vrm_portal:vrm_world
vrm_portal:vrm_world [2016-01-18 10:30] – created mvader | vrm_portal:vrm_world [2019-01-21 11:16] – [DISQUS] ictbeheer | ||
====== VRM World ====== | ====== VRM World ====== | ||
- | (draft) | ||
- | https://vrm.victronenergy.com/world/ | + | VRM World is a way to publicly share your VRM site data to the world via a searchable world map. Naturally access to your site configuration, |
- | To publish your site on VRM World, it needs to: | + | {{ :vrm_portal: |
- | * Site must have fresh data (?? hours) | + | Visit VRM World at [[https:// |
- | * Configured lat/long location | + | |
- | * ?? (trimm to complete) | + | |
- | Then go to your site, click the Share icon | + | In order for your site to show up on VRM World, it needs to: |
- | {{ :vrm_portal: | + | * Have sharing on VRM World enabled in VRM. |
+ | * Have fresh data (last update within the last 24 hours) | ||
+ | * Have data for at least one of the following: solar yield, battery SOC, AC power in or consumption | ||
+ | * Have its location configured (set manually in VRM or via a connected GPS) | ||
- | And enable the Show on Victron world button: | + | Sites which do not meet these requirements (anymore) will be hidden on VRM World. Whenever they meet the requirements (again), they will show up again. If your site isn't visible despite having enabled sharing, please check that it meets the other requirements. |
+ | If your site meets the above requirements you can enable | ||
+ | {{ :vrm_portal:vrm-share-icon.png? | ||
- | {{ :vrm_portal: | + | Here, enable the option to 'Share publicly on VRM World': |
- | In case you don't see the Show on Victron World button, double check above criteria. | + | {{ : |
+ | What happens when you share your site on VRM World? | ||
+ | - It will be shown on the digital globe on [[https:// | ||
+ | - Anyone will be able to click the ' | ||
+ | * The precise location will not be shown, and of course visitors will not be able to change any settings, see phone numbers or other privacy sensitive information. | ||
- | ~~DISQUS~~ | ||
vrm_portal/vrm_world.txt · Last modified: 2019-01-22 10:16 by 127.0.0.1
