vrm_portal:dashboard
vrm_portal:dashboard [2022-04-14 06:09] – [3.1 Inverter controls in VRM] guystewart | vrm_portal:dashboard [2023-01-31 06:27] – [3.1 Inverter controls in VRM] guy_stewart | ||
Line 116: | Line 116: | ||
===== 3. Control your devices in VRM ===== | ===== 3. Control your devices in VRM ===== | ||
- | VRM offers control over some of your Victron devices, straight from the VRM dashboard. With this feature, you can quickly adjust the settings | + | VRM offers control over some of your Victron devices, straight from the VRM dashboard. With this feature, you can quickly adjust the settings ESS or relay switches, without needing to open the remote console. |
To access it, head to your VRM dashboard. | To access it, head to your VRM dashboard. | ||
Line 126: | Line 126: | ||
==== 3.1 Inverter controls in VRM ==== | ==== 3.1 Inverter controls in VRM ==== | ||
- | Note - while initially | + | VE.Bus Inverter controls can be made available |
==== 3.2 ESS controls in VRM ==== | ==== 3.2 ESS controls in VRM ==== | ||
vrm_portal/dashboard.txt · Last modified: 2023-10-10 11:50 by sloges
