7. Technical specifications
MultiPlus-II 2x120V | 12/3000/120-50 | 12/4k/160-50 | 24/3000/70-50 | ||
PowerControl & PowerAssist | Yes (on L1 input) | ||||
Transfer switch | 50A | ||||
Maximum AC input current | 50A (each leg) | ||||
INVERTER | |||||
DC Input voltage range | 9.5 – 17V | 9.5 -17V | 19 - 33V | ||
Output in inverter mode | Output voltage: 120VAC ± 2% Frequency: 60Hz ± 0.1% | ||||
Continuous output power at 25°C/77°F (3) | 3000 VA | 3000 VA | |||
Continuous output power at 25C/77°F | 2400 W | 3.4 kW | 2400 W | ||
Continuous output power at 40C/104°F | 2200 W | 3.1 kW | 2200 W | ||
Time limited power 1 (cold start) | 4.0kW/1h | ||||
Continuous output power at 65C/150°F | 1700 W | 2.4 kW | 1700 W | ||
Time limited power 2 (cold start) | 4.5kW/30min | ||||
Peak power | 5500 W | 6 kW/2s | 5500 W | ||
Maximum efficiency | 93% | 93% | 94% | ||
Zero load power | 15 W | 18 W | 11 W | ||
Zero load power in AES mode | 10 W | 11 W | 8 W | ||
Zero load power in Search mode | 4 W | 4 W | 4 W | ||
CHARGER | |||||
AC Input | Split phase: 180-280 VAC 55 – 65 Hz Single phase: 90-140 VAC 55 – 65 Hz | ||||
Charge voltage 'absorption' | 14.4 V | 14.4 V | 28.8 V | ||
Charge voltage 'float' | 13.8 V | 13.8 V | 27.6 V | ||
Storage mode | 13.2 V | 13.2 V | 26.4 V | ||
Maximum battery charge current (4) | 120 A | 160 A | 70 A | ||
Battery temperature sensor | Yes | ||||
GENERAL | |||||
Auxiliary output (5) | 50A (each leg) See note 8 | ||||
External AC current sensor (optional) | 100 A | ||||
Programmable relay (6) | Yes | ||||
Protection (2) | a – g | ||||
VE.Bus communication port | For parallel and three phase operation, remote monitoring and system integration | ||||
General purpose communication port (7) | Yes, 2x | ||||
Remote on-off | Yes | ||||
Operating temperature range | -40 to +65°C (-40 - 150°F) fan assisted cooling | ||||
Humidity (non-condensing) | max 95% | ||||
ENCLOSURE | |||||
Material & Colour | Steel, blue RAL 5012 | ||||
Protection category | IP22 | ||||
Battery-connection | 2x2 M8 bolts | 2x2 M8 bolts | 2 M8 bolts | ||
120/240 V AC-connection | Screw terminals 21 mm² (4 AWG) | ||||
Weight | 22 kg (50 lb) | 25 kg (55 lb) | 22kg (48 lb) | ||
Dimensions hxwxd | 578 x 275 x 148 mm 23 x 11 x 6 inch | 650 x 275 x 165 mm 25.6 x 11 x 6.5 inch | 578 x 275 x 148 mm 23 x 11 x 6 inch | ||
STANDARDS | |||||
Safety | EN-IEC 60335-1, EN-IEC 60335-2-29, UL 458 | ||||
Emission, Immunity | EN 55014-1, EN 55014-2 EN-IEC 61000-3-2, EN-IEC 61000-3-3 IEC 61000-6-1, IEC 61000-6-2, IEC 61000-6-3 | ||||
MultiPlus-II 2x120V 50/60Hz | 12/4k/160-50 | ||||
INVERTER | |||||
DC Input voltage range | 9.5 -17V | ||||
Output in inverter mode | Output voltage: 120VAC ± 2% Frequency: 60Hz ± 0.1%(1) | ||||
Continuous output power at 25°C | 3.4kW | ||||
Continuous output power at 40°C | 3.1kW | ||||
Continuous output power at 65°C | 2.4kW | ||||
Peak power | 6kW/2s | ||||
Maximum efficiency | 93% | ||||
Zero load power | 18W | ||||
Zero load power in AES mode | 11W | ||||
Zero load power in Search mode | 4W | ||||
CHARGER | |||||
AC Input | Split phase: 180-280 VAC 45 – 65 Hz Single phase: 90-140 VAC 45 – 65 Hz | ||||
Charge voltage 'absorption' | 14.4V | ||||
Charge voltage 'float' | 13.8V | ||||
Storage mode | 13.2V | ||||
Maximum battery charge current (4) | 160A | ||||
GENERAL | |||||
External AC current sensor (optional) | 100A | ||||
ENCLOSURE | |||||
Battery-connection | 2x2 M8 bolts | ||||
Weight | 25 kg (55 lb) | ||||
Dimensions hxwxd | 650 x 275 x 165 mm 25.6 x 11 x 6.5 inch | ||||
STANDARDS | |||||
