ve.can:nmea-2000:start
ve.can:nmea-2000:start [2021-09-09 16:58] – [2.4 NMEA 2000 GPS integration] mvader | ve.can:nmea-2000:start [2022-03-16 12:07] – [3.4 DC Voltage compatibility] mvader | ||
Line 117: | Line 117: | ||
NMEA 2000 Instances are used to identify multiple similar products connected on the same network. | NMEA 2000 Instances are used to identify multiple similar products connected on the same network. | ||
- | More information | + | There are several types of instances, the most important ones being the **Device instance** |
+ | More information about instances is in [[https:// | ||
+ | === What settings need to be made? For example instances? === | ||
+ | That is a commonly asked question. The answer depends on the used brand of MFD: | ||
+ | For **Garmin, Furuno, Maretron and Navico (B&G, Lowrance, Simrad) systems**: none. No instances, also not data instances such as the DC Detailed instance, need to be changed. It all works out of the box, other than configuring what field to show where on the MFD. | ||
+ | For **Raymarine**, | ||
==== 3.3 Terminators and network layout ==== | ==== 3.3 Terminators and network layout ==== | ||
Line 124: | Line 134: | ||
* Use the NMEA 2000 cable as the backbone. | * Use the NMEA 2000 cable as the backbone. | ||
- | * Run a separate drop cable separately to each Victron device [[https://nocache.victronenergy.com/ | + | * Run a separate drop cable separately to each Victron device [[https://www.victronenergy.com/ |
- | * Only terminate the NMEA 2000 backbone, do not terminate on the VE.Can side. | + | * Only terminate the NMEA 2000 backbone. Do not install a terminator in any of the VE.Can |
+ | Or: | ||
+ | * Have the N2K network on one side, with one terminator. On the other end, change to the Victron network, with also one (Victron) terminator at the end. | ||
+ | The Victron VE.Can network is accepts 9 to 70VDC. | ||
+ | The NMEA-2000 network used to be 9 to 16VDC, which is, or will be, expanded to also include 24 V. Which means that some NMEA-2000 devices are 9 to 16 VDC, some are 9 to 30VDC, and some allow higher voltages. | ||
+ | Also, the Victron VE.Can network will (in most cases) be powered with battery voltage. So for a 48V system, the voltage on the VE.Can network **exceeds** the NMEA2000 accepted voltage levels. | ||
+ | Therefore, it is important to not connect those power cables. | ||
+ | The Victron cable used to connect both networks together, the [[https:// | ||
- | ==== 3.4 Further reading on Victron and NMEA 2000 ==== | + | ==== 3.5 Further reading on Victron and NMEA 2000 ==== |
Line 137: | Line 164: | ||
==== 4.1 Raymarine & EmpirBus ==== | ==== 4.1 Raymarine & EmpirBus ==== | ||
- | Besides using NMEA 2000 and/or the Lighthouse App, integration onto Raymarine MFDs can also be done with an [[http://www.trigentic.com/# | + | Besides using NMEA 2000 and/or the Lighthouse App, integration onto Raymarine MFDs can also be done with an [[https://www.empirbus.com/# |
- | In the [[http:// | + | In the [[https:// |
- | Next, use the [[http:// | + | Next, use the [[http:// |
The EmpirBus system requires the data instance of battery status and dc detailed status to be unique when using multiple sources. ([[ve.can: | The EmpirBus system requires the data instance of battery status and dc detailed status to be unique when using multiple sources. ([[ve.can: |
