vrm_portal:dashboard
vrm_portal:dashboard [2021-04-07 18:05] – guystewart | vrm_portal:dashboard [2022-07-03 12:47] – [3.1 Inverter controls in VRM] guystewart | ||
Line 36: | Line 36: | ||
Configuration: | Configuration: | ||
- | - Configure the battery settings on the GX Device, in the Settings | + | - Configure the battery settings on the GX Device, in the Menu → Settings |
- Meet all the requirements for the Real time feature, as this information is only available when in Real time mode. See Chapter 2. | - Meet all the requirements for the Real time feature, as this information is only available when in Real time mode. See Chapter 2. | ||
- Two or more batteries must be configured. If there is just one, then the information is already shown as part of the main system overview. | - Two or more batteries must be configured. If there is just one, then the information is already shown as part of the main system overview. | ||
Line 112: | Line 112: | ||
+ | Inverter controls can be made available on the VRM Dashboard, but require an additional step to enable in the Settings for that specific VRM Installation. This is to prevent accidentally switching off the system. | ||
+ | Note - there is a limitation where these controls are not available when using a Digital Multi Control, or VE.Bus BMS in the system. | ||
vrm_portal/dashboard.txt · Last modified: 2023-10-10 11:50 by sloges
