MultiPlus 230V
7. Technical specifications
In this section:
MultiPlus 230V
48/10000/140-100
48/15000/200-100
48/20000/250-100
PowerControl / PowerAssist
Yes
AC input
Input voltage range: 187 - 270 VAC
Input frequency: 50 - 60Hz
Cos φ >0.8
Maximum feed-through current
100A
INVERTER
DC input voltage range
38 – 60V
AC Output in inverter mode (1)
Output voltage: 230 VAC ± 2%
Frequency:  50 Hz ± 0.1%
Continuous output power at 25°C / 77°F (3)
8kW
12kW
20kW
Continuous output power at 40°C / 104°F
7kW
10kW
20kW
Continuous output power at 65°C / 150°F
6kVA
7kW
15.5kW
Maximum feed-in power
8kVA
12kVA
20kVA
Peak power
18kW
27kW
30kW
Power factor range
±0.8
Maximum efficiency
96%
95%
96%
Zero-load power
38W
55W
65W
Zero-load power in AES mode
27W
39W
44W
Zero-load power in Search mode
15W
6W
27W
CHARGER
AC input
Voltage range: 187 - 270VAC
Frequency: 45 - 65Hz
Power factor: 1
Charge voltage 'absorption'
57.6V
Charge voltage 'float'
55.2V
Storage mode
52.8V
Charge current house battery (4)
140A
200A
250A
GENERAL
Auxiliary output
Yes (50A)
External AC current sensor (optional)
100A
Programmable relay (5)
Yes
Protection (2)
a - g
VE.Bus communication port
Three-phase operation, remote monitoring and system integration
General purpose com. port
Yes, 2x
Operating temperature
-20 to 65°C (-4 to 50°F)
Cooling
Fan assisted
Maximum humidity (non-condensing)
95%
Maximum altitude
2000m
ENCLOSURE
Material & Colour
Alluminium, blue RAL 5012
Protection category
IP 20
Battery-connection
Four M8 bolts (2 positive and 2 negative connections)
230VAC connections
Bolts M6
Weight
42 kg
49 kg
80 kg
Dimensions h x w x d
582x427x347 mm
582x427x347 mm
626x422x357 mm
STANDARDS
Safety
EN-IEC 60335-1, EN-IEC 60335-2-29, EN-IEC 62109-1, EN-IEC 62109-2
Emission / Immunity
EN 55014-1, EN 55014-2 EN-IEC 61000-3-2, EN-IEC 61000-3-3 IEC 61000-6-1, IEC 61000-6-2, IEC 61000-6-3
Uninterruptible power supply
Please consult the certificates on our website.
Anti-islanding
  1. Can be adjusted to 60 Hz (120V, 60Hz units available on request).
  2. Protection key:
    1. Output short circuit
    2. Overload
    3. Battery voltage too high
    4. Battery voltage too low
    5. Temperature too high
    6. 230 VAC on inverter output
    7. Input voltage ripple too high
  1. Non-linear load, crest factor 3:1
  2. Up to 75°F / 25°C ambient
  3. The programmable relay can be set for general alarm, DC under voltage or genset start/stop function. AC rating: 120V / 4A, DC rating: 4A up to 35VDC and 1A up to 60VDC.
