ve.can:nmea-2000:start
ve.can:nmea-2000:start [2021-12-09 10:24] – [3.2 NMEA 2000 instancing] mvaderve.can:nmea-2000:start [2022-03-16 12:19] (current) – [3.4 DC Voltage compatibility] stefanie
Line 134: Line 134:
   * Use the NMEA 2000 cable as the backbone.   * Use the NMEA 2000 cable as the backbone.
-  * Run a separate drop cable separately to each Victron device [[https://nocache.victronenergy.com/accessories/ve-can-to-nmea2000-micro-c-male|VE.Can to NMEA 2000 cable]] +  * Run a separate drop cable separately to each Victron device [[https://www.victronenergy.com/accessories/ve-can-to-nmea2000-micro-c-male|VE.Can to NMEA 2000 cable]]
-  * Only terminate the NMEA 2000 backbone, do not terminate on the VE.Can side.+  * Only terminate the NMEA 2000 backbone. Do not install a terminator in any of the VE.Can ports on the Victron products.
 Or: Or:
Line 142: Line 142:
 The first option is more aligned with the official N2K method. But, in case of multiple Victron products that need to be connected to the N2K network, will require more wire runs and definitively more NMEA2000 to VE.Can conversion cables. The first option is more aligned with the official N2K method. But, in case of multiple Victron products that need to be connected to the N2K network, will require more wire runs and definitively more NMEA2000 to VE.Can conversion cables.
-==== 3.4 Further reading on Victron and NMEA 2000 ====+==== 3.4 DC Voltage compatibility ====
 +The Victron VE.Can network accepts 9 to 70VDC.
 +The NMEA-2000 network used to be 9 to 16VDC, which is, or will be, expanded to also include 24V. Which means that some NMEA-2000 devices are 9 to 16VDC, some are 9 to 30VDC, and some allow higher voltages.
 +Also, the Victron VE.Can network will (in most cases) be powered with battery voltage. So for a 48V system, the voltage on the VE.Can network **exceeds** the NMEA-2000 accepted voltage levels.
 +Therefore, it is important to **not** connect those power cables.
 +The Victron cable used to connect both networks together, the [[https://www.victronenergy.com/accessories/ve-can-to-nmea2000-micro-c-male|VE.Can to NMEA 2000 cable]], has a removable fuse which is to be removed in case separation is necessary. A printed warning label is attached to the cable to warn about this.
 +==== 3.5 Further reading on Victron and NMEA 2000 ====
   * [[https://www.victronenergy.com/upload/documents/Whitepaper-Data-communication-with-Victron-Energy-products_EN.pdf|Data communication white paper]]   * [[https://www.victronenergy.com/upload/documents/Whitepaper-Data-communication-with-Victron-Energy-products_EN.pdf|Data communication white paper]]
Line 152: Line 164:
 ==== 4.1 Raymarine & EmpirBus ==== ==== 4.1 Raymarine & EmpirBus ====
-Besides using NMEA 2000 and/or the Lighthouse App, integration onto Raymarine MFDs can also be done with an [[http://www.trigentic.com/#nxt-mcu|Empirbus NXT MCU ]]. Though both are connected to the same N2K network, the NXT MCU translates the N2K PGNs originating from the Victron equipment into Raymarine proprietary messages.+Besides using NMEA 2000 and/or the Lighthouse App, integration onto Raymarine MFDs can also be done with an [[https://www.empirbus.com/#nxt-mcu|Empirbus NXT MCU ]]. Though both are connected to the same N2K network, the NXT MCU translates the N2K PGNs originating from the Victron equipment into Raymarine proprietary messages.
-In the [[http://www.empirbus.com/clickOnce/EmpirBusStudio-Demo/|EmpirBus Studio software]] you will find dedicated Victron building blocks than can be drawn onto the diagram.+In the [[https://www.empirbus.com/#empirbus-studio|EmpirBus Studio software]] you will find dedicated Victron building blocks than can be drawn onto the diagram.
-Next, use the [[http://www.trigentic.com/#empirbus-graphic|EmpirBus Graphical tool]] to design the pages for on the Raymarine MFDs. +Next, use the [[http://www.empirbus.com/#empirbus-graphic|EmpirBus Graphical tool]] to design the pages for on the Raymarine MFDs.
 The EmpirBus system requires the data instance of battery status and dc detailed status to be unique when using multiple sources. ([[ve.can:changing_nmea2000_instances#changing_a_data_instance|how to change data instances]]) The EmpirBus system requires the data instance of battery status and dc detailed status to be unique when using multiple sources. ([[ve.can:changing_nmea2000_instances#changing_a_data_instance|how to change data instances]])
ve.can/nmea-2000/start.1639041898.txt.gz · Last modified: 2021-12-09 10:24 by mvader
