8. Specifications
Orion-Tr Smart Charger non-isolated 360 – 400 Watt | 12/12-30 (360 W) | 12/24-15 (360 W) | 24/12-30 (360W) | 24/24-17 (400W) |
Input voltage range (1) | 8-17 V | 8-17 V | 16-35 V | 16-35 V |
Under voltage shut down | 7 V | 7 V | 14 V | 14 V |
Under voltage restart | 7.5 V | 7.5 V | 15 V | 15 V |
Nominal output voltage | 12.2 V | 24.2 V | 12.2 V | 24.2 V |
Output voltage adjust range | 10-15 V | 18-30 V | 10-15 V | 18-30 V |
Output voltage tolerance | +/- 0.2 V | |||
Output noise | 2 mV rms | |||
Cont. output current at nominal output voltage and 40°C | 30 A | 15 A | 30 A | 17 A |
Maximum output current (10 s) at nominal output voltage minus 20% | 40 A | 25 A | 45 A | 25 A |
Short circuit output current | 60 A | 40 A | 60 A | 40 A |
Cont. output power at 25°C | 430 W | 430 W | 430 W | 480 W |
Cont. output power at 40°C | 360 W | 360 W | 360 W | 400 W |
Efficiency | 87% | 88% | 88% | 89% |
No load input current | < 80 mA | < 100 mA | < 100mA | < 80mA |
Standby current | Less than 1 mA | |||
Can be used as power supply | Yes, output voltage can be set with Bluetooth | |||
Operating temperature range | -20 to +55° C (derate 3% per °C above 40° C) | |||
Humidity | Max. 95% non-condensing | |||
DC connection | Screw terminals | |||
Maximum cable cross-section | 16 mm² AWG6 | |||
Weight | 12 V input and/or 12 V output models: 1.8 kg (4 lb) Other models: 1.6 kg (3.5 lb) | |||
Dimensions hxwxd | 12 V input and/or 12 V output models: 131 x 187 x 86 mm (5.2 x 7.4 x 3.4 inch) Other models: 131 x 187 x 71 mm (5.2 x 7.4 x 2.8 inch) | |||
Protection category | IP43 (electronic components), IP22 (connection area) | |||
Standards: Safety Emission Immunity Automotive Directive | EN 60950 EN 61000-6-3, EN 55014-1 EN 61000-6-2, EN 61000-6-1, EN 55014-2 ECE R10-5 | |||
1) If set to nominal or lower than nominal, the output voltage will remain stable within the specified input voltage range (buck-boost function). If the output voltage is set higher than nominal by a certain percentage, the minimum input voltage at which the output voltage remains stable (does not decrease) increases by the same percentage. Note 1) The VictronConnect App will not display current in or current out. Note 2) The Orion-Tr Smart DC-DC Charger Non-Isolated is not equipped with a VE.Direct port. | ||||
