vrm_portal:dashboard
vrm_portal:dashboard [2021-04-07 18:05] – guystewart | vrm_portal:dashboard [2023-10-10 11:50] (current) – [1.5. Details per section] sloges | ||
Line 36: | Line 36: | ||
Configuration: | Configuration: | ||
- | - Configure the battery settings on the GX Device, in the Settings | + | - Configure the battery settings on the GX Device, in the Menu → Settings |
- Meet all the requirements for the Real time feature, as this information is only available when in Real time mode. See Chapter 2. | - Meet all the requirements for the Real time feature, as this information is only available when in Real time mode. See Chapter 2. | ||
- Two or more batteries must be configured. If there is just one, then the information is already shown as part of the main system overview. | - Two or more batteries must be configured. If there is just one, then the information is already shown as part of the main system overview. | ||
Line 64: | Line 64: | ||
* Battery monitor (BMV, SmartShunt or similar): Voltage on the left axis and SOC on the right access | * Battery monitor (BMV, SmartShunt or similar): Voltage on the left axis and SOC on the right access | ||
- | * Phoenix | + | * Inverter: Output power on the left axis, Battery voltage on the right axis |
* Solar Charger: Output power on the left axis, Battery voltage on the right axis. | * Solar Charger: Output power on the left axis, Battery voltage on the right axis. | ||
Requirements for the kWh production and consumption data are explained [[vrm_portal: | Requirements for the kWh production and consumption data are explained [[vrm_portal: | ||
- | Screenshot of an installation with only a Phoenix | + | Screenshot of an installation with only an Inverter, thus showing the line diagram: |
Line 112: | Line 112: | ||
vrm_portal/dashboard.txt · Last modified: 2023-10-10 11:50 by sloges
