ve.can:nmea-2000:start
ve.can:nmea-2000:start [2022-03-16 12:07] – [3.4 DC Voltage compatibility] mvaderve.can:nmea-2000:start [2022-03-16 12:19] (current) – [3.4 DC Voltage compatibility] stefanie
Line 144: Line 144:
 ==== 3.4 DC Voltage compatibility ==== ==== 3.4 DC Voltage compatibility ====
-The Victron VE.Can network is accepts 9 to 70VDC.+The Victron VE.Can network accepts 9 to 70VDC.
-The NMEA-2000 network used to be 9 to 16VDC, which is, or will be, expanded to also include 24 V. Which means that some NMEA-2000 devices are 9 to 16 VDC, some are 9 to 30VDC, and some allow higher voltages.+The NMEA-2000 network used to be 9 to 16VDC, which is, or will be, expanded to also include 24V. Which means that some NMEA-2000 devices are 9 to 16VDC, some are 9 to 30VDC, and some allow higher voltages.
-Also, the Victron VE.Can network will (in most cases) be powered with battery voltage. So for a 48V system, the voltage on the VE.Can network **exceeds** the NMEA2000 accepted voltage levels.+Also, the Victron VE.Can network will (in most cases) be powered with battery voltage. So for a 48V system, the voltage on the VE.Can network **exceeds** the NMEA-2000 accepted voltage levels.
-Therefore, it is important to not connect those power cables.+Therefore, it is important to **not** connect those power cables.
 The Victron cable used to connect both networks together, the [[https://www.victronenergy.com/accessories/ve-can-to-nmea2000-micro-c-male|VE.Can to NMEA 2000 cable]], has a removable fuse which is to be removed in case separation is necessary. A printed warning label is attached to the cable to warn about this. The Victron cable used to connect both networks together, the [[https://www.victronenergy.com/accessories/ve-can-to-nmea2000-micro-c-male|VE.Can to NMEA 2000 cable]], has a removable fuse which is to be removed in case separation is necessary. A printed warning label is attached to the cable to warn about this.
ve.can/nmea-2000/start.1647428841.txt.gz · Last modified: 2022-03-16 12:07 by mvader
