venus-os:canvu-gx
venus-os:canvu-gx [2019-01-29 11:54] – mvader | venus-os:canvu-gx [2019-05-10 14:06] – lucian | ||
- | The CANvu GX is a product in the Victron [[venus-os: | + | The CANvu GX is a product in the Victron [[venus-os: |
+ | The CANvu GX is a device similar to the Color Control GX, and most of it's functionality and features are explained in the Color Control Manual here : https:// | ||
- | The CANvu GX is a device similar to the Color Control GX. | ||
- | For more information see here: https:// | ||
**CANvu GX:** | **CANvu GX:** | ||
Line 18: | Line 18: | ||
* CANvu GX IO extender | * CANvu GX IO extender | ||
- | * Power cable | + | * Power cable (supply voltage 8 - 32 VDC, **if used on a 48V system, a DC-DC converter must be used to reduce the voltage below 32VDC**) |
* VE.Can cable | * VE.Can cable | ||
* Ethernet cable | * Ethernet cable | ||
Line 34: | Line 34: | ||
Overview of connections | Overview of connections | ||
venus-os/canvu-gx.txt · Last modified: 2020-05-13 11:20 by mvader
