ve.can:nmea-2000:start
ve.can:nmea-2000:start [2016-11-23 12:28] – mvader | ve.can:nmea-2000:start [2022-03-16 12:19] (current) – [3.4 DC Voltage compatibility] stefanie | ||
- | Many Victron | + | ==== 1.1 Summary ==== |
+ | This document explains how to integrate a Victron | ||
+ | There are multiple options, and how to best integrate depends on the customer requirements, | ||
+ | Make sure to closely read this full document to find the best method for your type of system. | ||
+ | NMEA 2000 is a communications standard used for connecting marine sensors and display units within ships and boats. | ||
- | For brevity, this document will refer to NMEA 2000 as N2K. | + | NMEA 2000 is sometimes also refered to as N2K, for brevitiy. |
- | ===== 1. How to connect to a NMEA 2000 network ===== | + | ==== 1.3 What is the MFD HTML5 App? ==== |
+ | The MFD HTML5 App is a simple to install and setup integration into all main marine MFD brands, including Raymarine, Garmin, Navico and Furuno. Truly plug-and-play: | ||
- | ==== 1.1 Multis, MultiPlusses and Quattros | + | ==== 1.4 Other integration options |
- | Use the [[https:// | + | This document only covers integration via NMEA2000 as well as the MFD HTML5 App. There are two other alternatives, |
- | Monitoring and controlling these products from both to a N2K network and a Color Control GX is possible. In that case, do not connect the Color Control | + | First of all Modbus-TCP. Typically used on larger vessels, Modbus-TCP is a protocol commonly used for (custom) designed SCADA systems. The Victron |
- | Schematic diagram of combining a CCGX with NMEA 2000: | + | The other alternative is SignalK. More information about that in the [[venus-os:large|Venus OS Large manual]]. Do take note of the contents of the Support chapter. |
- | {{ :ve.can: | + | |
- | In above example, there needs to be a fuse in the [[https:// | + | |
- | ==== 1.2 BMV Battery Monitors | + | ===== 2. Integration details ===== |
- | Combining this with a CCGX on the same network is possible. Connect the CCGX to the N2K network as well, use our [[https:// | + | ==== 2.1 Systems |
- | ==== 1.3 VE.Can products (Skylla-i, Skylla-IP44, Lynx Shunt, Lynx Ion+Shunt | + | For most installations and integrations, it will be best to use one of our [[venus-os:start|GX Products]]. It acts as a hub, collecting information from connected equipment, such as Inverters, Battery Monitors |
- | Since the Victron | + | The GX devices offer both above introduced integration options: NMEA2000 as well as the Victron |
+ | The HTML5 integration | ||
+ | When connected to the onboard NMEA2000 network, the GX Device | ||
+ | Both the NMEA2000 and HTML5 App/ | ||
+ | Each has its advantages and disadvantages, | ||
+ | The MFD HTML5 App is the simpler one to setup as its plug and play. It presents an easy to use system overview without requiring any configuration. The system overview shown will automatically adapt to the type of Victron system installed. The (only) available configuration is defining the batteries as well as giving them names. | ||
+ | The NMEA 2000 integration is more complex, and allows more customisation on the MFD: the data will show up in the data-tree of the MFD, and most MFDs then allow the user to configure various pages and combinations of information. | ||
+ | ==== 2.2 Products with a VE.Can port ==== | ||
+ | All Victron products that feature a VE.Can port can be directly connected to the NMEA 2000 network, using the [[https:// | ||
* Skylla-i 24V Battery Chargers | * Skylla-i 24V Battery Chargers | ||
- | * Skylla | + | * Skylla |
- | * Lynx Shunt Battery | + | * Lynx Shunt VE.Can |
- | * Lynx Ion + Shunt all models | + | * Lynx Smart BMS |
- | ===== 2. MFD integration ===== | + | {{ :ve.can: |
- | Using the NMEA 2000 protocol, Victron equipment can be integrated in many multi function displays. Such as the ones from Maretron, Raymarine, Garmin and many other brands | + | ==== 2.3 Tank monitoring integration ==== |
- | Note: working on a very large yacht featuring custom Scada and PLC networks? Consider integrating | + | The GX devices can measure tank levels, |
- | ==== 2.1 Raymarine & EmpirBus ==== | + | Below sections explain the details of each integration type. |
- | Integration | + | === Integration |
- | In the [[http://www.empirbus.com/clickOnce/ | + | Some of Victron GX monitoring products feature built-in tank level inputs. For example |
- | Next, use the [[http://www.trigentic.com/#empirbus-graphic|EmpirBus Graphical tool]] to design the pages for on the Raymarine MFDs. | + | Also, all GX devices can also have their number and types of tank level inputs expanded by adding one or multiple |
- | The EmpirBus system requires the data instance of battery status | + | All tank level inputs feature customisable naming, setting a type (fresh water, fuel, black water and more), configurable filtering and damping settings as well as setting up a custom tank shape for non-square tanks. |
- | ==== 2.2 Maretron ==== | + | |
- | All data sent out by Victron devices | + | The GX Device |
- | ===== 3. PGN overview | + | === Integration B) NMEA2000 to GX Device and VRM Portal === |
+ | The other way around is possible as well: the Victron system reading tank level data from NMEA2000. | ||
+ | The tank data will be shown in the GX device user interface as well as on the VRM Portal. Screenshots below. | ||
+ | Compatible tank senders are listed in the [[https:// | ||
+ | //Above picture: GX Touch 50, showing multiple tank levels. Coming from either the NMEA2000 network, directly connected resistive tank senders or via the GX Tank 140 accessory.// | ||
+ | * [[https:// | ||
+ | ===== 3. NMEA2000 Details | ||
- | ===== 4. Color Control GX & NMEA 2000 ===== | + | ==== 3.2 NMEA 2000 instancing |
- | * The VE.Can port on the CCGX only reads information from the N2K network. It does not (yet!) send any data out on the N2K network. | + | NMEA 2000 Instances are used to identify multiple similar products connected |
+ | There are several types of instances, the most important ones being the **Device instance** as well as the **Data instances**. | ||
- | ===== 5. FAQ ===== | + | More information about instances is in [[https:// |
- | === What about instances? Device instances, data instances? === | + | === What settings need to be made? For example |
- | See [[ve.can:changing_nmea2000_instances|]] for details on that. | + | That is a commonly asked question. The answer depends on the used brand of MFD: |
- | === Can MPPT Solar Chargers with a VE.Direct port also be connected? === | + | For **Garmin, Furuno, Maretron and Navico (B&G, Lowrance, Simrad) systems**: none. No instances, |
- | No, they cannot | + | For **Raymarine**, you might need to do some configuration: |
+ | ==== 3.3 Terminators and network layout ==== | ||
+ | * Use the NMEA 2000 cable as the backbone. | ||
+ | * Run a separate drop cable separately to each Victron device | ||
+ | * Only terminate the NMEA 2000 backbone. Do not install a terminator in any of the VE.Can ports on the Victron products. | ||
+ | Or: | ||
+ | * Have the N2K network on one side, with one terminator. On the other end, change to the Victron network, with also one (Victron) terminator at the end. | ||
+ | The Victron VE.Can network accepts 9 to 70VDC. | ||
+ | The NMEA-2000 network used to be 9 to 16VDC, which is, or will be, expanded to also include 24V. Which means that some NMEA-2000 devices are 9 to 16VDC, some are 9 to 30VDC, and some allow higher voltages. | ||
+ | Also, the Victron VE.Can network will (in most cases) be powered with battery voltage. So for a 48V system, the voltage on the VE.Can network **exceeds** the NMEA-2000 accepted voltage levels. | ||
+ | Therefore, it is important to **not** connect those power cables. | ||
+ | The Victron cable used to connect both networks together, the [[https:// | ||
+ | ==== 3.5 Further reading on Victron and NMEA 2000 ==== | ||
+ | ===== 4. Varia ===== | ||
+ | Besides using NMEA 2000 and/or the Lighthouse App, integration onto Raymarine MFDs can also be done with an [[https:// | ||
+ | In the [[https:// | ||
+ | ===== 5. FAQ ===== | ||
- | Note that there are many more generic frequently asked questions answered in the [[https:// | + | === Q1: Can/must both Ethernet and and N2K connection be made between |
- | === What about terminators and network layout? === | + | Both can be made at the same time. |
- | A N2K canbus network needs to be laid out as in backbone configuration, | + | Ethernet is needed |
- | * Use the NMEA2000 cable as the back bone. | + | And an N2K connection is needed |
- | * Run a separate drop cable separately | + | |
- | * [[https:// | + | |
- | * Only terminate the NMEA 2000 backbone, do not terminate | + | |
+ | See annotated screenshot above for which is what. | ||
ve.can/nmea-2000/start.1479900486.txt.gz · Last modified: 2016-11-23 12:28 by mvader
