7. Technical specification
EV Charging Station | |
Input voltage range (V AC) | 170 – 265 V AC @ 50 Hz |
Rated charge current | 32 A / phase |
Nominal power | 22 kW |
Self-consumption | 15 mA @ 230 V |
Configurable min. / max. current | 6 - 32 A |
Connector type | IEC 62196 Type 2 |
GENERAL | |
Means to Disconnect | External fuse or circuit breaker, max 40 A, depending on available input power |
Configurable price/kWh calculator | Default setting: € 0.13 (adjustable) |
Control type | Touch Screen, Web interface, GX device, VictronConnect (locally via Bluetooth), VictronConnect-Remote (from anywhere via VRM) |
Light Ring | 55 configurable light effects available |
Protection | External RCD is required |
Operating temperature | -25 °C to +50 °C |
Storage temperature | -40 °C to +80 °C |
Humidity | 95 %, non-condensing |
Data communication | MQTT and Modbus TCP over WiFi, Bluetooth |
Wi-Fi standards | 802.11 b/g/n (2.4 GHz only) |
ENCLOSURE | |
Enclosure colour | Light Blue (RAL 5012) |
Power terminals | 6-10 mm² / AWG 10-8 |
Protection category | IP44 |
Ventilation | not required |
Weight | 3 kg |
Dimensions (h x w x d) | 377 x 307 x 148 mm |
STANDARDS | |
Safety | IEC 61851-1, IEC 61851-22 Detection for Relay Contact welded Detection for missing protective conductor Detection for missing Ground Detection for shorted CP |
7.1. Dimensions
