vrm_portal:dashboard
vrm_portal:dashboard [2020-09-28 12:09] – [1.4 Example screenshot for Off-grid installation] thlassche | vrm_portal:dashboard [2022-09-13 09:35] – [3.1 Inverter controls in VRM] guystewart | ||
Line 18: | Line 18: | ||
- | ==== 1.4. Details per section ==== | + | ==== 1.5. Details per section ==== |
- | === 1.4.1 Schematic visualisation === | + | === 1.5.1 Schematic visualisation === |
- | The information shown adopts | + | The information shown adapts |
- | === 1.4.2 Battery block === | + | === 1.5.2 Battery block === |
- | Intended | + | The purpose of this part of the dashboard is to show all available batteries, |
- | To see this information, the following must be done: | + | For each of the configured battery, the VRM Portal will show its name, the voltage, current, and state of charge. |
- | - Configure the battery settings on the GX Device, in the Settings -> System Setup -> Marine MFD App menu | + | Configuration: |
- | - Meet all the requirements for the Real time feature, as this information is only available when in Real time mode. See Chapter 2. | + | |
- | === 1.4.3 Historical data === | + | - Configure the battery settings on the GX Device, in the Menu → Settings → System Setup → Battery Measurements |
+ | - Meet all the requirements for the Real time feature, as this information is only available when in Real time mode. See Chapter 2. | ||
+ | - Two or more batteries must be configured. If there is just one, then the information is already shown as part of the main system overview. | ||
- | Depending on available information, | + | This is the main configuration menu: |
+ | It lists all available battery measurements. Including battery monitors, but also a simple voltage measurement by a solar charger or battery charger for example. For a three output charger, it will list all three measured voltages. | ||
+ | The GX Device allows configuration of each of the available battery measurements: | ||
+ | - to hide or show it | ||
+ | - to name it | ||
+ | Screenshot of detailed menu: | ||
+ | === 1.5.3 Historical data === | ||
+ | Depending on available information, | ||
Line 58: | Line 76: | ||
==== 2.1 Introduction ==== | ==== 2.1 Introduction ==== | ||
- | The dashboard can show real time data, meaning that data updates | + | The dashboard can show real time data, meaning that every two seconds |
The new dashboard increases the GX CPU load. Data usage is also increased. Both the CPU load and data usage are only increased while the dashboard is being observed. | The new dashboard increases the GX CPU load. Data usage is also increased. Both the CPU load and data usage are only increased while the dashboard is being observed. | ||
Line 70: | Line 88: | ||
==== 2.2 Disabling the realtime data feature ==== | ==== 2.2 Disabling the realtime data feature ==== | ||
- | Within a few weeks, a switch will be added to the Settings | + | It is possible |
+ | Examples of when you want to disable real time data are: | ||
* To keep data usage to a minimum, while keeping the VRM Two way communication setting enabled to be able to remotely configure & firmware update | * To keep data usage to a minimum, while keeping the VRM Two way communication setting enabled to be able to remotely configure & firmware update | ||
Line 79: | Line 99: | ||
* A GX Device, with Venus OS v2.60 or later | * A GX Device, with Venus OS v2.60 or later | ||
* Good internet connection | * Good internet connection | ||
- | * Settings -> VRM Portal -> Two way communication must be enabled | ||
* Sufficient CPU resources (see below) | * Sufficient CPU resources (see below) | ||
+ | * Settings -> VRM Portal -> Two way communication must be enabled | ||
==== 2.4 GX Device CPU Load ==== | ==== 2.4 GX Device CPU Load ==== | ||
- | Transmitting the data to the VRM Dashboard causes an extra load on the CPU in the GX Device. As such, for systems already operating at 100% CPU, or close to it, would be overloaded. Meaning | + | Transmitting the data to the VRM Dashboard causes an extra load on the CPU in the GX Device. As such, systems already operating at 100% CPU, or close to it, would be overloaded |
To prevent this, the dashboard will automatically suspend itself in case the CPU load is too high. In which case a warning is shown on the lower right on your screen: | To prevent this, the dashboard will automatically suspend itself in case the CPU load is too high. In which case a warning is shown on the lower right on your screen: | ||
+ | Inverter controls can be made available on the VRM Dashboard, but require an additional step to enable in the Settings for that specific VRM Installation. This is to prevent accidentally switching off the system. | ||
+ | Note - there is a limitation where these controls are not available when using a Digital Multi Control, or VE.Bus BMS v1 in the system. | ||
vrm_portal/dashboard.txt · Last modified: 2023-10-10 11:50 by sloges
