venus-os:start
GX product family of Venus-devices
Introduction
GX products are Victron's state-of-the-art monitoring solution. The family consists of a number of 'Venus' devices each especially suited to a particular type of installation. Accessories are available for these devices which extend their functionality even further.
The Venus-device lies at the heart of the system - providing monitoring, and operating as the communication-centre of your installation. All the other system-components - such as inverter/chargers, solar chargers, and batteries - are connected to it. The Venus-device ensures that they all work in harmony. Monitoring can be carried out locally …or remotely - via our free-to-use Victron Remote Management portal (VRM). The Venus device also provides Remote firmware updates and even allows the settings to be Changed Remotely.
The Venus devices are:
  • Octo GX - The Octo GX is particularly suited to installations which have many MPPT Solar Chargers, as it has 10 VE.Direct ports
  • CANvu GX - The CANvu GX is best for harsh environments - when its IP67 rating is a must.
Available accessories
Comparison table
User interface CCGX Venus GX Octo GX CANvu GX
Appearance
Display LCD Display & 7 buttons no display no display 4.3“ touch-screen
Remote Console yes
Buzzer yes yes no no
Documentation CCGX Venus GX Octo GX CANvu GX
Manual CCGX manual VGX manual OGX manual CANvu manual
Product detail page CCGX product VGX product OGX product CANvu product
Victron comm. ports CCGX Venus GX Octo GX CANvu GX
VE.Direct ports 2 (1) 10 (1) 3 (1)
VE.Can 2 paralleled RJ45 sockets – isolated
VE.Bus 2 paralleled RJ45 sockets – isolated
Non Victron-products CCGX Venus GX Octo GX CANvu GX
Canbus-BMS batteries Many battery brands. See here for details
Fronius PV Inverters See here for details
SMA PV Inverters See here for details
Communication CCGX Venus GX Octo GX CANvu GX
USB 2 USB Host ports – not isolated 1 USB Host port - not isolated
Ethernet 10/100 RJ45 socket - isolated except shield 1 port. isolation?
WiFi optional (2) built-in, but see (3) built-in, external antenna (11) optional (2)
Bluetooth Smart no
Micro SDcard slot SDHC cards up to max. of 32GB. (5) no
Second CAN-bus port no yes - non-isolated yes - non-isolated yes - non-isolated
RS485 no no yes - non-isolated no
IO CCGX Venus GX Octo GX CANvu GX
Programmable relay (7) 1x NO 1x NO / NC (8) 1x NO / NC
Resistive tank level inputs no 3 (9) no
Temperature measurements no 2 (10) no
Digital Inputs no 5 3 1
Other CCGX Venus GX Octo GX CANvu GX
Mounting Panel Integration Wall mounting DIN Rail (35mm) Panel
Outer dimensions ( h x w x d ) 130 x 120 x 28 mm 45 x 143 x 96 mm 61 x 108 x 90 mm ?
Operating temperature -20 to +50°C ?
Standards CCGX Venus GX Octo GX CANvu GX
Safety EN 60950 ? ?
EMC EN 61000-6-3, EN 55014-1, EN 61000-6-2, EN 61000-6-1, EN 55014-2
Automotive E4-10R-053535 In progress ? ?
Notes:
  1. The maximum number of VE.Direct devices which can be attached to a CCGX is 5 (2 direct, and 3 via USB); on a Venus GX the number is 6 (2 direct and 4 via USB); on an Octo GX it is 10 (all attached directly). VE.Direct ports on a Venus-device are isolated.
  2. Though the CCGX has no built-in WiFi that functionality can easily be added by attaching a USB-WiFi dongle. See CCGX Manual, section 1.4.2 for details.
  3. The built-in WiFi in the Venus GX has a very low signal strength - unfortunately. It is strong enough to connect to a phone, tablet or laptop in order to access setup and monitoring. But to connect the Venus GX to the internet either use the built-in Ethernet port or add a USB-WiFi dongle. See CCGX Manual, section 1.4.2 for details. Make sure the Venus GX is running v2.06 or later - early shipments of Venus GX units ran v2.05.
  4. The hardware of the Venus GX and Octo GX includes a built-in Bluetooth Smart chipset which hasn't proved satisfactory. Bluetooth Smart for Venus-devices is coming soon but will not use built-in chipsets.
  5. Larger SD memory cards (SDXC) are not supported. SD cards can be used for two purposes:
  6. The second CANbus port is accessible via the GND, CAN-H and CAN-L terminals. Note that the port is not Isolated. See Settings → Services for configuring that port.
  7. The programmable relay can be set to act as an alarm relay, automatic genset start stop, or an on/off switch, and is controlled via the GUI and/or ModbusTCP.
  8. In the Venus GX hardware there are two relays - at present only one of them is available for use.
  9. The tank level inputs are resistive and should be connected to a resistive tank sender. Victron does not supply tank senders. The tank level ports can each be configured to work with either European (0 - 180 Ohm); or US tank senders (240 - 30 Ohm).
  10. The Venus GX has two temperature terminals which can be used to measure & monitor all kinds of temperature-inputs. Temperature senders are not included. The required sensor is ASS000001000 - Temperature Sensor QUA/PMP/Venus GX. (Note that this is not the same as the BMV temperature accessory.)
  11. Octo GX comes with a small Wifi antenna. You may remove and replace it with any other Wifi antenna having an RP-SMA connector.
venus-os/start.1546896607.txt.gz · Last modified: 2019-01-07 22:30 by guy_stewart
