vrm_portal:change_log
VRM Portal changelog
2022-04-13
- Move the language settings under the new preferences menu.
2022-04-12
- Dark mode improvements: Safari notch color, modal headers, scroll bars.
- Improve loading translations for slow connections.
- Update translations for all languages
2022-04-10
2022-04-07
2022-04-01
2022-03-31
- Update translations.
2022-03-30
2022-03-23
2022-03-16
2022-03-15
2022-03-14
2022-03-11
2022-03-09
- Add dark mode.
- Add “Preferences” menu.
2022-03-09
2022-03-03
2022-02-25
2022-02-22
2022-02-21
2022-02-18
2022-02-08
2022-02-01
2022-01-31
2022-01-20
2022-01-18
2022-01-17
2022-01-12
2022-01-08
2022-01-07
2021-12-31
2021-12-29
2021-12-24
2021-12-23
2021-12-14
2021-12-13
2021-12-10
2021-12-08
2021-12-07
2021-12-01
2021-11-30
2021-11-29
2021-11-26
2021-11-25
2021-11-24
2021-11-23
2021-11-18
2021-11-16
2021-11-11
2021-11-08
2021-11-05
2021-11-04
2021-11-03
2021-10-19
2021-10-18
2021-10-11
2021-10-07
2021-10-04
2021-09-28
2021-09-27
2021-09-22
2021-09-21
2021-09-20
2021-09-15
2021-09-13
2021-09-08
2021-09-06
2021-08-23
2021-08-19
2021-08-17
2021-08-16
2021-07-05
- Updated translations
2021-06-30
- Improved security
2021-06-21
- Add dutch language option
2021-06-09
2021-05-20
2021–05-17
2021-05-14
2021-05-10
2021-05-03
- Update dutch translations
2021-04-19
2021-04-10
2021-04-09
2021-03-29
2021-03-21
2021-03-18
2021-03-12
2021-03-11
2021-03-08
- Update german translations
2021-03-06
2021-03-04
2021-03-03
2021-03-02
2021-03-01
2021-02-28
2021-02-26
2021-02-16
2021-02-15
2021-02-11
2021-02-10
2021-02-08
2021-02-05
2021-01-25
2021-01-18
2021-01-14
2021-01-13
2021-01-05
2021-01-02
2020-12-24
2020-12-10
2020-12-07
2020-12-04
2020-12-03
2020-11-30
2020-10-11
2020-10-02
2020-10-01
2020-09-29
2020-09-28
2020-09-25
2020-09-22
2020-09-21
2020-09-02
2020-08-21
- Add pulse meter support
2020-08-17
2020-07-29
2020-07-28
2020-07-27
2020-07-14
2020-07-13
2020-07-09
2020-07-07
2020-07-01
- Change PV inverter icon
2020-06-11
- Add fuel cell widgets
2020-05-12
2020-05-05
2020-04-27
2020-04-08
2020-03-18
2020-03-05
2020-03-02
2020-02-13
2020-01-31
2020-01-29
2020-01-17
2020-01-15
2020-01-13
2020-01-07
2019-12-20
2019-12-13
2019-12-12
2019-12-11
- Add altitude to GPS widgets
2019-12-10
2019-11-28
2019-11-21
2019-11-19
2019-11-14
2019-11-11
2019-11-06
2019-10-30
2019-10-25
2019-10-23
2019-09-18
2019-09-16
2019-09-02
2019-08-30
2019-08-27
2019-08-16
2019-08-14
2019-08-13
2019-08-09
2019-08-05
2019-08-02
2019-07-29
2019-07-08
- Added widgets for DC meter
2019-07-03
2019-07-02
2019-07-01
2019-06-27
2019-06-18
2019-06-17
2019-06-14
2019-06-12
2019-06-11
2019-06-06
2019-06-05
2019-06-04
2019-06-03
2019-05-22
2019-05-20
2019-05-17
2019-05-16
2019-05-14
2019-05-02
2019-05-01
2019-04-30
2019-04-25
2019-04-19
2019-04-15
2019-04-12
2019-03-29
2019-03-28
2019-03-21
2019-02-15
2019-01-29
2019-01-26
2019-01-21
2018-12-12
2018-12-10
2018-11-22
2018-10-26
- Renamed username to e-mail
2018-10-19
2018-10-17
2018-10-16
2018-09-28
2018-09-27
2018-09-11
2018-09-06
2018-09-05
- Added tank level widget
2018-09-04
2018-08-29
2018-08-24
2018-08-14
2018-08-03
2018-07-27
2018-07-16
2018-05-23
2018-05-22
2018-05-16
2018-04-19
2018-02-27
2018-02-13
2017-12-18
2017-11-13
2017-10-19
2017-10-04
2017-10-03
2017-09-15
2017-09-12
2017-09-07
2017-08-03
2017-08-02
2017-07-25
2017-07-20
2017-07-12
2017-06-28
2017-06-27
2017-06-19
2017-06-13
2017-06-07
2017-05-31
2017-05-16
2017-04-21
2017-04-13
2017-04-06
2017-03-31
2017-03-29
2017-03-28
2017-02-27
2017-02-15
2017-02-01
2017-01-25
2017-01-24
2017-01-23
2017-01-19
2017-01-18
2017-01-13
2017-01-12
2017-01-11
2017-01-10
2017-01-09
2017-01-06
2017-01-04
2017-01-03
2017-12-23
2016-12-22
2016-12-20
2016 Nov. - New VRM API
2016-09-09
2016-06-07
2016-06-06
2016-06-03
2016-05-11
2016-04-12
2016-03-31
2016-03-11
2016-03-07
2016-02-01
2016-01-15
2015-12-08
2015-12-04
2015-12-02
2015-11-30
2015-11-17
2015-10-30
2015-10-26
2015-10-23
2015-10-20
2015-10-19
2015-10-12
2015-09-22
2015-09-11
2015-09-08
2015-09-03
vrm_portal/change_log.1649850689.txt.gz · Last modified: 2022-04-13 13:51 (external edit)
