vrm_portal:change_log
VRM Portal Changelog
2026-04-14
- Mobile: Fix graphs not loading for older iOS devices.
2026-04-11
- Advanced: Add L2 & L3 data to 'System - Critical Loads' widget.
2026-04-08
- Navigation: Fix notifications badge positioning.
- Dashboard: Fix Solar Forecast tollorence + Display of it.
- Dashboard: Add logic that prevents unnecessary chart data queries on mobile dashboard and VC embed pages.
- Advanced: Add cell difference line in tooltip for BMS Min/Max Cell Voltage widgets.
- Firmware updates: Bring back 'waiting for reconfiguration' success message after VE.bus firmware update.
- Firmware updates: Remove rounding from progress.
2026-04-07
- Advanced: Fix 'apparent power' not showing range values while the slider is enabled.
2026-04-02
- Graphs: Fix issue where pre-Summer-Time ranges had wrong hours in graphs on dashboard and in the widgets
2026-04-01
- Dashboard: Fix Solar Forecast tolerance + Display of it
- Firmware updates: Round progress percentage to full number
2026-03-31
- Add Installation: Redirect to the user's site when it's already connected.
2026-03-27
- Firmware update: Added a missing translation to the Firmware update page.
- Preferences: Fixed an incorrect validation error in the MFA setup for SMS verification.
2026-03-20
- Garmin Watch APP: New release featuring switch controls, a new view with today's totals for a site, using totals for complications, as well as adding favorite site settings and complication site choosing to the APP settings menu
2026-03-19
- Changing Passwords: Change to realtime password validation & fix issue where missing a special character would not show a clear error.
2026-03-18
- Dashboard: system sizing installations now display separate energy meter cards in the VC embedded view instead of the legacy dashboard layout.
- Dashboard: all widgets now follow a consistent expandable behaviour and visual hierarchy to ensure key information is presented uniformly.
- Dashboard: users can now choose which temperature sensor or tank is displayed in the VC embedded dashboard view.
- Dashboard: EV card now shows the vehicle’s current street and city when location sharing is enabled, including a home indicator when at the installation location.
- Dashboard: air quality metrics such as CO2 and PM2.5 are now shown more prominently within the temperature card.
- Installation: unlink action is now disabled for installations managed via installation groups or teams, with clear guidance shown to the user.
- Teams: team details page has been migrated to newer framework.
- Teams: team overview page has been migrated to newer framework.
- Dashboard: add “Total energy” to the EVCS card in the alternative dashboard layout.
- OneID: Fix migrating account when a OneID account already exists, and the VRM account has a too weak password
2026-03-13
- Dynamic ESS Settings: Fix loop where configuration form goes back to the first step after completing the second step.
- Login: Fix Garmin watch login when logging in through OneID.
2026-03-10
- Login: Fix logins through OneID in the VRM app when on an ipad.
2026-03-04
- Version detection: Improve automatic version detection and reloading for the Vue 3 pages.
- Alarm log: Improve performance of sites with many alarms.
2026-03-03
- Venus OS Large: Remove unnecessary “Missing NodeRed” toaster when not running NodeRed
2026-02-28
- Notifications: Allow users to (re)subscribe to alarm notifications, e.g. after clicking the unsubscribe email in alarm emails.
2026-02-25
- Date Picker: Add `Recent and Upcoming` quickrange.
- Data Download: Deprecate old vrm-api based `/data-download` endpoint & direct users to use the new vrm-reports-api.
- Alarm Logs: Don't show an error toaster on empty alarmlog page.
- API Docs: Document installation-user management endpoints.
- API: Add attribute-exists validation to `/installation-data-attributes` endpoint.
- Tags API: Group tags by source & allow filtering on a specific tag source.
- Timezones: Synchronise VRM's timezone with the GX's timezone.
- Advanced: Add location history to GPS widget.
2026-02-20
- Fix issue on safari causing blank space when window width was right on the edge of mobile and desktop width
2026-02-12
- Dashboard: Change number formatting for Meterological sensor.
- Dashboard: Use Temperature sensor type for the name of the card if no custom name is set.
- Profile: Replace all phone inputs with the new phone input component.
- Notifications: Allow users to see, accept and reject installation access requests in the notifications popup.
- Data Download: Fix issues with partially filled columns.
2026-02-05
- Dashboard: Fix “This year” time range start date.
2026-02-04
- Home page: Added shortcut buttons to favorite installations for easy access to the Advanced and Device List pages.
- Advanced: In custom widgets with individual PV trackers, we now also show the custom name per tracker.
- Datepicker: Fixed an issue where you could not select custom dates in German.
2026-02-02
- [Admin] Firmware release: Fixed a Safari-specific layout issue in the Markdown editor.
2026-01-29
- Event Log: Show VRM Plus changes in the event log.
- VRM Warning: Improved the VRM warning design and added a new warning for users who reset their location while DESS is enabled.
- Datepicker: Fixed editing custom dates by typing in the textfield.
- Reports: New EVCS reports to track charging history and charging sessions.
2026-01-26
- Advanced: Added 'PV Yield Overview' widgets for Inverter, Inverter/Charger and Solar Charger
- Advanced: Fix the NOx axis going negative for the 'Air Quality` widget.
- Advanced: Fix `hours of AC in` on the VE.Bus Summary widget OOM error for large datasets.
2026-01-22
- Production Reports: Fix identifier sometimes being returned as int, breaking report generation.
- API: Clean up & improve performance for the `/installations` endpoint.
- API: Fix `/overallstats` endpoint sometimes timing out.
- Advanced: Fix x-axis disappearing after zooming.
2026-01-21
- Installation DESS settings: fix 500 error for some sites when calling the settings endpoint
- Invites: Improved invite acceptance errors by showing the specific failure reason from the API instead of a static error message
- Installation: Keep site location when replacing GX device
- Advanced: Add 'Battery Balancing Status' & 'Battery Smart Lithium Errors' widgets
- Remote Console: Fix missing close console button on small screens
2026-01-20
- Advanced: Fix AC Energy Summary not showing L3 power.
2026-01-15
- Navigation: Fix an issue causing middle mouse clicks to open duplicate tabs in some browsers.
2026-01-14
- Dashboard: Fixed an issue where AC Load details would not show up.
- General: Update the favicons to the new version.
- Navigation: Fix an issue where submenu would not update correctly on page change.
- Dashboard: Fix bug where live feed graph was missing Y-axis for future ranges, and “Last year” range was missing the “next” range.
- Command K: Allow users to switch between navigation and search mode in installation context.
- Remote Console: Fix bug where modal title was too dark in dark mode.
2026-01-09
- Device list: Show EV model and VIN in the details of the EV device.
2026-01-07
- Login: Improve user feedback when encountering issues during login
- Advanced: Move reset zoom button out of the active chart area and into the header
2026-01-05
- Advanced: Fix heat pump L3 power and frequency not showing.
2025-12-24
- Data Downloads: Only allow one generating one datadownload at a time.
- Advanced: Fix header padding bug on screen resize.
- Advanced: Add Heatpump widgets: voltage, current, and energy.
2025-12-23
- API: Cache devicetypes to reduce database load.
- API: Remove queries for non-existent attributes.
- API: Upgrade database abstraction layer.
- Reports: Improve generation time of data download export (advanced) & production report (installation overview).
2025-12-22
- Device List: Fix DC Generator not showing in the Device List.
2025-12-17
- Remote Console: Fix close button styling.
- Victron Connect: Fix authorising VictronConnect returning a URL-encoded email, leading to authentication issues.
2025-12-10
- Fleet Monitor: Hide offline sites from disconnected devices.
- Fleet Monitor: Add widget for offline sites.
2025-12-09
- Advanced: Add state widgets for MultiRS in general and for the individual trackers.
- Device list: Fix VRM reboot timeout not showing when reported as 0.
2025-12-03
- Dashboard: Add Apparent power to the Grid Meter Combined chart for system sizing layouts.
- Advanced: Add Apparent power tab for the Grid Meter Combined widget.
- Dashboard: Hide the minus sign when the temperature is 0 degrees.
- Dashboard: Reduce the size of the weather icons.
- Navigation: Auto hide the navigation bar, allow users to always hide it from Preferences, and various other UX improvements.
- Teams and Installation Groups: Fix to ensure the Members dropdown inside the “Link users” modal closes when users click outside the dropdown.
- API: Add an endpoint to show total usage of VRM
2025-12-02
- Recurring Reports: Fix error causing recurring reports to not generate.
2025-11-26
- API: Add `/v2/installation-data-attributes` endpoint to allow users & tools to query their sites by (multiple) data attributes.
- Remote Console: Improve fetching logic of the `New UI` to prevent unnecessary re-downloads.
2025-11-20
- Device list: Rename Motor Drive to E-drive and adjust icons.
- Dashboard: Various fixes of the EV card data formatting and display conditions.
2025-11-20
- API: Revert the changes done to the `live_feed` type on the `/stats` endpoint.
2025-11-19
- Widget AI: Allow adding the same widget to multiple sites.
- Remote Console: Add a new progress bar.
- Remote Console: Allow users to open NodeRED and SignalK from the remote console via VRM.
2025-11-14
2025-11-13
2025-11-12
2025-11-11
2025-11-06
2025-11-05
2025-10-30
2025-10-29
2025-10-23
2025-10-22
2025-10-20
2025-10-16
2025-10-09
2025-10-07
2025-10-06
2025-10-02
2025-10-01
2025-09-29
2025-09-25
2025-09-17
2025-09-12
2025-09-11
2025-09-10
2025-09-04
2025-09-03
2025-09-02
2025-08-28
2025-08-27
2025-08-22
2025-08-20
2025-08-18
2025-08-14
2025-08-13
2025-08-11
2025-08-06
2025-07-31
2025-07-30
2025-07-25
2025-07-23
2025-07-17
2025-07-16
2025-07-10
2025-07-09
2025-07-04
2025-07-03
2025-07-02
2025-07-01
2025-06-25
2025-06-24
2025-06-18
2025-06-17
2025-06-12
2025-06-11
2025-06-06
2025-06-05
2025-06-04
2025-06-03
2025-05-28
2025-05-26
2025-05-21
2025-05-17
2025-05-15
2025-05-14
2025-05-13
2025-05-12
2025-05-10
2025-05-08
2025-05-07
2025-05-06
2025-05-02
2025-05-01
2025-04-30
2025-04-24
2025-04-19
2025-04-18
2025-04-17
2025-04-16
2025-04-09
2025-04-07
2025-04-04
2025-04-03
2025-04-02
2025-03-29
2025-03-28
2025-03-27
2025-03-26
2025-03-21
2025-03-19
2025-03-12
2025-03-05
2025-03-04
2025-03-03
2025-02-26
2025-02-21
2025-02-19
2025-02-12
2025-02-05
2025-02-04
2025-02-01
2025-01-29
2025-01-23
2025-01-18
2025-01-16
2025-01-15
2025-01-13
2025-01-10
2025-01-08
2025-01-06
2025-01-02
vrm_portal/change_log.1776165637.txt.gz · Last modified: by aleximb
Add this page to your book
Manage book (
Help
