vrm_portal:dashboard
vrm_portal:dashboard [2020-09-28 12:31] – [2.4 GX Device CPU Load] justin_tyers_live_a_c | vrm_portal:dashboard [2023-01-31 06:27] – [3.1 Inverter controls in VRM] guy_stewart | ||
Line 18: | Line 18: | ||
- | ==== 1.4. Details per section ==== | + | ==== 1.5. Details per section ==== |
- | === 1.4.1 Schematic visualisation === | + | === 1.5.1 Schematic visualisation === |
Line 26: | Line 26: | ||
The information shown adapts itself to the system installed. For systems without an inverter/ | The information shown adapts itself to the system installed. For systems without an inverter/ | ||
- | === 1.4.2 Battery block === | + | === 1.5.2 Battery block === |
- | Intended | + | The purpose of this part of the dashboard is to show all available batteries, |
- | To see this information, the following must be done: | + | For each of the configured battery, the VRM Portal will show its name, the voltage, current, and state of charge. |
- | - Configure the battery settings on the GX Device, in the Settings -> System Setup -> Marine MFD App menu | + | Configuration: |
- | - Meet all the requirements for the Real time feature, as this information is only available when in Real time mode. See Chapter 2. | + | |
- | === 1.4.3 Historical data === | + | - Configure the battery settings on the GX Device, in the Menu → Settings → System Setup → Battery Measurements |
+ | - Meet all the requirements for the Real time feature, as this information is only available when in Real time mode. See Chapter 2. | ||
+ | - Two or more batteries must be configured. If there is just one, then the information is already shown as part of the main system overview. | ||
+ | This is the main configuration menu: | ||
+ | It lists all available battery measurements. Including battery monitors, but also a simple voltage measurement by a solar charger or battery charger for example. For a three output charger, it will list all three measured voltages. | ||
+ | The GX Device allows configuration of each of the available battery measurements: | ||
+ | - to hide or show it | ||
+ | - to name it | ||
+ | Screenshot of detailed menu: | ||
+ | === 1.5.3 Historical data === | ||
Depending on available information, | Depending on available information, | ||
Line 70: | Line 88: | ||
==== 2.2 Disabling the realtime data feature ==== | ==== 2.2 Disabling the realtime data feature ==== | ||
- | Within a few weeks, a switch will be added to the Settings | + | It is possible |
+ | Examples of when you want to disable real time data are: | ||
* To keep data usage to a minimum, while keeping the VRM Two way communication setting enabled to be able to remotely configure & firmware update | * To keep data usage to a minimum, while keeping the VRM Two way communication setting enabled to be able to remotely configure & firmware update | ||
Line 79: | Line 99: | ||
* A GX Device, with Venus OS v2.60 or later | * A GX Device, with Venus OS v2.60 or later | ||
* Good internet connection | * Good internet connection | ||
- | * Settings -> VRM Portal -> Two way communication must be enabled | ||
* Sufficient CPU resources (see below) | * Sufficient CPU resources (see below) | ||
+ | * Settings -> VRM Portal -> Two way communication must be enabled | ||
==== 2.4 GX Device CPU Load ==== | ==== 2.4 GX Device CPU Load ==== | ||
Line 89: | Line 112: | ||
vrm_portal/dashboard.txt · Last modified: 2023-10-10 11:50 by sloges
