vrm_portal:change_log
VRM Portal Changelog
2023-05-12
- Performance improvement: When navigating away from a VRM tab for more than 10s the Realtime connection stops. When coming back to the tab the connection is re-established and Realtime data starts showing again.
2023-05-11
- Dashboard: Improve the performance (reduce CPU & memory use) of rendering the real time data updates to the “Detailed” fold-outs on the Dashboard. This is part of ongoing work: more improvements to fix out-of-date / slow performing VRM Portal pages are expected in the coming days.
- Custom widgets: Fix the legend and series colors being duplicated for the same device type.
- Production report: fix broken generator run hours
2023-05-10
- Improve data reloading when returning to an inactive VRM tab in Firefox and Chrome.
2023-05-09
- Date picker: Remove date rounding when custom ranges are selected.
- Dashboard: Fix showing the correct Local time after coming back to an inactive VRM tab.
- Fix showing the Local time in the correct timezone in all browsers.
2023-05-04
- Internal: Major upgrade of the API framework.
2023-04-28
- General: Update translations
- Login: Add better type validation to login API request
- Installation users: Fix tooltip text explaining that the latest admin can not be removed
2023-04-26
- Add Installation: Remove SHS (PAYGo) device
2023-04-23
- Advanced: Show correct last seen timestamp.
- Advanced: Fix a bug that caused widget icons to overlap on touchscreen devices.
- Advanced: Improve validation on custom widget creation
2023-04-18
- Dashboard: Add generator runtime in generator historical graph
2023-04-13
- Remote console: Fix bug remote console broken height on mobile.
2023-04-04
- Dashboard: Improve readability for dashboard tiles and add font smoothing.
2023-03-30
- Controls: Do not display controls that are not present anymore.
- Dashboard: Make the realtime indicator more reliable.
2023-03-29
- E-Mails: Add the email of the requesting user.
2023-03-28
- Android: Fix charge toggle is not visible when enabled on the EVCS widget
2023-03-23
- Advanced graphs: Fix range values were incorrectly calculated and displayed.
2023-03-16
- Alerts: Make the 'connection offline' notification dismissible for 5 minutes.
2023-03-13
- Production report: Operational run hours now shows how long inverters were powering the AC loads, and generator run hours shows the amount of time the generator was running.
2023-03-10
- Dashboard: Do not interpolate missing data for PV Inverter, AC Loads and Critical Loads.
2023-03-08
- Dashboard: Fix EVCS component covers status label
2023-03-03
- Custom widgets: increased the yAxis allowed range from 5000 to 500000
2023-03-02
- Historical data: Now also shows data about grid, shore and generator usage.
- Controls: Fix scrolling inside the drawer.
2023-02-28
- Custom widgets: Creating and editing custom widgets is now done on a separate page.
2023-02-24
- Settings: The user is now warned before removing his own full control over an installation.
- Settings: It is not possible to remove the last user with full control over an installation.
2023-02-22
- Login: Changing the language before login saves this as preferred language for the account.
- Alerts: Reduce the bottom spacing of alerts on mobile.
- Dashboard: Connect the EVCS tile to Critical loads.
- Advanced: Fix default y-axis max value race condition.
2023-02-21
- Modals: Fixed issue causing some modals to appear outside of the viewport.
- Dashboard: Prevent the page from scrolling when the controls are open.
- Installation users: Remove personal message required indication on invite.
2023-02-20
- Advanced: Fix tooltip sometimes not showing in all charts when hovering.
- Advanced: Only copy active widgets when duplicating a widget layout.
- Advanced: Fix bug causing original custom widget to be modified when editing a copy on a different installation.
- Advanced: Fix location and size of custom widgets without data not being saved correctly.
- Advanced: Added units to the dropdown of custom widget parameters.
2023-02-13
- Event logs: Event logs are now shown in installation timezone, rather than browser timezone.
- Internal: Add debouncing to state graph data fetching.
- Internal: Improve state graph data fetching performance.
2023-02-08
- Advanced: Change .xls data exports to .xlsx
- Internal: Improvements and optimisations in querying timeseries data.
2023-02-07
- Dashboard controls: Allow users to set the EVCS to “Scheduled charging” mode. (requires Venus OS version to be at least v2.93~2)
2023-01-31
- Custom widgets: Allow users to use decimal values for the lower and upper bounds of the scale.
2023-01-30
- Admin: Add pagination the search results on data attribute filtering.
2023-01-27
- Dashboard: Historical data graph now shows the right date and hour when in monthly interval. It also detects quick ranges when going forward with the arrow buttons after going backwards from a quick range.
- Reporting: Fix the style of the floating date picker.
- Advanced: Resolve duplicate attributes for custom widgets.
- What's new: What's new section blue badge does not appear again when deleting local or session storage.
2023-01-17
- Controls: Improved loading state showing more details about connection issues for inverter controls.
- Dashboard: Fix bug where date picker arrow buttons would become unclickable on mobile devices.
- Advanced: Fix the search function for advanced widgets and stop widget rearrangement.
2023-01-11
- Advanced: Stop the keyboard from hiding dropdown selection menus in custom widget creation or editing on mobile devices.
2023-01-03
- Event log: Fix bug causing incorrect state names to be used when switching ESS state.
- Firmware updates: Added support to detect custom firmware version mismatches for VE.Bus devices.
2023-01-01
- Styling: Fix bugs causing the colors in vrm to be wrong for some providers, which would cause graph colors to be different than their labels, and accent colors to not match in different parts of the website.
2022-12-30
- Android: Fix bug where status widget wouldn't show graph or would show it incredibly small after resizing
2022-12-29
- Historical data: Fix wrong date range shown in graph when “previous month” was selected
- Historical data: Fix additional day being shown when selected time range contained a daylight savings time change.
2022-12-21
- Venus OS Large: Show Node-RED link when it is in safe mode.
2022-12-19
- Firmware updates: Allow updating GX devices from VRM.
- Push notifications: Fix duplicated devices in the Other devices list.
2022-12-16
- Advanced: Removed bug causing a second tooltip showing “title” text to show up when hovering a chart in the Custom widget creating or editing modal
2022-12-12
- Installations: Fix map moving when hovering over one of the installations.
- Advanced: Set Y-axis for Humidity between 0 and 100.
2022-12-02
- The blue dot indicating there are new elements in the “What's new” in-app changelog now disappears after the changelog is opened rather than after every element has been viewed.
- Advanced: Modal for editing and creating custom widget will now be shown regardless of screen resolution
2022-12-01
- Add installation: Add Cerbo-S GX
- Installations: Apply filtering by tags to the map view of installations.
2022-11-28
- Controls: Improve Inverter controls by adding a loading state.
2022-11-24
- Advanced: Add GlobalLink summary and graph widget.
- Dashboard: Improve the alignment of the Controls icon.
2022-11-22
- Push notifications: Improve the design and text of the Preferences > Notifications screen.
- Push notifications: Fix edge case causing duplicated devices in the “Other devices” list.
2022-11-21
- Release Mobile and Web Push notifications.
- Firmware updates: Add support for VE.Bus BMS firmware files and update instructions.
2022-11-18
- Historical data: Fix page scrolling to the top when switching between Consumption and Solar.
2022-11-16
- Custom widgets: Show the custom device name in the legend of the widget.
- Historical data: Distinguish between Grid, Shore and generic AC input in the To/From tiles.
2022-11-10
- Custom widgets: Allow customising the Y-axis minimum, maximum and interval count.
- Historical data: Fix bug causing the data not be rendered correctly in the chart.
2022-11-07
- Add Polish language and translations.
2022-10-25
- Internal: Replace _old_ with _deleted_by_user_ for deleted installations.
- Internal: Add idUser to MQTT URL to help debugging.
2022-10-21
- Firmware Update: Fix incomplete serial numbers being logged.
2022-10-18
- Dashboard - Historical data: Add a new Generator tile and show in the chart generator data if it is available.
2022-10-17
- Installation: Fix filtering of installations after deselecting all the tags.
- Reporting: Fix the text color inside the report types cards for dark mode.
2022-10-13
- Event logs: Add new event types: accessing the Remote console and changes made using the controls from the dashboard (input limit, inverter/charger mode, EVCS mode, etc.)
- Event logs: Add actions performed by Victron admins.
- Event logs: Firmware update versions.
- Registration: Add link to the privacy policy document.
2022-10-10
- Preferences: Update the design of the language selection page.
2022-10-07
- Profile: Move Volume unit setting from Profile to Display preferences.
- Internal: Change MQTT headers.
2022-10-05
- Controls: Fix issue which caused the controls to be unavailable for certain relay configurations.
2022-10-04
- Add the Event logs screen to track and monitor important changes made to an installation.
2022-09-27
- Advanced: Add Alternator Speed and Drive widget.
2022-09-21
- Advanced: Add a button to view widgets in fullscreen.
- Dashboard: Improve temperature cards layout and alignment.
- Dashboard: Display Input Current Limit for MultiRS.
- Support new tank types: Gasoline, Diesel, LPG, LNG, Hydraulic oil, Raw water.
2022-09-20
- Location and Geofence: Improve Reset button styling.
2022-09-19
- Controls: Improve the time counters of the generator controls.
2022-09-16
- Remove HotJar analytics.
2022-09-13
- Improve the styling of the What's new modal and allow links.
2022-09-12
- Update links to documentation for adding installations and Node-Red.
2022-09-06
- Dashboard: Position the EVCS tile on input or output.
- Remote console: Fix error screen showing while the remote connection is being established.
- Custom widgets: Show custom widgets even when there is no data for the selected series and time period.
- Require 2FA when resetting the password.
- Internal: Move from Mandrill SDK to Mailchimp SDK for sending emails.
- Internal: Move from Twillio Authy for Twillio Verify for sending 2FA codes.
2022-09-05
- Add the Display preference menu.
- First day of the week used to be only Sunday. Now for all users, existing and new, the first day of the week is set automatically. Users can override the preferred first day of the week in the Display preferences menu.
2022-08-29
- Fix duplication of certain PV inverters in the Device list.
2022-08-23
- Make global announcements bar dismissible.
2022-08-22
- Dashboard: Correctly show PV inverters not wired through phase one.
- Dashboard: Add spark graph for certain PV inverters that did not have one yet.
2022-08-19
- Advanced: Fix solar charger summary widget when there is no data.
- Production report: Fix errors caused by invalid time periods selected. Improve error messages in case of failure or timeouts.
2022-08-17
- Patch the caching and version checking mechanism to work on older Safari browsers.
2022-08-16
- Improve the caching and version checking mechanism.
2022-08-13
- Custom widgets: Prevent y-axis labels from being truncated
- Add cross button to make alarm banners not be fixed at the top of the screen to prevent overlap.
2022-08-04
- Advanced: Fix Hours of AC in for VE.Bus summary widgets with different instance numbers.
- Installation overview: Hide the PAYGo column when no installations are PAYGo.
2022-08-01
- Add 2FA reset flow.
- Improve password policy requirements.
- Require password to update the email address.
- Prevent reusing TOTP tokens.
- Do not allow links in invitations.
2022-07-25
- Add the Ukrainian language and translations.
2022-07-22
- Installation overview: Add sorting installations by voltage and SoC.
- Dealers: Add whitelabels for SO Energy and Puredrive.
2022-07-12
- PAYGo: Add functionality for managing PAYGo installations and tokens in VRM.
2022-07-11
- Dashboard: Improve detailed values displaying on mobile.
- Alarm log: Improve columns width on mobile.
2022-07-08
- Alarm log: Add links to documentation for known alarm codes.
2022-07-01
- Dashboard: Add expandable ESS states to the Battery tile.
- Dashboard: Add MPPT details for Multi RS and Inverter RS.
2022-06-29
- ESS Controls: Design improvements.
2022-06-28
- Device List: Show L2 and L3 PV Inverter devices.
2022-06-21
- Advanced: Fix voltage unit for energy meters in graph legends.
- Advanced: Fix synchronised zooming for the Solar Charger Current widget.
2022-06-20
- Dashboard controls: Add control for EV Charging Station.
- Dashboard controls: Add generator control (requires Venus v2.90).
- Dashboard controls: Allow user to enable Inverter/Charger control from general settings.
- Dashboard controls: Display loading state of the controls.
- Advanced: Switch around Humidity and Pressure series to ensure color consistency.
2022-06-15
- Advanced: Fix calculated Solar Charger PV Current not being displayed sometimes.
- Advanced: Fix graphs showing “No data available” instead of rendering the actual data.
- Translations: Fix reloading english translations upon failure.
2022-06-13
- Dashboard: Improve battery temperature readings. Now the temperature is displayed for more system types that use different methods of reading temperatures.
2022-06-09
- Advanced: Add the ability to edit custom widgets.
- Advanced: Show device names in the custom widget legend.
2022-05-24
- Alarm log: Fix selecting the time range of an alarm when navigating to the Advanced page.
2022-05-23
- Activate Hotjar for web and mobile.
2022-05-17
- Controls: Change ESS translations and order.
2022-05-16
- Advanced: Add icon to custom widgets.
- Dashboard: Improve input limit tile styling.
2022-05-12
- Installation overview: Add a Total row to sum up the power from all installations in the overview.
2022-05-11
- Firmware Update: Change the firmware file format for EV Charging Station from .bin to .evcsup.
- Dashboard: Improve the update frequency of the values from the EV Charging Station tile.
- Improve overall buttons styling and consistency.
2022-05-09
- Advanced: Fix AC Meter showing the MPPT icon.
2022-05-04
- Advanced: Fix “Reset zoom” button not being visible for certain widgets.
- Dashboard: Fix EVCS status for multiple stations combined in one tile.
2022-05-03
- Dashboard: Hide the solar charger status “lollipop” when there is more than one solar charger.
- Prevent keyboard from showing on Android when interacting with dropdowns.
2022-04-29
- Dashboard: Change the design of the controls button.
2022-04-28
- Device list: Add icons for Alternator, DC Source and DC Load.
2022-04-25
- Device list: Allow to separately click on the remote LAN IP addresses.
- Advanced: Improve the grid of the temperature, humidity and pressure chart.
- Advanced: Switch around min and max cell voltage in the tooltip.
- Various styling improvements
2022-04-20
- Dashboard: Improve showing battery temperature for installation with multiple temperature sources.
- Advanced: Fix tag positioning in Firefox.
- Custom widgets: Improve creation modal size and position.
2022-04-19
- Device list: Fix delete device button when a device is expanded.
- Add installation: Add instructions and logic for GX devices requiring the WiFi MAC.
2022-04-15
- Advanced: The tooltip labels for state graphs on the advanced page stay within the graph.
- Dashboard: Make battery states translatable.
- Dashboard: Replace EVCS Max Charge Current with Total Energy.
- Redirect from the VRM landing page to the VRM product page.
2022-04-13
- Move the language settings under the new preferences menu.
2022-04-12
- Dark mode improvements: Safari notch color, modal headers, scroll bars.
- Improve loading translations for slow connections.
- Update translations for all languages
2022-04-10
2022-04-07
2022-04-01
2022-03-31
- Update translations.
2022-03-30
2022-03-23
2022-03-16
2022-03-15
2022-03-14
2022-03-11
2022-03-09
- Add dark mode.
- Add “Preferences” menu.
2022-03-09
2022-03-03
2022-02-25
2022-02-22
2022-02-21
2022-02-18
2022-02-08
2022-02-01
2022-01-31
2022-01-20
2022-01-18
2022-01-17
2022-01-12
2022-01-08
2022-01-07
2021-12-31
2021-12-29
2021-12-24
2021-12-23
2021-12-14
2021-12-13
2021-12-10
2021-12-08
2021-12-07
2021-12-01
2021-11-30
2021-11-29
2021-11-26
2021-11-25
2021-11-24
2021-11-23
2021-11-18
2021-11-16
2021-11-11
2021-11-08
2021-11-05
2021-11-04
2021-11-03
2021-10-19
2021-10-18
2021-10-11
2021-10-07
2021-10-04
2021-09-28
2021-09-27
2021-09-22
2021-09-21
2021-09-20
2021-09-15
2021-09-13
2021-09-08
2021-09-06
2021-08-23
2021-08-19
2021-08-17
2021-08-16
2021-07-05
- Updated translations
2021-06-30
- Improved security
2021-06-21
- Add dutch language option
2021-06-09
2021-05-20
2021–05-17
2021-05-14
2021-05-10
2021-05-03
- Update dutch translations
2021-04-19
2021-04-10
2021-04-09
2021-03-29
2021-03-21
2021-03-18
2021-03-12
2021-03-11
2021-03-08
- Update german translations
2021-03-06
2021-03-04
2021-03-03
2021-03-02
2021-03-01
2021-02-28
2021-02-26
2021-02-16
2021-02-15
2021-02-11
2021-02-10
2021-02-08
2021-02-05
2021-01-25
2021-01-18
2021-01-14
2021-01-13
2021-01-05
2021-01-02
2020-12-24
2020-12-10
2020-12-07
2020-12-04
2020-12-03
2020-11-30
2020-10-11
2020-10-02
2020-10-01
2020-09-29
2020-09-28
2020-09-25
2020-09-22
2020-09-21
2020-09-02
2020-08-21
- Add pulse meter support
2020-08-17
2020-07-29
2020-07-28
2020-07-27
2020-07-14
2020-07-13
2020-07-09
2020-07-07
2020-07-01
- Change PV inverter icon
2020-06-11
- Add fuel cell widgets
2020-05-12
2020-05-05
2020-04-27
2020-04-08
2020-03-18
2020-03-05
2020-03-02
2020-02-13
2020-01-31
2020-01-29
2020-01-17
2020-01-15
2020-01-13
2020-01-07
2019-12-20
2019-12-13
2019-12-12
2019-12-11
- Add altitude to GPS widgets
2019-12-10
2019-11-28
2019-11-21
2019-11-19
2019-11-14
2019-11-11
2019-11-06
2019-10-30
2019-10-25
2019-10-23
2019-09-18
2019-09-16
2019-09-02
2019-08-30
2019-08-27
2019-08-16
2019-08-14
2019-08-13
2019-08-09
2019-08-05
2019-08-02
2019-07-29
2019-07-08
- Added widgets for DC meter
2019-07-03
2019-07-02
2019-07-01
2019-06-27
2019-06-18
2019-06-17
2019-06-14
2019-06-12
2019-06-11
2019-06-06
2019-06-05
2019-06-04
2019-06-03
2019-05-22
2019-05-20
2019-05-17
2019-05-16
2019-05-14
2019-05-02
2019-05-01
2019-04-30
2019-04-25
2019-04-19
2019-04-15
2019-04-12
2019-03-29
2019-03-28
2019-03-21
2019-02-15
2019-01-29
2019-01-26
2019-01-21
2018-12-12
2018-12-10
2018-11-22
2018-10-26
- Renamed username to e-mail
2018-10-19
2018-10-17
2018-10-16
2018-09-28
2018-09-27
2018-09-11
2018-09-06
2018-09-05
- Added tank level widget
2018-09-04
2018-08-29
2018-08-24
2018-08-14
2018-08-03
2018-07-27
2018-07-16
2018-05-23
2018-05-22
2018-05-16
2018-04-19
2018-02-27
2018-02-13
2017-12-18
2017-11-13
2017-10-19
2017-10-04
2017-10-03
2017-09-15
2017-09-12
2017-09-07
2017-08-03
2017-08-02
2017-07-25
2017-07-20
2017-07-12
2017-06-28
2017-06-27
2017-06-19
2017-06-13
2017-06-07
2017-05-31
2017-05-16
2017-04-21
2017-04-13
2017-04-06
2017-03-31
2017-03-29
2017-03-28
2017-02-27
2017-02-15
2017-02-01
2017-01-25
2017-01-24
2017-01-23
2017-01-19
2017-01-18
2017-01-13
2017-01-12
2017-01-11
2017-01-10
2017-01-09
2017-01-06
2017-01-04
2017-01-03
2017-12-23
2016-12-22
2016-12-20
2016 Nov. - New VRM API
2016-09-09
2016-06-07
2016-06-06
2016-06-03
2016-05-11
2016-04-12
2016-03-31
2016-03-11
2016-03-07
2016-02-01
2016-01-15
2015-12-08
2015-12-04
2015-12-02
2015-11-30
2015-11-17
2015-10-30
2015-10-26
2015-10-23
2015-10-20
2015-10-19
2015-10-12
2015-09-22
2015-09-11
2015-09-08
2015-09-03
vrm_portal/change_log.1683878951.txt.gz · Last modified: (external edit)
