8. Technical Data
MultiPlus | 12/2k/100 | 48/2k/30 | ||
PowerControl / PowerAssist | Yes | |||
Transfer switch | 35A | |||
INVERTER | ||||
Input voltage range | 9.5 - 17Vdc | 38 - 66Vdc | ||
Output voltage | 230Vac ± 2% | |||
Output frequency(1) | 50Hz ± 0,1% | |||
Cont. output power at 25°C (77°F) | 2000W | |||
Cont. output power at 40°C (104°F) | 1800W | |||
Cont. output power at 65°C (149°F) | 1200W | |||
Peak power | 4000W | |||
Maximum efficiency | 93% | 95% | ||
Zero-load power | 11W | 13W | ||
Zero-load power search mode | 3W | |||
CHARGER | ||||
AC Input voltage range | 187 - 265Vac | |||
AC input frequency range | 45 - 65Hz | |||
Charge voltage 'absorption' | 14.4V | 57.6V | ||
Charge voltage 'float' | 13.8V | 55.2V | ||
Storage mode | 13.2V | 52.8V | ||
Charge current house battery (4) | 100A | 30A | ||
Charge current starter battery | 1A | n/a | ||
Battery temperature sensor | Yes | Not included. Order number: ASS000001000 | ||
GENERAL | ||||
Programmable relay (5) | Yes | |||
Protection (2) | a – g | |||
Operating temperature | -40 to +65°C (-40 to + 140°F), fan assisted cooling | |||
Humidity | Maximum 95%, non-condensing | |||
Maximum altitude | 2000m | |||
ENCLOSURE | ||||
Material & colour: | Steel/ABS, blue RAL 5012 | |||
Protection category: | IP 21 | |||
Battery-connection | M8 bolts | |||
230V AC-connection | Screw terminals 13 mm² (6 AWG) | |||
Weight | 15.5kg (34.2lb) | |||
Dimensions (h x w x d) | 506 x 236 x 147mm (19.92 x 9.29 x 5.79 inch) | |||
STANDARDS | ||||
Safety | EN-IEC 60335-1, EN-IEC 60335-2-29, EN 62109-1 | |||
Emission / Immunity | EN 55014-1, EN 55014-2, EN-IEC 61000-3-2, EN-IEC 61000-3-3 IEC 61000-6-1, IEC 61000-6-2, IEC 61000-6-3 | |||
Road vehicles | ECE R10-5 | |||
