victronconnect:start
VictronConnect manual
1. Introduction
Welcome to the VictronConnect Manual. Use the VictronConnect App to configure, monitor, update and diagnose the VictronConnect compatible products.
VictronConnect is available for Android, iOS, Windows, and macOS X.
It can connect to Victron products via Bluetooth, USB and WiFi/LAN/Internet. How to connect depends on the product, some product ranges have Bluetooth, some do not. Some product ranges have WiFi, others do not. For details, see chapter 11.
Documentation
See the table of contents for all general VictronConnect information covered in this document.
Other product specific relevant documents are:
- Specific documentation for MPPT Solar Chargers.
- VE.Bus Configuration for MultiPlusses, Quattros, EasySolars and other inverter/chargers.
2. Download and installation
VictronConnect is available to users of Windows PCs, macOS X, iOS and Android phones, as well as tablets. Use this link to download the app suitable for your device.
Also, it is available for Linux - though not officially supported.
See chapter 4 for details regarding compatible phones, tables and laptops, as well as required minimum Operating System versions.
3. Connecting
There are three ways to connect to a Victron product:
Method iOS Android Windows PC macOS X
Products with built-in Bluetooth Yes Yes No Yes
VE.Direct Bluetooth Smart dongle Yes Yes No Yes
VE.Direct USB interface No Yes (1) Yes Yes
(1) Requires a USB On-The-Go cable. These cables are available in mobile phone and phone-repair shops, as well as on the internet.
Use the Compatible Victron products chapter to verify that your product is compatible.
3.1 Bluetooth Smart - Pairing and Connecting
To connect to your Victron product, over Bluetooth, always connect from within VictronConnect. Do not connect from the device's system menu because VictronConnect will not find your Victron product.
Here is how to connect:
  1. Enable the Bluetooth on your phone, tablet or laptop (device).
  2. Open VictronConnect, and scan:
    1. On a phone or tablet, pull down the screen, or tap the refresh button to initiate a scan.
    2. On a computer or laptop: click the “Scan or Refresh” button on the left.
  3. The first time you attempt to connect the phone will ask to pair with the device. Enter the pin code. The default pin code is 000000
  4. Connection is complete.
If connection was not successful please refer to section 9. Troubleshooting below.
3.2 Bluetooth Smart - Changing the PIN code
To prevent unauthorised connections to your device we recommend you change the PIN code. Avoid using obvious PIN codes such as 111111 or 123456.
To change the PIN code, first complete your connection. Then go to the Product info page. To access that page, click the button on the upper right. For some products it will be the settings icon: . After opening that menu press , and click Product info.
For other products you'll find the button on the upper right, which takes you straight to the Product info page.
On this page, select the change pin code button.
Note that after changing the pin code, all other phones, tablets, and laptops connected to the Victron product need to have their pairing information refreshed; and first, the old pairing information needs to be removed. See section 3.4 to learn how to remove the pairing information.
3.3 Bluetooth Smart - Resetting the PIN code
If the PIN code is lost, it can be reset to 000000. The way you reset depends on which product you are using:
Reset the PIN code by pressing and holding the 'Clear PIN' button. After holding the button for 5 seconds, both LEDs will blink twice. This indicates that the PIN code has been reset.
Blue Smart Chargers IP65
Reset the PIN code by pressing and holding the 'Mode' button on the charger. After holding the button for 10 seconds, all blue LEDs will blink twice. This indicates that the PIN code has been reset.
Blue Smart Chargers IP22
On the device list: tap or click the three-dots menu on the right side of the product description. A menu will pop up offering a 'Reset PIN code' option. Click that, and enter the PUK code. The PUK code can be found on the product label, on the back of the product.
It can also be done on the charger itself:
Blue Smart Chargers IP67
Smart Solar Charger
BMV-712 Smart
Smart LiFePO4 Batteries
SmartShunts
3.4 Bluetooth Smart - Removing from the list of paired devices
You may want or need to remove a product from the list of Bluetooth paired devices on your phone/tablet/laptop. For example, if the PIN code of your product has been changed on a different device.
To remove the pairing information you will need to go to your device's Bluetooth settings. Watch the videos below to learn how to remove the pairing information from iOS and Android devices:
Remove Bluetooth pairing on iOS devices:
(click to play, double-click to enter fullscreen mode)
Remove Bluetooth pairing on Android devices:
4. Phone, tablet and laptop compatibility
4.1 Windows PC
VictronConnect requires Windows 7, Windows 8 or Windows 10. For older Windows versions, XP and Vista, check our archive of previous versions.
Note that on Windows, VictronConnect cannot use Bluetooth Smart to connect to a product. Other connection methods, is USB, or LAN and WiFi do work properly.
4.2 macOS X
Todays version of VictronConnect requires macOS version is 10.12 (OS X Sierra), or later.
For the older macOS 10.11/10.10/10.9 versions, an (unsupported) previous version of VictronConnect is still available in the Apple Store.
To connect to a Victron product with Bluetooth, the Apple Laptop needs to have Bluetooth 4.0 aka Bluetooth Smart.
4.3 Android devices
Android 5.0 is the minimum version required to run VictronConnect.
An older version of VictronConnect that works for some users of Android 4.3 and 4.4 is still available in archive – but unsupported.
The required hardware is ARMv7 and later, as well as x86 or ARM64bit.
Notes for Android 5
Android 5 devices with a 64bit CPU will experience a crash at startup due to an issue in the libraries we use to develop VictronConnect. This is not expected to be fixed. A workaround for this issue is to manually install the VictronConnect APK that can be downloaded in the software section.
The pairing does not work on some devices running Android 5. The pin code popup does not appear, or it appears without a text field to enter the PIN code. If you have this situation on your device, the phone/tablet might report that it has been paired with the Victron product - but it has not.
Unfortunately this is a bug in Android over which we have no control, and are therefore unable to fix.
Devices where we have seen this issue are:
  • Asus Zenfone 2 with 5.0 ← Android 6 is available, update the phone to solve the issue
  • Motorola Moto G 2 ← Android 6 is available, update the phone to solve the issue
  • Medion tablet with Android 5.0
Notes for Android 6 and later
No known issues, when Access to Locations services are enabled.
Why is Access to location services required?
Android 5 and later requires access permission for VictronConnect to the (coarse) location services. Otherwise it can not scan for the Bluetooth devices.
Besides permitting access to its data, the location services also need to be enabled in many (but not all) cases.
Note that after enabling location services, the GPS itself, can be switched off again: the Android location services are more than GPS. Bluetooth, and WiFi-, scan results can technically also be used to approximate the devices location; hence these requirements.
Despite above, you can be sure that Victron is not interested in, nor tracking your location.
Being sensitive to privacy issues at Victron ourselves, we are not happy with this requirement. But there is nothing we can do about it unfortunately. More information about why its needed to enable the location services is here.
List of known non-compatible Android devices
Manufacturer Model USB OTG Bluetooth Smart
HTC One+ ? No
HTC One M7 ? No
Huawei P8 Lite (2015) No Only if location services are disabled
Lenovo Tab 3 A7 ? No
Samsung Galaxy S3 Mini No No
Samsung Galaxy S2 Yes No
ZTE Telstra Max ? No
List of known compatible Android devices
We have tested the following Android devices and can confirm that they are compatible with VictronConnect*:
Google Nexus 6P; LG G4; Sony Xperia Z5; HTC One M9; HTC One S9; OnePlus 3T; Asus Zenfone 2; Samsung Galaxy S5; Samsung Galaxy S5 mini; Samsung Galaxy S7; Samsung Galaxy S8; Samsung Galaxy Tab E 9.6.
*Assumes the device runs the latest firmware released by the manufacturer.
4.4 Apple iOS iPhones and iPads
VictronConnect works on the following iPhones and iPads running iOS 11 or later:
  • iPhone 5S and later.
  • iPad mini 2 and later
  • iPad (5th generation) and later
  • iPod touch (6th generation) and later
Unfortunately Apple iPhone/iPad doesn't support USB OTG.
4.5 Linux
Details here.
4.6 Archive of previous versions
It would be nice to forever support all existing versions of Android, iOS, Windows and other systems. But unfortunately its impossible to do so. Therefore, now and then, a new release of VictronConnect doesn't work any more on your device; whereas the previous version worked perfectly.
In such situation, we recommend to update your phone/laptop to the latest OS. For situations where that is not possible we make these older versions available:
Warning: These versions are no longer supported or recommended to use by Victron, only use it as a last resort if you don't have access to a compatible device with the latest VictronConnect release version. Under the download link find the last available VictronConnect version that still works on those older operating systems.
OS Version Download link
Windows XP and Windows Vista VictronConnect 3.3
Android 4.3 to 4.4.4 armv7 architecture VictronConnect 5.8
Android 4.3 to 4.4.4 x86 architecture VictronConnect 5.8
macOS 10.9 (OS X Mavericks) VictronConnect 3.2
macOS 10.10, 10.11 & 10.12 (OS X Yosemite / Sierra) VictronConnect 5.8
5. Application overview
5.1 Screenshots (click to enlarge)
Device list
LOCAL - This page shows all the Victron products that have been discovered by your device, and to which a connection can be made. Click on the desired product.
VictronConnect - Device List - LOCAL
VRM - This page will show a GX device if it is connected to your VRM account.
VictronConnect - Device List - VRM
Battery Monitor pages:
Clicking on 'Battery Monitor' will show the current state of charge; and allows you to toggle between screens showing more detailed information concerning the current battery STATUS, and HISTORY data.
  • To access 'Settings' click on the cog icon at the top right of the screen.
From 'Settings' you can change the data concerning your battery storage; set alarms and relays; change charging parameters; tailor the appearance and quantity of data displayed and set up or join an existing VE.Smart network.
VictronConnect - BMV VictronConnect - BMV history VictronConnect - BMV settings VictronConnect - BMV relay settings VictronConnect - BMV alarm settings VictronConnect - BMV display settings VictronConnect - BMV misc settings VictronConnect - BMV networking settings
Solar Charge Controller pages
Clicking on your Solar Charge Controller product allows you to view the current charging status.
'Settings' will allow access to the extensive range of functions available on your solar charge controller, including: programming the charge settings; initiating relays which are triggered by solar time, or by voltage parameters; together with comprehensive history analysis.
For a full explanation of the Solar Charge Controller options follow this link.
VictronConnect - MPPT VictronConnect - MPPT settings VictronConnect - MPPT battery settings VictronConnect - MPPT load output settings VictronConnect - MPPT Relay settings VictronConnect - MPPT streetlight settings VictronConnect - MPPT TX port settings settings VictronConnect - MPPT Networking settings VictronConnect - MPPT history
Phoenix Inverter pages
Clicking on the Phoenix Inverter allows you to view dynamic data such as power-draw of connected loads; a power bar will show how hard your inverter is working; and you will find information such as battery voltage etc.
'Settings' will allow you to set output voltages/frequency; set low voltage shut-downs, and restarts - together with their alarms; set a dynamic cut-off - based on load; together with other setting about which more information can be found here.
 VictronConnect - Phoenix inverter  VictronConnect - Phoenix inverter settings  VictronConnect - Phoenix inverter settings
Blue Smart IP65 charger pages
The Blue Smart IP65 battery charger comes with Bluetooth already built in. When the Blue Smart charger is powered-up it will be discoverable using the VictronConnect app on your device. (Except Windows PC - See 3.1 Windows PC, above).
The 'home' page shows information about the battery voltage, charge current, and where your battery is in the charging-cycle.
From here you can choose a preset charge algorithm, you can select the charge current; and you can choose to employ the charge algorithm for a Li-ion battery when that is appropriate.
 Blue smart IP65 charger  Blue smart IP65 charger history information  Blue smart IP65 charger settings
Lithium Batteries Smart
Lithium Batteries Smart have Bluetooth built-in. Clicking on the Lithium battery from the Device list will allow you to view live data about the battery status, voltage and temperature. You will also see the voltage of each cell - which is an essential guide to battery health.
From 'Settings' you can change discharge and temperature parameters.
 VictronConnect - Lithium batteryies smart  VictronConnect - Lithium batteryies smart settings page  VictronConnect - Lithium batteryies smart temperature screen
Peak Power Pack
Windows
Here is a VictronConnect app screenshot from a device using a version of the Microsoft Windows operating system showing information from an MPPT.
macOS X
Here is a VictronConnect app screenshot from a device running the Mac Operating System showing information from an MPPT.
5.2 Videos
**Blue Smart IP65 Charger **
This video will show you how to download the VictronConnect app onto a smart phone (in the video we use an iPhone). It will also show you how to use the app to view information and control the settings of a Blue Smart IP65 charger.
BlueSolar MPPT
This video will show you how to download the VictronConnect app onto a smart phone (in the video we use an iPhone). It will also show you how to use the app to view Live Data and historical information from your Victron MPPT Solar Charge Controller. A full description of all the settings available on our Solar Charge Controllers can be found on this page.
5.3 Renaming your devices
It is possible to change the name of your devices to make identification easier. This is especially useful if you have multiple devices, such as 3 MPPTs and 2 BMVs. It is not yet possible to change the name of Smart Lithium batteries. This will be available in the future.
To change the name: First complete your connection; then go to the Product info page. To access that page, click the button on the upper right. For some products it will be the settings icon: . After opening that menu press , and click Product info.
Go to the Custom Name option, and select Edit and Done.
5.4 How to disable and re-enable Bluetooth
All our products that have Bluetooth built-in, have a feature that allows disabling Bluetooth. Typically the reason for doing so is security, even though the Bluetooth connection is protected by a PINcode, there is nothing more secure than disabling it.
In most cases, it's also possible to re-enable Bluetooth after disabling. For example by using a VE.Direct cable.
There are, however, a few exceptions:
Finding the Bluetooth menu
First complete your connection; then go to the Product info page by clicking the button on the upper right:
  • For some products, it will be the settings icon: . After opening that menu press , and click Product info.
  • For other products you'll find the button on the upper right, which takes you straight to the Product info page.
If the product has the feature that Bluetooth can be disabled, you will see the field “Bluetooth” with a switch button next to the text “Bluetooth enabled”. Toggle the switch to off, the button will turn from light-blue to grey and a dialogue will be displayed to confirm your action. If you choose to “Cancel” the change Bluetooth will remain on and the switch button and text will return the “Bluetooth enabled” position.
For some products a Disable button is shown instead of a toggle switch.
How to re-enable Bluetooth
Warning: This section does not apply to the Lithium Smart batteries. Bluetooth cannot be re-enabled on the Lithium Smart batteries.
There are a few different ways to re-enable Bluetooth depending on your product, always check the manual of your product for more detailed instructions:
Re-enable Bluetooth using VE.Direct
Connect the product with a VE.Direct to USB cable to your PC or Android device and use VictronConnect to re-enable Bluetooth in the Product Info page (see here on how to reach the Product info page).
Re-enable Bluetooth using the MODE button on the product
Press and hold the MODE button on the product for 10 seconds will perform a Bluetooth reset. This means that the following actions will be executed:
The product page can be found here.
Once Bluetooth is disabled, it is disabled permanently and is irreversible. This means that VictronConnect will ask for a confirmation code displayed in the dialogue; if you are sure that you want to permanently disable Bluetooth, enter the code displayed and choose “Ok”.
Phoenix Smart IP43 Chargers
Once Bluetooth is disabled, there are multiple ways to re-enable it again:
  1. Using the MODE button
  2. Using a VE.Direct to USB cable to your PC or Android device
Blue Smart IP22 Chargers
The product page for can be found here.
Once Bluetooth is disabled, it can be re-enabled with the MODE button.
Blue Smart IP65 Chargers
Blue Smart IP67 Chargers
For these chargers there are two options:
  • Disable Bluetooth permanently. This option is irreversible and VictronConnect will ask for a confirmation code displayed in the dialogue; if you are sure that you want to permanently disable Bluetooth, enter the code displayed and choose “Ok”.
  • Enable Bluetooth for 30 seconds at power-up. This allows you connect to the product and to perform a firmware update or re-enable Bluetooth. If you do not connect within the first 30 seconds Bluetooth will be disabled.
SmartSolar MPPTs
Bluetooth can be re-enabled by connecting a VE.Direct to USB cable to your PC or Android device and follow these instructions.
Smart Battery Protect
Bluetooth can be disabled/re-enabled by connecting the PROG pin to ground and selecting F (enable) or h (disable). Check the product manual for more details.
Smart BMV-712
The BMV-712's on-board Bluetooth module can be turned on or off through the settings menu (setting #71). Check the product manual for more details.
Smart BMS
Bluetooth is temporarily enabled at power-up for 30 seconds. You can connect within these 30 seconds to perform a firmware update or re-enable Bluetooth. If you do not connect within the first 30 seconds Bluetooth will be disabled.
Smart Shunt
5.5 Importing and converting a GX Product Family database File
VictronConnect for Mac OSX and Windows allows you to import and convert the database log file (that is created by the VenusOS on the GX Product Family of devices) to a Microsoft Excel XLSX file. This can be useful if the site is remote and without an internet connection to upload the file to the VRM Portal.
This feature is not available in the iOS and Android mobile versions of VictronConnect.
6. Product alarms & errors
Behind the scenes VictronConnect has a full monitoring system which checks for alarms and errors on the connected product. As soon as an alarm or error is reported by the product, the alarm/error and its description is shown on the live data page.
(Note that alarms and errors are only shown when the app is active.)
7. Settings files
7.1 Save, load, share and manage settings
This feature allows you to save product settings to a file so that they can be loaded onto the Victron product you are connected to …or another product, at a later time.
** Save settings **
Connect your device to the Victron product, go to the 'Settings' page and click on the floppy disc icon .
** Load settings **
Connect your device to the Victron product, go to the 'Settings' page and click load icon , and then select a file from the list.
When the file is loaded, the changes are not immediately be applied to make it possible to review them first. The differences between the product's current settings, and the new settings contained in the loaded file, will be marked-up in orange.
Once you have reviewed them, click 'Apply' …or you may choose to 'Discard' them.
** Share settings **
The 'Share settings' feature allows you to share the current product settings with other products, using your device. Also, settings you have already saved using VictronConnect are stored in a settings file and can be shared with other products through the 'Settings file manager'.
** Settings file manager **
The Settings file manager is located in the main menu, and shows all stored settings:
From here files can be opened, shared or removed:
7.2 Settings files and the demo library
The demo library can be a great tool for an installer to create a set of settings, and then share it to a customer whom can then apply it to their product.
Note that whilst saving settings from the demo library is possible, loading settings from within the demo library is not possible.
7.3 Limitation in opening older settings files
There are two methods to open a previously stored settings-file:
  1. From the settings file manager, as in above screenshot, to see the settings without having to be connected to the product. A snapshot of all data, including voltage readings, history data, and so forth, will be loaded and visible to inspect.
  2. From the product settings pages, only possible when connected to a product.
Note that the first method only works when the settings file is created with the exact same VictronConnect version that as used to store the file. To open a file made longer ago, use the second method: connect the same product, and then load the settings.
8. Demo feature
VictronConnect contains a library with demonstration settings for all the supported products.
The demo feature can be used to:
  • Learn about the settings which are available on your Victron product. By exploring the library's example-settings you will discover the full capability of your product.
  • Create a specific product setup, save it …and then send it to a customer so that they have those settings on their device, and can install them on their Victron product.
  • Besides loading products from the standard library, it is also possible to load them from a saved file using the 'Settings file manager'.
  • Review settings made to your installations, make changes, and then send them to whoever is on-site so that they can apply them.
** Loading demos **
The Demo library can be accessed through the main menu.
To load a saved settings file as a demo, go to the 'Settings file manager', click on the file menu button, and select “Open”.
9. Firmware updates
9.1 Introduction & automatic updates
What about updating Firmware on VE.Bus devices such as MultiPlus and Quattro?
Please follow this seperate Firmware guide for updating products such as MultiPlus and Quattro that use a VE.Bus connection via an MK3-USB adaptor, instead of VE.direct or Bluetooth.
How can I see what firmware version is available?
Connect to the product: VictronConnect will prompt to update in case there is a new version available.
Or, when not close to the product, open the Demo library and select the product. The Product info page will show the latest available version that is shipped with VictronConnect.
Do I need to be connected to the internet for updating firmware?
No. Updating firmware does not require an internet connection, the latest Firmware files are already loaded inside VictronConnect, on your phone/tablet/laptop. When updating the app, all firmware files are updated as well automatically.
How does it work?
After connecting your product, VictronConnect will automatically check whether your product is running on the latest firmware version. If there is a newer version, you will be guided through the update procedure before doing anything else.
A firmware update - when available - will need to be completed in order to continue using VictronConnect.
Will I need to reconfigure my MPPT or BMV after the update?
No. The settings of your VE.direct and Bluetooth products will not be affected by the firmware update …and so you will not need to reconfigure your product after the update. Also, the History data of BMVs and MPPTs will be preserved throughout a firmware update.
9.2 Updating to a self-supplied firmware file
The previous chapter explained how VictronConnect will automatically update to the latest recommended firmware version. Besides that, it is also possible to update a product with a file that you supply your-self.
This is not needed very often. Some reasons to do so could be:
  • Update to a very recent version, thats already available on Victron Professional but not yet shipped with VictronConnect. Note that instead of going throught this effort, you can also wait a bit longer, for a new version of VictronConnect to be released.
  • Update a product to a special version, such as the required to disable Bluetooth in the Lithium batteries. See the files in Victron Professional for more information about that.
Instructions for Windows and MacOS computers
With your device and Victron product paired via VictronConnect, go to the “Product info” page, click on “Update” and open the correct firmware file.
Instructions for Android and iOS phones and tablets
Due to limitations on a mobile device the process is slightly different from the Windows/MacOS routine.
Firstly, you need to add the desired firmware file to the VictronConnect firmware library. Firmware files can be added to the library from: an email attachment; web browser; Dropbox; file browser …and any kind of app that can handle files.
Note for iOS: The current version of Google Chrome for iOS fails to download “.dup” files from the Victron Professional website - so we recommended using Safari instead.
Note for Android: VictronConnect needs to be running before opening files. Open VictronConnect and, without closing it, switch to the app containing the file, select it and choose to open it with VictronConnect.
On both iOS and Android, go to the app that contains the firmware file, tap on it, and open it with VictronConnect.
VictronConnect will be opened and should read: “File added to the firmware library”. If the message doesn't appear, repeat the previous step.
Go to the “Product info” page and tap on “Update firmware”.
Select the desired file from the list.
The update mechanism will detect-and-reject firmware files which are not targeted for the current product - but we strongly recommend that you only attempt to load files with the “Show only compatible firmware” option enabled.
Once selected you will be guided through the update process.
9.3 Troubleshooting firmware updates
A troubleshooting guide relevant to firmware updates can be found in chapter 11.3
9.4 Error codes
In spite of our painstaking efforts, sometimes errors occur. But don't worry, it is always possible to recover your product.
In most cases, errors are caused by communication problems. Always make sure to check all cable connections and, if you are using Bluetooth, stay as close to the product as possible and check that the Bluetooth function is enabled on your phone/tablet/laptop. Sometimes you may need to remove the Bluetooth pairing information from your device in order to be able to reconnect with your product.
In the following list, you can check possible errors and descriptions.
Check chapter 10.3 of this manual for Troubleshooting firmware updates. When asking for help, make sure to always mention the error code.
VE.Direct products
Error Description
D3 No VE.Direct product(s) found.
D4 Unknown error occurred. Try again and check the product settings once updated.
D10 Error closing com port.
D20 Could not start updating, no updatable product found.
D26 Updating failed, communication lost. The product might be unusable. Check connection and power supply.
D29 Could not start updating, the firmware file is corrupt.
D31 Updating failed, the product is unusable. Try again and check the product settings once updated.
D32 Could not start updating, entering boot mode failed.
D33 Could not start updating, the firmware file is not found.
D90 Could not start updating, the firmware is not for this product.
D91 Could not start updating, an unknown product was found.
D92 Updating failed, erasing firmware failed. The product might be unusable. Try again and check the product settings once updated.
D93 Error starting firmware after updating. Power cycle (off/on) your product and if that does not help
try updating again, and check the product settings once updated.
D94 Product updated successfully, but an error occurred reading the previous settings. Check the product settings.
D95 Product updated successfully, but an error occurred restoring the previous settings. Check the product settings.
D96 Updating failed due to version mismatch. Power cycle (off/on) your product and if that does not help try
D97 Dup executable too old.
D98 Firmware file is not a valid dup file.
D99 Product updated successfully, but an error occurred restoring the settings. Check the product settings.
D100 Cannot migrate settings because the application is not active. Manual action required.
** Blue Smart Charger, SmartLithium, and VE.Direct Bluetooth Smart dongle **
Error Description
B1 Error reading file.
B2 Victron BLE service not found. Please remove the product from the list of paired devices and retry.
B3 Dfu BLE service not found. Please remove the product from the list of paired devices and retry.
B4 The product disconnected unexpectedly. Perhaps the bond information is no longer valid? Please remove
B5 A write to the device failed.
B6 The product did not activate its bootloader - although it should have.
B7 The product did not disconnect - although it should.
B8 Timeout waiting for access to the Victron BLE service.
B9 Timeout waiting for access to the Dfu BLE service.
B10 Timeout waiting for a response.
B11 Timeout while writing to the product. Perhaps a pairing dialogue is shown? Please retry.
B12 Device was no longer found. Perhaps out of range? Please retry.
B96 An internal error occurred (Opcode not supported). Please send a service report to Victron Energy.
B97 The requested encryption is not supported by the product. Please send a service report to Victron Energy.
B98 An internal error occurred (Data size exceeds limits). Please send a service report to Victron Energy.
B99 The product could not store the firmware in its memory. Please retry, and if the problem persists, please contact Victron Energy.
B100 An internal error occurred (CRC error). Please send a service report to Victron Energy.
B101 An internal error occurred (Data length error). Please send a service report to Victron Energy.
B102 An internal error occurred (Not allowed). Please send a service report to Victron Energy.
** VE.Bus Products **
Error Description
V2 No product detected. Please check all the cable connections and try again.
V3 An unexpected timeout was triggered. Please check all the cable connections and try again.
V4 Incomplete vff file. Nonce missing. Please make sure you selected a valid update file and try again.
V5 Incomplete vff file. EEPROM lines missing. Please make sure you selected a valid update file and try again.
V6 The vff file contains more eeprom data than supported. Please make sure you selected a valid update file and try again.
V7 The calibration map in the file exceeds the device calibration map. Please make sure you selected a valid update file and try again.
V8 Device calibration data size bigger than expected. Please make sure you selected a valid update file and try again.
V9 Bootloader did not respond to bootloader setup. Please check all the cable connections and try again.
V10 Bootloader response to version request failed.
V11 Incompatible bootblock. Function version invalid.
V12 Incompatible bootblock. Version invalid.
V13 Bootloader did not start after bootblock update.
V14 Incompatible bootblock type.
V15 No or unexpected response to target id query.
V16 No or unexpected response to eeprom read action.
V17 No or unexpected response to calibration map query.
V18 The supplied firmware contains new unsupported calibration values.
The updater does not know how to handle them.
V19 No response received to eeprom write command. Please check all the cable connections and try again.
V20 Invalid response received to eeprom write command. Please check all the cable connections and try again.
V21 No response received to code write command. Please check all the cable connections and try again.
V22 Invalid response received to code write command.
V23 The MK2/MK3 did not respond. Please check all the cable connections and try again.
V24 The connected product does not match the specified model in the file.
V25 The hardware revision specific eeprom defaults data is corrupt.
V26 Updates can not be performed with a VEBUS BMS connected.
V27 Updates can not be performed with a DMC connected.
V40 Failed to start Update. could not allocate memory. Malloc error.
V50 Failed to start Update. File open error. Please check the file location and access permissions.
Make sure you selected a valid update file and try again.
V51 Failed to start Update. File write error. Please check file location and access permissions.
V52 Failed to start Update. File read error. Please check file location and access permissions.
V53 Failed to start Update. File checksum error. File corrupted or not a valid VFF file.
V54 Failed to start Update. File has an incompatible version number.
V55 Failed to start Update. File section not found. File corrupted or not a valid VFF file.
V56 Failed to start Update. Format error. File corrupted or not a valid VFF file.
** All other products (XUP update files)**
Error Description
X3 Invalid updater state. Please try again.
X4 Firmware not for Product (Id). Please make sure you selected a valid update file and try again.
X5 Updater (version) too old.
X6 Communication Error. No Callback handler connected. Please check the connection and try again.
X7 Communication Error. Vreg ack-ed with an unexpected error. Please check the connection and try again.
X8 Update (xup) file format not supported. Please make sure you selected a valid update file and try again.
X9 File Error. No Instance Blob could be found in the update file. Please make sure you selected a valid update file and try again.
X10 File Error. Invalid instance Blob attribute. Please make sure you selected a valid update file and try again.
X11 File Error. Instance Blob defined more than once. Please make sure you selected a valid update file and try again.
X12 File Error. No Firmware Version for instance found in the update file. Please make sure you selected a valid update file and try again.
X13 Communication Error. Unexpected Vreg Ack received. Please check the connection and try again.
X14 Communication Error. The instance could not be reached. Please check the connection and try again.
X15 Fail on Minimum Firmware Version check. Please make sure you selected a valid update file and try again.
X16 Failed to Begin Update. Please check the connection and try again.
X17 File Error. No/invalid Firmware data found for instance in the update file. Please make sure you selected a valid update file and try again.
X18 Update Error. Invalid ack on non-final Update Data. Please check the connection and try again.
X19 Update Error. Invalid sequence# in Update Data Ack. Please check the connection and try again.
X20 Update Error. Invalid instance# in Update Data Ack. Please check the connection and try again.
X21 Update Error. Invalid ack on final Update Data. Please check the connection and try again.
X22 Verification Error. Invalid Firmware Version Ack. Please check the connection and try again.
X23 Verification Error. Invalid UDF Version Ack. Please check the connection and try again.
X24 Verification Error. Invalid instance field in Minimum Firmware Version Ack. Please check the connection and try again.
X25 Verification Error. Invalid instance field in Firmware Version Ack. Please check the connection and try again.
X26 Verification Error. Invalid instance field in UDF Version Ack.
X27 Failed to verify Minimum Firmware Version.
X28 Failed to verify Firmware Version. Please check the connection and try again.
X29 Failed to verify UDF Version. Please check the connection and try again.
X30 Failed on Minimum Firmware Version verification. Please check the connection and try again.
X31 Failed on Firmware Version verification. Please check the connection and try again.
X32 Still in Bootloader Mode after the update. Please try again.
X33 File Error. No Product Id found in the update file. Please make sure you selected a valid update file and try again.
X34 File Error. No VE.Direct baudrates found in the update file. Please make sure you selected a valid update file and try again.
X35 File Error. No Xup Format Version found in the update file. Please make sure you selected a valid update file and try again.
X36 File Error. No Minimum Updater Version found in the update file. Please make sure you selected a valid update file and try again.
X37 File Error. No Firmware (product) Version found in the update file. Please make sure you selected a valid update file and try again.
X38 File Error. The update file does not match XML standard. Please make sure you selected a valid update file and try again.
X39 Communication Error. Vreg Ack timeout. Please check the connection and try again.
X40 Communication Error. No product found. Please check the connection and try again.
X41 Communication Error. Comm port error. Please check the connection and try again.
X42 Update Error. Failed to set baudrate. Please check the connection and try again.
X43 Update Error. Update in progress on another interface.
X44 Update Error. Invalid instance# in Ack. Please check the connection and try again.
X45 Update Error. Vreg Ack error: Invalid instance. Please check the connection and try again.
X46 Update Error. Vreg Ack error. Please check the connection and try again.
10. VictonConnect-Remote (VC-R) – Configuration and monitoring via VRM
10.1 Introduction
VictronConnect-Remote functionality enables Victron devices with a VE.Direct interface to be accessed remotely through a GX device, via the VRM online portal.
This powerful new feature allows full device configuration and monitoring from practically anywhere in the world using the VictronConnect app.
The user interface experience is just like the devices were connected locally using Bluetooth or a wired VE.Direct to USB interface.
10.2 Compatibility
The VictronConnect-Remote feature is ONLY compatible with devices connected to a GX Device with a VE.Direct interface.
This includes;
  • MPPT solar chargers with a VE.Direct interface (SmartSolar and BlueSolar)
  • Battery monitors with a VE.Direct interface (BMV and SmartShunt)
  • Specific inverters with a VE.Direct interface (Phoenix Inverter VE.Direct and Phoenix Inverter Smart)
  • Specific mains chargers with a VE.Direct interface (Phoenix Smart IP43)
Devices connected with a VE.Bus interface, such as Multiplus/Quattro inverter-chargers and larger Phoenix Inverters are NOT compatible. However another feature Remote VEConfigure already exists to configure these devices remotely.
Devices connected using a VE.Can interface, such as Lynx Shunt, Skylla chargers and MPPT solar chargers using a VE.Can interface are also NOT compatible and cannot be configured remotely.
10.3 Setup
10.3.1 Minimum Requirements
  • VictronConnect SW: v5.20
  • GX Device - Venus OS FW: v2.40 (However v2.53 recommended for full functionality)
10.3.2 VictronConnect
  1. Confirm that the phone, tablet or PC has VictronConnect installed and that the software version meets or exceeds the minimum requirements - upgrade if necessary
  2. Authorize VictronConnect to access your VRM account;
  • Open the VictronConnect app
  • Swipe across to the VRM tab, then select ‘SIGN IN TO VRM’
  • Complete your email address and VRM password, then select ‘Authorize Victron Connect’
VictronConnect-Remote - VRM Tab Sign In VictronConnect-Remote - Login to VRM
  • If using a tablet or PC your browser may also request permission to proceed, if prompted select ‘Open’
VictronConnect-Remote - Permission
10.3.3 GX Device
1- Confirm that the GX Device is running Venus OS firmware version that meets or exceeds the minimum requirements - upgrade if necessary 2- Enable ‘VRM two-way communication’ under Device List > Settings > VRM Online Portal
VictronConnect-Remote - GX Device Settings
10.4 Local Tab
The local tab displays all devices that are within local Bluetooth and wireless LAN range or physically connected to the phone, tablet or PC with VictronConnect (such as with a VE.Direct to USB or MK3 to USB interface cable)
VictronConnect-Remote - Local Tab
10.5 VRM Tab
The VRM tab displays all VRM installations associated with the VRM user profile.
Any installation can be selected to access the VRM online portal or connected devices.
When a VRM installation is selected it will take a few seconds for a connection to be made, once the connection is established two tabs will appear, an ‘OVERVIEW’ tab and a ‘DEVICES’ tab.
10.5.1 Overview Tab
The ‘OVERVIEW’ tab has an image of the GX device, the name of the VRM installation and a direct link to the associated VRM Online Portal.
VictronConnect-Remote - Installation Connecting VictronConnect-Remote - Overview Tab
10.5.2 Devices Tab
The ‘DEVICES’ tab has a list of all compatible devices that are physically connected to the GX device.
VictronConnect-Remote - Devices Tab
If using a tablet or PC, the ‘DEVICES’ tab is shown as a panel on the right side of the same screen.
VictronConnect-Remote - Tablet View
10.6 Remote device access
When a device is selected it will take a few seconds for a connection to be made, once the connection is established live device information/data will begin to appear.
VictronConnect-Remote - BMV Device Selection VictronConnect-Remote - BMV Connecting
Immediately after initial connection settings and historical data will be downloaded, during this time a cloud symbol will remain in the upper right corner (this typically takes less than 30 seconds).
Settings cannot be accessed until the cloud symbol is replaced by the normal settings gear symbol.
VictronConnect-Remote - BMV Settings Download VictronConnect-Remote - BMV Settings Ready
10.7 Signing out
To disable the link between VictronConnect-Remote and your VRM account, expand the main menu and then select ‘Settings’.
VictronConnect-Remote - Sign Out 1 VictronConnect-Remote - Sign Out 2
In the settings page select ‘SIGN OUT’ and then select ‘OK’ in the prompt window to confirm.
VictronConnect-Remote - Sign Out 3 VictronConnect-Remote - Sign Out 4
After signing out VictronConnect-Remote will no longer have access to the VRM account or any of the associated VRM installations. To reinstate access the log in procedure needs to be repeated.
10.8 Troubleshooting and FAQ
Device not found
  • VictronConnect-Remote is only compatible with devices that use a VE.Direct interface to the GX device – see the ‘compatibility’ section.
  • Ensure that that the missing device is physically connected to the GX device, with the VE.Direct cable properly installed at both ends.
  • Ensure that the device is running a recent firmware version.
Installation/GX device not found or offline
  • Confirm that the installation is currently online and communicating with the VRM online portal.
  • Ensure that the installation is linked to the VRM account used during initial VictronConnect-Remote sign in to VRM.
  • Ensure that ‘VRM two-way communication’ is enabled – see the ‘settings’ section.
  • Ensure that the GX device is running the minimum compatible Venus OS firmware version – see the ‘settings’ section.
VictronConnect has no VRM tab
  • Ensure that the phone, tablet or PC is running the minimum compatible VictronConnect software version – see the ‘settings’ section.
VRM account
  • It is necessary to have an active VRM account linked to your installation and any others that you intend to monitor or configure using VictronConnect-Remote - creating a new account is quick and easy.
  • For further information in relation to VRM (Victron Remote Management) see Getting started with VRM and the VRM online portal site.
Systems with no GX device
  • VictronConnect-Remote functionality is not possible unless the system includes a GX device. A GX device can be easily added to any system and there are a range of products available.
Installations with no internet connection
  • VictronConnect-Remote functionality is not possible unless GX device at the installation site has an active internet connection.
  • For remote sites without an existing internet connection or with mobile installations, a Victron GS GSM modem can be easily be added to the system in order to provide an internet connection.
Large systems
  • The use of the VictronConnect-Remote feature will slightly increase the GX device CPU load.
  • In some large/complex systems (with many devices connected to the GX device) the CPU may already be operating at its limit and any additional CPU load could exceed its capability - this will typically be recognisable by slow user interface response and/or unexpected system reboots.
  • It is important to select a GX device that has sufficient performance capability in relation to the system design, for example a Cerbo GX has significantly more processing power than a Color Control GX and is much better suited to large/complex systems – see the performance section in the GX product range comparison table.
VictronConnect Remote troubleshooting
VictronConnect will report errors encountered during communication attempts with VRM in a message box with an error code. The code can have one of the following value:
Error Description
-100 Call to retrieve a list of child devices expired (60 seconds). The most common cause is a bad internet connection.
1 No link to VRM can be established. Check if the internet is present and try again.
2 VRM encountered temporary difficulties. Try again in a while.
8 An error occurred with the network (e.g., the network cable was accidentally plugged out).
13 Proxy authentication error. VictronConnect does not support communication over proxy.
14 Failed to establish a secure connection to VRM.
65538 VRM MQTT broker is not responding. Please try again in a while.
There are also other error codes that could be reported. They are a result of internal errors in VictronConnect and/or VRM. In case these errors persist after a retry, please create a “Service Report” and submit it for examination.
VictronConnect Remote is establishing communication with a range of services on 'victronenergy.com' domain. Please make sure that traffic with this domain is allowed in your firewall and internet security application.
11. Troubleshooting
11.1 Common Bluetooth problems and how to solve them
The #1 first step before attempting any of the specific troubleshooting advice below is to power down and then restart all related devices. This includes closing the software, restarting the phone, tablet, computer and Victron equipment. This will solve most issues.
For example with Victron MPPTs you must isolate the MPPT from both battery and solar voltage so that no lights appear, before reconnecting it again.
I cannot find my device listed
  • Make sure that you have a “Smart” Victron product. It needs to have a Bluetooth symbol.
  • Make sure your device is in range.
  • If a firmware update failed, the device Custom Name might have reverted to its original name and serial number, check if that is the case. Once the update is completed, the Custom Name will be back. See more tips about troubleshooting firmware updates on section 9.3.
  • Only one device can be connected to a product at the same time. Make sure that no other device: phone/tablet/laptop is already connected.
  • Make sure you are attempting to connect from within VictronConnect - not from the system menu of your phone/tablet/laptop. If you have connected from the system menu: close VictronConnect, remove the pairing information from your device, and then open and connect to your product from within VictronConnect.
I can see but not connect to my device
  1. Make sure you are trying to connect to the right device. See section 4.3 to learn how you can give your device a Custom Name.
  2. Make sure your device is in range. It can be that you are close enough to see the device but not close enough to connect to it.
  3. Make sure that Bluetooth is still enabled in your phone/tablet/laptop. If Bluetooth was disabled after scanning, you may be able to see your device listed but you won't be able to connect to it.
  4. The Bluetooth bonding information may be outdated. This happens when the PIN code has been changed in the device, or if your Victron device has been connected to too many phones/tablets/Laptops. The device will only remember the last 10 phones/tablets/laptops connected to it. To solve this, remove the pairing completely from your phone/tablet/laptop system menu. Then open VictronConnect and re-pair the product and your device. Watch these instructional videos to learn how to remove the pairing on Android or iOS devices.
  5. If you are using an Android phone/tablet, check section 11.2 below for issues particular to Android as well.
Connection fails around 20%
  1. Make sure you are up to date with the latest version of VictronConnect.
  2. Remove the device from the paired devices list in the phones Bluetooth settings.
  3. Force close the VictronConnect app. Instructions: how to for iPhone and iPad, how to for Android. If you are unsure how to do this, then uninstalling and re-installing the app works as well)
  4. Reconnecting in VictronConnect using the default PIN 000000
11.2 Bluetooth connection issues on Android devices
Step 1: Check that your device is supported
Step 2: Check the Android version
  • Android 4.2 or earlier: this Android version is not supported. The earliest Android version which can be used with Bluetooth is 4.3.
  • Android 6 or later: no known issues.
Step 3: Check that VictronConnect has access to the Location services
On Android 5 and later VictronConnect needs access to the device location services to be able to scan nearby Bluetooth devices. Unless you checked “Don't show again” VictronConnect will warn on each discovery attempt when permissions are not granted or location services are disabled.
Permission to access location services is requested each time the app starts …but if you checked the “Don't show again” option while denying, the request won't appear again.. You can grant permission by going to the Android settings → Applications → VictronConnect → Permissions, and then enable the “Location” permission. Another way is to uninstall and then reinstall VictronConnect.
Step 4. Enable Location (or GPS) functionality in the system settings
For Bluetooth scanning to work, the Location (or GPS) functionality on the device needs to be enabled.
Step 5. Search & connect from within VictronConnect ...NOT from the system Bluetooth menu
Step 6. Pin-code pop-up never shows
On some Android phones, the pin-code pop-up dialog doesn't show. It is hidden into the notifications bar.
Try to connect and when the connection is stuck at 80%, open the notifications bar and check if the PIN code/Pair request is there, if it the case open it and enter the PIN code.
The default pin-code is 000000, six times zero.
Step 7. Try another phone at first
If you are still experiencing difficulties, having tried the steps above, try connecting using another phone …preferably an Apple phone or tablet as they work without any issues.
When successfully connected using another device, VictronConnect will automatically update the firmware in the Victron Bluetooth device. After the firmware has been updated you may find that you can use the Android device with which you were experiencing difficulties.
11.3 Problems during firmware updating
First of all, it's good to know that you can always restart the firmware update procedure. The update process will be restarted each time you connect to the product.
Keep your mobile device as close to the product as possible. If the update fails due to Bluetooth connectivity problems, and if your device is already paired to a product, try and remove the pairing completely from your phone/tablet/laptop system menu. Then open VictronConnect and re-pair the product and your device. Watch these instructional videos to learn how to remove the pairing on Android or iOs devices
If the firmware update stops at a random percentage during each retry, just keep trying - it will succeed eventually. If the update fails even after many attempts, try using another phone or tablet …if possible an Apple iOS device - they usually work without any issues. After the update, you may find you can use the phone with which you were having difficulty.
Update stops at 4% or earlier
When the firmware update fails at 4% or less, VictronConnect cannot make the device switch to the update mode.
__ Solution for Blue Smart IP65 Chargers __
  • If you are in the firmware update screen, first force close VictronConnect.
  • Unplug the mains cable from the charger and wait for 30 seconds.
  • Press and hold the MODE button on the charger and plug in the mains cable again until the yellow and blue LEDs are blinking alternately to force the charger into update mode.
  • Release the MODE button. You now have 30 seconds to connect to the product, after 30 seconds the charger will automatically leave the update mode.
  • Start VictronConnect and click on the product in the device list.
  • The firmware update screen will appear again. You should now be able to update your charger to the latest firmware version.
__ Solution for VE.Direct Smart dongle __
  • Unplug the dongle from the VE.Direct port.
  • Press and hold the 'Clear PIN' button on the dongle and connect it to the VE.Direct port again, the red and blue LEDs will blink alternately; indicating that the dongle is in update mode.
  • Release the 'Clear PIN' button. You now have 30 seconds to connect to the product, after 30 seconds the dongle will automatically leave the update mode.
  • The firmware update screen will appear again. You should now be able to update the dongle to the latest firmware version.
11.4 VE.Direct USB driver problem on macOS X 10.9 (Mavericks)
The driver included in macOS X 10.9 “Mavericks” doesn't work properly with the VE.Direct USB cable. To fix this issue we recommend updating to a later version of macOS.
If updating the operating system is not possible, there is a workaround which disables the Apple FTDI (Future Technology Devices International) driver and installs a compatible driver. Follow these steps:
Step 1. Open the terminal and run the following commands:
cd /System/Library/Extensions/IOUSBFamily.kext/Contents/PlugIns
sudo mv AppleUSBFTDI.kext AppleUSBFTDI.disabled
Step 2. Restart the computer
Step 3. Download and install the compatible FTDI driver
Step 4. Restart the computer
VictronConnect should now show the connected products.
11.5 VictronConnect on Windows doesn't find VE.Direct USB connected devices
VE.Direct USB cable requires a driver to be installed.
The necessary drivers are available in the software section.
11.6 VictronConnect on Android doesn't show files opened from email or file manager apps
Open VictronConnect and without closing it switch to the app containing the file, select it and choose to open it with VictronConnect.
11.7 How to create a VictronConnect Service Report
If you are experiencing issues with VictronConnect or your Victron product, you may be asked to create a “VictronConnect Service Report”. Please note that this service report is for Victron internal use and is not able to be read or used for any other purpose than developer troubleshooting.
To do this,
  1. Open VictronConnect
  2. Perform the action that leads to the bug or issue
  3. Return to the main menu
  4. Select the three lines menu
  5. Select Settings
  6. Click or tap CREATE SERVICE REPORT
  7. Save, email or copy the file to Victron, via email or the Victron Community.
If you require more detailed power system diagnostic information, for example detailed monitoring of battery voltage and state of charge readings over time, this may require connecting a GX device.
11.8 VE.Bus firmware update fails at 5% on macOS
There is a known issue that makes VE.Bus firmware updates randomly fail on some macOS laptops. We are working on it; a new VictronConnect version fixing this issue is expected in the near future. Meanwhile this is the workaround for this:
Proceed to update as usual and quickly minimise the VictronConnect window when progress bar is shown because the update starts. After ~20 seconds you can maximise VictronConnect to see the update status. (1)
This issue was introduced in VictronConnect v5.9.
(1) For those with a technical background and wondering how, why and what minimising has to do with this: yes this really works, and relates to a power saving mode that has a side effect on serial communication.
12. Compatible Victron products
Solar Chargers
SmartSolar MPPT Charge controllers
USB via VE.Direct port Wireless Via Bluetooth
MPPT 75/10 VE.Direct to USB accessory required Yes - Built in
MPPT 75/15 VE.Direct to USB accessory required Yes - Built in
MPPT 100/15 VE.Direct to USB accessory required Yes - Built in
MPPT 100/20 VE.Direct to USB accessory required Yes - Built in
MPPT 100/30 VE.Direct to USB accessory required Yes - Built in
MPPT 100/50 VE.Direct to USB accessory required Yes - Built in
MPPT 150/35 VE.Direct to USB accessory required Yes - Built in
MPPT 150/45 Tr and MC4 VE.Direct to USB accessory required Yes - Built in
MPPT 150/60 Tr and MC4 VE.Direct to USB accessory required Yes - Built in
MPPT 150/70 Tr and MC4 VE.Direct to USB accessory required Yes - Built in
MPPT 150/85 Tr and MC4 VE.Direct to USB accessory required (*) Yes - Built in (*)
MPPT 150/100 Tr and MC4 VE.Direct to USB accessory required (*) Yes - Built in (*)
MPPT 250/60 Tr and MC4 VE.Direct to USB accessory required Yes - Built in
MPPT 250/70 Tr and MC4 VE.Direct to USB accessory required Yes - Built in
MPPT 250/85 Tr and MC4 VE.Direct to USB accessory required Yes - Built in
MPPT 250/100 Tr and MC4 VE.Direct to USB accessory required Yes - Built in
(*) Note for early versions of SmartSolar MPPT 150/85 and 150/100: it is not possible to use both the VE.Direct port and the built-in Bluetooth Smart function at the same time. When connecting to VE.Direct, the built-in Bluetooth Smart function will not be available. These early versions can be recognized by their part number:
  • SmartSolar MPPT 150/85 Tr. Early version: SCC010085210.
  • SmartSolar MPPT 150/85 MC4. Early version: SCC010085310.
  • SmartSolar MPPT 150/100 Tr. Early version: SCC010100210.
  • SmartSolar MPPT 150/100 MC4. Early version: SCC010100310.
The same models, but then with a different part number do support using both the VE.Direct port and the built-in Bluetooth Smart function at the same time. As do all other SmartSolar MPPT models.
BlueSolar MPPT Charge controllers
Battery Chargers
Blue Smart IP22 USB via VE.Direct port Wireless Via Bluetooth Bluetooth on/off Charge cycle history Advanced settings
All Blue Smart IP22 Chargers No Yes - Built in Yes - Since firmware v3.12 No No
Blue Smart IP65 USB via VE.Direct port Wireless Via Bluetooth Bluetooth on/off Charge cycle history Advanced settings
Blue Smart IP65 12/25 Charger No Yes - Built in Yes Yes Yes
Blue Smart IP65 24/13 Charger No Yes - Built in Yes Yes Yes
Other Blue Smart IP65 Chargers No Yes - Built in Yes - Since firmware v3.12 No No
Blue Smart IP67 USB via VE.Direct port Wireless Via Bluetooth Bluetooth on/off Charge cycle history Advanced settings
All Blue Smart IP67 Chargers No Yes - Built in Yes - Since firmware v3.12 No No
Phoenix Smart IP43 USB via VE.Direct port Wireless Via Bluetooth Bluetooth on/off Charge cycle history Advanced settings
All Phoenix Smart IP43 Chargers Yes Yes - Built in Yes No No
IMPULSE-II Smart USB via VE.Direct port Wireless Via Bluetooth Bluetooth on/off Charge cycle history Advanced settings
All IMPULSE-II Smart Chargers No Yes - Built in Yes - Since firmware v3.09 Yes - Since firmware v3.09 No
Orion-Tr Smart DC-DC Charger Isolated
All Orion-Tr Smart DC-DC Isolated Chargers No Yes - Built in
Battery Monitors
Phoenix Inverters VE.Direct
Phoenix Inverter 12V 250VA VE.Direct to USB accessory required VE.Direct to Bluetooth accessory required
Phoenix Inverter 12V 375VA VE.Direct to USB accessory required VE.Direct to Bluetooth accessory required
Phoenix Inverter 12V 500VA VE.Direct to USB accessory required VE.Direct to Bluetooth accessory required
Phoenix Inverter 12V 800VA VE.Direct to USB accessory required VE.Direct to Bluetooth accessory required
Phoenix Inverter 12V 1200VA VE.Direct to USB accessory required VE.Direct to Bluetooth accessory required
Phoenix Inverter 24V 250VA VE.Direct to USB accessory required VE.Direct to Bluetooth accessory required
Phoenix Inverter 24V 375VA VE.Direct to USB accessory required VE.Direct to Bluetooth accessory required
Phoenix Inverter 24V 500VA VE.Direct to USB accessory required VE.Direct to Bluetooth accessory required
Phoenix Inverter 24V 800VA VE.Direct to USB accessory required VE.Direct to Bluetooth accessory required
Phoenix Inverter 24V 1200VA VE.Direct to USB accessory required VE.Direct to Bluetooth accessory required
Phoenix Inverter 48V 250VA VE.Direct to USB accessory required VE.Direct to Bluetooth accessory required
Phoenix Inverter 48V 375VA VE.Direct to USB accessory required VE.Direct to Bluetooth accessory required
Phoenix Inverter 48V 500VA VE.Direct to USB accessory required VE.Direct to Bluetooth accessory required
Phoenix Inverter 48V 800VA VE.Direct to USB accessory required VE.Direct to Bluetooth accessory required
Phoenix Inverter 48V 1200VA VE.Direct to USB accessory required VE.Direct to Bluetooth accessory required
Peak Power Pack
Smart LiFePO4 Lithium Batteries
LiFePO4 battery 12,8V/60Ah No VE.Direct port Yes - Built in
LiFePO4 battery 12,8V/90Ah No VE.Direct port Yes - Built in
LiFePO4 battery 12,8V/100Ah No VE.Direct port Yes - Built in
LiFePO4 battery 12,8V/150Ah No VE.Direct port Yes - Built in
LiFePO4 battery 12,8V/160Ah No VE.Direct port Yes - Built in
LiFePO4 Battery 12,8V/200Ah No VE.Direct port Yes - Built in
LiFePO4 Battery 12,8V/300Ah No VE.Direct port Yes - Built in
LiFePO4 Battery 25,6V/200Ah No VE.Direct port Yes - Built in
Smart Battery Sense
Smart Battery Sense No VE.Direct port Yes - Built in
MultiPlus, EasySolar, Quattro, Phoenix Inverter with VE.Bus, and similar products
This section applies to MultiPlus, MultiPlus-II, MultiCompact, Multi (the models introduced in 2018), Quattro, EasySolar, EasySolar-II, MultiGrid and ECOMultis.
In order to keep this section short, all these devices are referred to as VE.Bus products.
The minimal required version of the VE.Bus devices is 19xx111 for European units and 20xx111 for 120V, which were released in 2007. Older models, 18xxxxx are not supported.
The currently sold generation, VE.Bus firmware 26xxxxx and 27xxxxx is supported.
Mixed systems (1954208 in parallel to 2654208) are not supported by vebus-interface, not for readout and not for settings; use VEConfigure instead.
Inverter/chargers can be connected to in two ways:
  1. Using USB, this requires the MK3-USB, full details here.
  2. Wirelessly, over Bluetooth. Requires the VE.Bus Smart dongle accessory. The available functionality is monitoring as well as operation of the product: switching between on/off/charger-only and setting the input current limit. Changing the configuration, as well as firmware updating a VE.Bus product, is not supported.
Note that switching between on/off/charger-only as well as setting the input current limit is not possible when there is a DMC or VE.Bus BMS installed.
For systems with a GX device installed, and running firmware version 415 or newer, switching between on/off/charger-only and setting the input current limit IS possible.
victronconnect/start.1592620081.txt.gz · Last modified: by nlakatos
