EasySolar-II GX
12. Technical specifications
In this section:
EasySolar-II GX 230V
48/4k5/55-32 MPPT 250/70
48/6k5/100-50 MPPT 250/100 GX
PowerControl & PowerAssist
Yes
Transfer switch
32 A
50 A
Maximum AC input current
32 A
50 A
INVERTER/CHARGER
Input voltage range
38 – 60 V
Output in inverter mode (1)
Output voltage: 230 VAC ± 2%    Frequency: 50 Hz ± 0.1%
Cont. output power at 25°C
4 kW
6 kW
Cont. output power at 40°C
3.7 kW
5.7 kW
Cont. output power at 65°C
3 kW
4.6 kW
Time-limited power 1 (cold start)
4.5 kW/2h
6.5 kW/4h
Time-limited power 2 (cold start)
6 kW/25min
8 kW/1h
Maximum feed-in power
4 kW
6 kW
Peak power
7 kW/1min
11 kW/1min
Maximum efficiency
95 %
96 %
Zero load power
20 W
28 W
Zero load power in AES mode
13 W
18 W
Zero load power in Search mode
8 W
8 W
AC Input
Input voltage range: 187-265 VAC    Input frequency: 45–65 Hz
Charge voltage 'absorption'
57.6 V
Charge voltage 'float'
55.2 V
Storage mode
52.8 V
Maximum battery charge current at 25°C
55 A
100 A
Maximum battery charge current at 40°C
50 A
95 A
Battery temperature sensor
Optional. Order number: ASS000001000
Compatible battery chemistries
Lithium, Lead -acid, Zinc -Bromine and more(3)
GENERAL
Auxiliary output
Yes (32 A)
External AC current sensor (optional)
100 A
Programmable relay (4)
Yes
Protection (2)
a - g
VE.Bus communication port
For parallel and three-phase operation, remote monitoring and system integration
General purpose communication port
Yes, 2x
Remote on/off
Yes
GX device interfaces
VE.Can, USB, Ethernet, VE.Direct, Wi-Fi
Operating temperature range
-40 to +65 °C (fan-assisted cooling).
Humidity (non -condensing)
Maximum 95 %
Maximum altitude
2000 m
SMART SOLAR CHARGER
Model
MPPT 250/70-Tr
MPPT 250/100-Tr
Maximum output current
70 A
100 A
Maximum PV power
4000 W
5800 W
Maximum PV open circuit voltage
250 V
Maximum efficiency
99 %
Self-consumption
20 mA
Charge voltage 'absorption', default
57.6 V
Charge voltage 'float', default
55.2 V
ENCLOSURE
Material and colour
Steel, blue RAL 5012
Protection category
IP21
Battery connection
M8 bolts
230VAC connection
Screw terminals 13 mm2 (6 AWG)
Weight
28.8 kg
39.6 kg
Dimensions hxwxd
591 x 275 x 254 mm
670 x 320 x 270 mm
STANDARDS
Safety
EN-IEC 62019-1, EN-IEC 6201-2, EN-IEC 60335-1, EN-IEC 60335-2-29
Emission / Immunity
EN55014-1, EN 55014-2 EN-IEC 61000-3-2, EN-IEC 61000-3-3
IEC 61000-6-1, IEC 61000-6-2, IEC 61000-6-3
Uninterruptible power supply
IEC 62040-1
1) Can be adjusted to 60 Hz
2) Protection key:
a) output short circuit
b) overload
c) battery voltage too high
d) battery voltage too low
e) temperature too high
f) 230VAC on inverter output
g) input voltage ripple too high
3) Other chemistries are possible as well, provided the charger is configured according to the battery manufacturer’s specification.
4) Programmable relay which can be set for general alarm, DC under voltage or generator start/stop function.  AC rating: 230 V / 4 A, DC rating: 4 A up to 35 VDC and 1 A up to 60 VDC
