Lynx Shunt VE.Can
7. Commissioning the Lynx Shunt VE.Can
In this section:
Commissioning sequence:
checkbox.svg
Check polarity of all DC cables.
checkbox.svg
Check cross sectional area of all DC cables.
checkbox.svg
Check if all cable lugs have been crimped correctly.
checkbox.svg
Check if all cable connections are tight (don’t exceed maximum torque).
checkbox.svg
Tug slightly on each battery cable to check if the connections are tight and if the cable lugs have been crimped correctly.
checkbox.svg
Turn a load on and see if the battery monitor displays the correct current polarity.
checkbox.svg
Fully charge the battery, so that the battery monitor synchronises.
