vrm_portal:dashboard
vrm_portal:dashboard [2021-04-07 18:05] – guystewart | vrm_portal:dashboard [2022-04-14 09:35] – [3. Control your devices in VRM] guystewart | ||
Line 36: | Line 36: | ||
Configuration: | Configuration: | ||
- | - Configure the battery settings on the GX Device, in the Settings | + | - Configure the battery settings on the GX Device, in the Menu → Settings |
- Meet all the requirements for the Real time feature, as this information is only available when in Real time mode. See Chapter 2. | - Meet all the requirements for the Real time feature, as this information is only available when in Real time mode. See Chapter 2. | ||
- Two or more batteries must be configured. If there is just one, then the information is already shown as part of the main system overview. | - Two or more batteries must be configured. If there is just one, then the information is already shown as part of the main system overview. | ||
Line 112: | Line 112: | ||
+ | Note - while initially available, inverter controls have since been removed and are not currently accessible via the controls feature. | ||
vrm_portal/dashboard.txt · Last modified: 2023-10-10 11:50 by sloges
