5. Technical specifications
In this section:
Isolation Transformer | 8000W 230V |
AC input voltage | 230V |
AC output voltage | 240V |
Frequency | 50/60Hz |
Output current rating | 35A |
Soft start | Yes |
Operating temperature range | -20°C to 40°C |
Humidity | Max 95%, non-condensing |
Transformer type | Toroidal (low noise, low weight), 1:1.05 ratio |
Enclosure | Aluminium (blue RAL5012) |
Protection category | IP21 |
Safety | EN 60076 |
Weight | 28.17 kg |
Dimensions (h x w x d), mm | 362 x 258 x 243 |
