending on the status of the charger. By default the charger starts up in normal mode and bulk.
If required, press the MODE button to select a different charging algorithm (the battery charger remembers the mode when it is disconnected from the power supply and/or battery).
After selecting reconditioning, the RECONDITION LED will light up and start to blink when reconditioning is active.
The battery charger switches to LOW (low power) when the MODE button is held down for 3 seconds. The LOW LED will then light up and remain lit, and the maximum output current will be limited to 50% of the rated output power. LOW mode can be deactivated by holding the MODE button down for another 3 seconds.
The battery will be about 80% charged and ready for use when the ABSORPTION LED lights up.
The battery will be fully charged when the FLOAT (trickle charging) or STORAGE LED lights up.
You can now interrupt the charging at any time by disconnecting the power supply to the charger.
