venus-os:mfd-raymarine
venus-os:mfd-raymarine [2020-03-26 08:13] – [3. Wiring] mbosma | venus-os:mfd-raymarine [2023-04-13 20:50] – [7. NMEA 2000] mvader | ||
Line 2: | Line 2: | ||
+ | This document explains how to connect to Raymarine MFDs using an Ethernet connection. Also, the last chapter explains the Raymarine specifics when connecting on NMEA2000. | ||
The integration technology used is called [[http:// | The integration technology used is called [[http:// | ||
Line 10: | Line 15: | ||
Raymarine MFDs need at least LightHouse v3.11 for compatibility, | Raymarine MFDs need at least LightHouse v3.11 for compatibility, | ||
===== 3. Wiring ===== | ===== 3. Wiring ===== | ||
Line 22: | Line 29: | ||
* A80513 - RayNet male to RJ45 adaptor cable | * A80513 - RayNet male to RJ45 adaptor cable | ||
- | Connecting a Axiom MFD to a network router might lead to IP address conflicts, due to the integrated DHCP server. | + | To connect the [[https:// |
- | To connect | + | :!: Connecting a Axiom MFD to a network router over Ethernet leads to IP address conflicts, due to the integrated DHCP server in the Axiom MFD. |
+ | **Note: As of Raymarine LightHouse v3.15, there is an option | ||
- | On the Victron GX Device, go to Settings → Services, and there enable both MQTT on LAN (SSL) and MQTT on LAN (Plaintext). | + | On the Victron GX Device, go to //Settings → Services//, and there enable both //MQTT on LAN (SSL)// and //MQTT on LAN (Plaintext)//. |
+ | Next, go to Menu -> Settings -> System Setup -> Battery Measurements. And there set up what batteries you want to see on the MFD; and by what name. | ||
- | Next, go to Settings → System Setup → Scroll to the bottom → Battery measurements. And there set up what batteries you want to see on the MFD; and by what name. | + | {{: |
No other settings, such as IP addresses or similar are required, since the Axiom MFDs have an integrated DHCP server. | No other settings, such as IP addresses or similar are required, since the Axiom MFDs have an integrated DHCP server. | ||
Line 48: | Line 64: | ||
{{youtube> | {{youtube> | ||
+ | After connecting the Ethernet cable the GX device receives an IP number from the Axiom DHCP. | ||
+ | If you start the Victron App on the Axiom and it shows " | ||
+ | Besides connecting over ethernet, a Raymarine MFD can also be connected to the Victron system using NMEA 2000. If you’re new to NMEA2000 & Victron, start with reading the [[ve.can: | ||
+ | This chapter explains the specifics of NMEA2000 when connecting Victron to a Raymarine MFD. | ||
+ | === 7.1. Generic and supported PGNs === | ||
+ | To setup the data sources on the Raymarine, go to //Settings > Network > Sources > Advanced...// | ||
+ | If you have more than 1 battery be sure to adjust the settings of the Axiom to the correct amount of battery(banks). | ||
+ | The following Victron related PGNs are supported by Raymarine: | ||
+ | * 127505 - Fluid level (tank levels) | ||
+ | * 127506 - DC Detailed Status (State-of-charge, | ||
+ | * 127507 - Charger status | ||
+ | * 127508 - Battery Status (Battery Voltage, Battery Current) | ||
+ | * 127509 - Inverter status | ||
+ | This PGN is not supported by Raymarine: | ||
+ | * J1939 - AC data | ||
+ | When the NMEA2000/ | ||
+ | === 7.2. Instancing requirements when using Raymarine === | ||
+ | Fluid instancing details: | ||
+ | * Raymarine i70: max number of tank levels is 5; fluid instance 0-4 and type must be fuel. | ||
+ | * Raymarine i70s: max number of tank levels is 5; fluid instance 0-4 and type must be fuel. | ||
+ | * Axiom MFDs: per Lighthouse version 4.1.75, a maximum of 16 tanks can be connected; fluid instance 0-15. | ||
+ | ==== LightHouse 4.1.75 and newer versions ==== | ||
+ | As of LightHouse version 4.1.75, the battery instances no longer need to be unique. This means that you can leave the battery instance to its default value, which is typically set to 0. The batteries are automatically detected by the Axiom display. | ||
+ | ==== LightHouse 4.1.74 and prior versions ==== | ||
+ | If there are more than 1 (for example) SmartShunts in the NMEA2000 network, or a Solar Charger and a SmartShunt, or any other device that transmits the same type of PGNs, then the Data instances of those PGNs need to changed to make each data instance unique. | ||
+ | Typically this concerns the Battery instance, used in the Battery Status and DC Detailed PGNs. | ||
+ | See here for how to do that: [[https:// |
