7. Technical specifications
MultiPlus 230V | 48/20000/250-100 | ||||
PowerControl / PowerAssist | Yes | ||||
Transfer switch | 100A | ||||
Maximum AC input current | 100A | ||||
INVERTER | |||||
DC input voltage range | 38 – 60V | ||||
Output voltage | 230 VAC ± 2% | ||||
Output frequency(1) | 50 Hz ± 0.1% | ||||
Continuous output power at 25°C | 20kW | ||||
Continuous output power at 40°C | 18kW | ||||
Continuous output power at 65°C | 14kW | ||||
Maximum apparent feed-in power | 20kW | ||||
Time limited output power (cold start) | 21kW 5 hours | ||||
Peak power | 25kW 1 minute | ||||
Maximum efficiency | 96% | ||||
Zero-load power | 65W | ||||
Zero-load power in AES mode | 40W | ||||
Zero-load power in Search mode | 13W | ||||
CHARGER | |||||
AC input voltage range | 187 - 265VAC | ||||
AC input frequency range | 45 - 65Hz | ||||
Charge voltage 'absorption' | 57.6V | ||||
Charge voltage 'float' | 55.2V | ||||
Storage mode | 52.8V | ||||
Max. battery charge current (25°C) | 250A | ||||
Max. battery charge current (40°C) | 240A | ||||
GENERAL | |||||
Auxiliary output | Yes (50A) | ||||
External AC current sensor (optional) | 100A | ||||
Programmable relay (3) | Yes | ||||
Protection (2) | a - g | ||||
VE.Bus communication port | For parallel and three phase operation, remote monitoring and system integration | ||||
General purpose com. port | Yes, 2x | ||||
Operating temperature | -40 to 65°C (fan assisted cooling) | ||||
Humidity (non-condensing) | max 95% | ||||
Maximum altitude | 2000m | ||||
ENCLOSURE | |||||
Material & Colour | Alluminium, blue RAL 5012 | ||||
Protection category | IP 20 | ||||
Battery-connection | Four M8 bolts (2 positive and 2 negative connections) | ||||
230VAC connections | Bolts M6 | ||||
Weight | 80 kg | ||||
Dimensions h x w x d | 616 x 422 x 357 mm | ||||
STANDARDS | |||||
Safety | EN-IEC 60335-1, EN-IEC 60335-2-29, IEC 62109-1, IEC 62109-2, IEC 62477 | ||||
Emission / Immunity | IEC 61000-6-2, IEC 61000-6-4 | ||||
Uninterruptible power supply | Please consult the certificates on our website. | ||||
Anti-islanding | Please consult the certificates on our website. | ||||
