vrm_portal:dashboard
vrm_portal:dashboard [2020-09-28 11:19] – [1.1. Details per section] thlassche | vrm_portal:dashboard [2023-01-31 06:27] – [3.1 Inverter controls in VRM] guy_stewart | ||
===== 1.Introduction & available information ===== | ===== 1.Introduction & available information ===== | ||
- | The dashboard is the main page. It shows all information | + | The dashboard is the main page. It shows all information |
+ | ==== 1.1 Introduction video ==== | ||
{{youtube> | {{youtube> | ||
+ | ==== 1.2 Example screenshot for yacht installation ==== | ||
+ | ==== 1.3 Example screenshot for ESS installation ==== | ||
- | ==== 1.1. Details per section | + | ==== 1.4 Example screenshot for Off-grid installation |
- | === 1.1.1 Schematic visualisation === | + | {{: |
+ | ==== 1.5. Details per section ==== | ||
+ | === 1.5.1 Schematic visualisation === | ||
- | === 1.1.2 Battery block === | + | The information shown adapts itself to the system installed. For systems without an inverter/ |
+ | === 1.5.2 Battery block === | ||
- | Intended | + | The purpose of this part of the dashboard is to show all available batteries, |
- | To see this information, the following must be done: | + | For each of the configured battery, the VRM Portal will show its name, the voltage, current, and state of charge. |
- | - Configure the battery settings on the GX Device, in the Settings -> System Setup -> Marine MFD App menu | + | Configuration: |
- | - Meet all the requirements for the Real time feature, as this information is only available when in Real time mode. See Chapter 2. | + | |
- | === 1.1.3 Historical data === | + | - Configure the battery settings on the GX Device, in the Menu → Settings → System Setup → Battery Measurements |
+ | - Meet all the requirements for the Real time feature, as this information is only available when in Real time mode. See Chapter 2. | ||
+ | - Two or more batteries must be configured. If there is just one, then the information is already shown as part of the main system overview. | ||
- | Depending on available information, | + | This is the main configuration menu: |
+ | It lists all available battery measurements. Including battery monitors, but also a simple voltage measurement by a solar charger or battery charger for example. For a three output charger, it will list all three measured voltages. | ||
+ | The GX Device allows configuration of each of the available battery measurements: | ||
+ | - to hide or show it | ||
+ | - to name it | ||
+ | Screenshot of detailed menu: | ||
+ | === 1.5.3 Historical data === | ||
+ | Depending on available information, | ||
- | Or, in case that information is not available, it will show a line diagram. | + | Or, in case that information is not available, it will show a line diagram. |
- | On the right Y-axis will show battery state of charge when available. And if not, then battery | + | * Battery monitor (BMV, SmartShunt or similar): Voltage on the left axis and SOC on the right access |
+ | * Phoenix Inverter: Output power on the left axis, Battery | ||
+ | * Solar Charger: Output power on the left axis, Battery voltage on the right axis. | ||
Requirements for the kWh production and consumption data are explained [[vrm_portal: | Requirements for the kWh production and consumption data are explained [[vrm_portal: | ||
+ | Screenshot of an installation with only a Phoenix Inverter, and thus showing the line diagram: | ||
===== 2. Real time data ===== | ===== 2. Real time data ===== | ||
==== 2.1 Introduction ==== | ==== 2.1 Introduction ==== | ||
- | The dashboard can show real time data, meaning that data updates | + | The dashboard can show real time data, meaning that every two seconds |
- | ==== 2.2 Requirements ==== | + | The new dashboard increases the GX CPU load. Data usage is also increased. Both the CPU load and data usage are only increased while the dashboard is being observed. |
+ | Check the top of the page to see if its in real time mode. Here is a screenshot when using real time data: | ||
+ | And here is a screenshot of a system not using real time data: | ||
+ | ==== 2.2 Disabling the realtime data feature ==== | ||
+ | It is possible to disable the realtime data feature in the VRM -> Select Installation Site -> Settings -> General -> Realtime updates green(on) / red(off). | ||
+ | Examples of when you want to disable real time data are: | ||
+ | * To keep data usage to a minimum, while keeping the VRM Two way communication setting enabled to be able to remotely configure & firmware update | ||
+ | * For systems where CPU load is already at the edge of what is possible, so rather than each time waiting for it to be automatically disabled (see below), and thus also having a short time of high CPU load on the system, disable it permanently. | ||
+ | ==== 2.3 Requirements ==== | ||
* A GX Device, with Venus OS v2.60 or later | * A GX Device, with Venus OS v2.60 or later | ||
* Good internet connection | * Good internet connection | ||
- | * Settings -> VRM Portal -> Two way communication must be enabled | ||
* Sufficient CPU resources (see below) | * Sufficient CPU resources (see below) | ||
+ | * Settings -> VRM Portal -> Two way communication must be enabled | ||
- | ==== 2.3 GX Device CPU Load ==== | + | {{: |
- | Transmitting the data to the VRM Dashboard causes an extra load on the CPU in the GX Device. As such, for systems already operating at 100% CPU, or close to it, would be overloaded. Meaning | + | |
+ | ==== 2.4 GX Device CPU Load ==== | ||
+ | Transmitting the data to the VRM Dashboard causes an extra load on the CPU in the GX Device. As such, systems already operating at 100% CPU, or close to it, would be overloaded | ||
To prevent this, the dashboard will automatically suspend itself in case the CPU load is too high. In which case a warning is shown on the lower right on your screen: | To prevent this, the dashboard will automatically suspend itself in case the CPU load is too high. In which case a warning is shown on the lower right on your screen: | ||
vrm_portal/dashboard.txt · Last modified: 2023-10-10 11:50 by sloges
