9. Technical specifications
Electrical | 12/15 | 12/20 | 12/30 | 24/8 | 24/12 | 24/16 | |
Mains power voltage (Nominal | Min/Max) | 220 - 240VAC | 180 - 265VAC | ||||||
Mains power frequency (Nominal | Min/Max) | 50 - 60Hz | 45 - 65Hz | ||||||
Power factor | >0.6 | ||||||
Standby power | 0.5W | ||||||
Max efficiency | 93% | 94% | |||||
Charge voltage (Absorption | Float | Storage) | Normal | 14.4V | 13.8V | 13.2V | 28.8V | 27.6V | 26.4V | ||||
High | 14.7V | 13.8V | 13.2V | 29.4V | 27.6V | 26.4V | |||||
Li-ion | 14.2V | N/A | 13.5V | 28.4V | N/A | 27.0V | |||||
Temperature compensation (N/A for Li-ion) | -16mV/°C (-9mV/°F) | -32mV/°C (-18mV/°F) | |||||
Charge algorithm | 6-stage adaptive (3 stage for Li-ion) | ||||||
Charge current limit (in selected mode) | Max | 15A | 20A | 30A | 8A | 12A | 16A |
Low | 7.5A | 10A | 15A | 4A | 6A | 8A | |
Min | 3.7A | 5A | 7.5A | 2A | 3A | 4A | |
Max battery capacity (≥0.1C in max mode) | 150Ah | 200Ah | 300Ah | 80Ah | 120Ah | 160Ah | |
Min battery capacity - Lead-acid (≤0.3C in selected mode) | Max | 50Ah | 67Ah | 100Ah | 27Ah | 40Ah | 53Ah |
Low | 25Ah | 33Ah | 50Ah | 13Ah | 20Ah | 27Ah | |
Min | 12Ah | 17Ah | 25Ah | 7Ah | 10Ah | 13Ah | |
Min battery capacity - Li-ion (≤0.5C in selected mode) | Max | 30Ah | 40Ah | 60Ah | 16Ah | 24Ah | 32Ah |
Low | 15Ah | 20Ah | 30Ah | 8Ah | 12Ah | 16Ah | |
Min | 7Ah | 10Ah | 15Ah | 4Ah | 6Ah | 8Ah | |
Fault protection | Reverse polarity (fuse), output short circuit and over temperature | ||||||
Communication | Bluetooth (via VictronConnect app) | ||||||
Bluetooth power and frequency | +4dBm | 2402 - 2480MHz | ||||||
Cooling | Fan assisted (except 12/15 and 24/08) | ||||||
Operating temperature range | -20 to 50°C (-4 to 122°F) with full rated output up to 40°C (104°F) | ||||||
Max humidity | 95% | ||||||
Physical | |||||||
Material and colour | Aluminium | Blue RAL 5012 | ||||||
Mains power connection | 1.5m (5ft) mains cable with CEE 7/7, BS 1363 or AS/NZS 3112 plug | ||||||
Battery connection | Type | 16mm² (6 AWG) screw terminals | |||||
Outputs | 1 output or 3 isolated outputs (except 24/8 and 24/12 models) | ||||||
Output fuse rating | 20A | 30A | 40A | 15A | 20A | 25A | |
Ingress protection (IP) rating | IP22 | ||||||
Weight | 1.3kg (2.9lbs) | ||||||
Dimensions (h x w x d) | 235 x 108 x 65 mm (9.3 x 4.3 x 2.6 inch) | ||||||
Compliance | |||||||
Safety | EN 60335-1, EN 60335-2-29 | ||||||
EMC | ETSI EN 301 489-1 V2.2.3, ETSI EN 301 489-17 V3.2.4, ETSI EN 300 328 V2.2.2 | ||||||
Automotive | ECE R10 | ||||||
