vrm_portal:change_log
vrm_portal:change_log [2026-04-14 13:20] aleximbvrm_portal:change_log [2026-05-06 11:58] (current) aleximb
 ====== VRM Portal Changelog ====== ====== VRM Portal Changelog ======
 +=== 2026-05-04 ===
 +  * Set Alarms: Wrap long usernames to prevent table layout breaking.
 +  * Command K: Fix issue with scroll on mobile.
 +  * DESS: Adding Sell & Buy price for energy graph.
 +  * Reporting: The reporting pages have been migrated to Vue 3 (excluding EVCS).
 +  * Advanced: Use the zoom range for data exports while zoomed in on charts.
 +  * Advanced: Add calculated parameters from 'standard widgets' in custom widgets.
 +  * Advanced: Add Power widgets per tracker for Multi RS.
 +=== 2026-05-04 ===
 +  * Event log: Fix severity icon now showing in light mode.
 +=== 2026-04-28 ===
 +  * Dashboard: Cache OpenWeather calls for 15 minutes to reduce usage.
 +  * Dashboard: Cache MapBox Geocoding based on coordinated to reduce usage.
 +  * Dashboard: Always start with the map boxes collapsed.
 +=== 2026-04-24 ===
 +  * Preferences: Fix an issue where SMS tokens were being sent when visiting the profile page
 +=== 2026-04-22 ===
 +  * Dashboard: Show how different energy sources contributing to my consumption.
 +  * Navigation (Notifications): Decrease size of text shown after accepting/declining a team invite
 +  * AI Agent: A multi-site agent page has been added
 +  * Dashboard: Improved the UI of the Show details element
 +  * Installation groups: Allow users to create microgrid installation groups
 +  * Forecasts & DESS: Allow users to adjust their consumption forecast on the live-feed chart
 +  * Advanced: Add Voltage and Current widgets per tracker for the Multi RS devices.
 +  * Remote console: Fix the keyboard not showing in Safari for iOS 26.4.1 or newer.
 +=== 2026-04-16 ===
 +   * Dashboard: Count Generator-coupled PV in Total solar
 +   * Dashboard & Advanced: Show Virtual EVs created from Node-RED
 === 2026-04-14 === === 2026-04-14 ===
    * Mobile: Fix graphs not loading for older iOS devices.    * Mobile: Fix graphs not loading for older iOS devices.
vrm_portal/change_log.1776165637.txt.gz · Last modified: by aleximb
