ve.can:nmea-2000:start
ve.can:nmea-2000:start [2021-03-15 15:14] – [2.3 Tank monitoring] mvader | ve.can:nmea-2000:start [2021-04-29 20:46] – [5. FAQ] mvader | ||
Line 4: | Line 4: | ||
==== 1.1 Summary ==== | ==== 1.1 Summary ==== | ||
- | This technical | + | This document explains how to integrate a Victron system onto a marine |
- | There are multiple options, and how to best integrate depends on the customer requirements, | + | There are multiple options, and how to best integrate depends on the customer requirements, |
Make sure to closely read this full document to find the best method for your type of system. | Make sure to closely read this full document to find the best method for your type of system. | ||
==== 1.2 What is NMEA 2000? ==== | ==== 1.2 What is NMEA 2000? ==== | ||
NMEA2000 is a communications standard used for connecting marine sensors and display units within ships and boats. | NMEA2000 is a communications standard used for connecting marine sensors and display units within ships and boats. | ||
Line 18: | Line 19: | ||
==== 1.3 What is the MFD HTML5 App? ==== | ==== 1.3 What is the MFD HTML5 App? ==== | ||
- | The MFD HTML5 App is a very simple to install and setup integration into all main marine MFD brands, including Raymarine, Garmin, Navico and Furuno. Truly plug-and-play: | + | The MFD HTML5 App is a simple to install and setup integration into all main marine MFD brands, including Raymarine, Garmin, Navico and Furuno. Truly plug-and-play: |
==== 1.4 Other integration options ==== | ==== 1.4 Other integration options ==== | ||
Line 25: | Line 26: | ||
First of all Modbus-TCP. Typically used on larger vessels, Modbus-TCP is a protocol commonly used for (custom) designed SCADA systems. The Victron GX devices all support the Modbus-TCP protocol. More information in the [[ccgx: | First of all Modbus-TCP. Typically used on larger vessels, Modbus-TCP is a protocol commonly used for (custom) designed SCADA systems. The Victron GX devices all support the Modbus-TCP protocol. More information in the [[ccgx: | ||
- | The other alternative is SignalK. More information about that in the [[venus-os: | + | The other alternative is SignalK. More information about that in the [[venus-os: |
===== 2. Integration details ===== | ===== 2. Integration details ===== | ||
Line 33: | Line 34: | ||
For most installations and integrations, | For most installations and integrations, | ||
- | There are two ways to connect a GX Device to a MFD: | + | The GX devices offer both above introduced integration options: NMEA2000 as well as the Victron HTML5 App. |
- | - the (simpler) plug and play like method uses an Ethernet connection, which enables the MFD HTML5 App. Available | + | The HTML5 integration is available |
- | - in an the NMEA2000 network. See the [[https:// | + | |
- | Both connections | + | When connected to the onboard NMEA2000 network, the GX Device |
- | The MFD HTML5 App is the simplest | + | Both the NMEA2000 and HTML5 App/ |
+ | Each has its advantages and disadvantages, | ||
+ | The MFD HTML5 App is the simpler one to setup as its plug and play. It presents an easy to use system overview without requiring any configuration. The system overview shown will automatically adapt to the type of Victron system installed. The (only) available configuration is defining the batteries as well as giving them names. | ||
The NMEA 2000 integration is more complex, and allows more customisation on the MFD: the data will show up in the data-tree of the MFD, and most MFDs then allow the user to configure various pages and combinations of information. | The NMEA 2000 integration is more complex, and allows more customisation on the MFD: the data will show up in the data-tree of the MFD, and most MFDs then allow the user to configure various pages and combinations of information. | ||
- | Note that, besides making information available on NMEA 2000, a GX Device can also read tank level data from NMEA 2000. More information in [[https:// | + | As mentioned above, a GX Device can also read tank level data from NMEA 2000. More information in the [[https:// |
==== 2.2 Products with a VE.Can port ==== | ==== 2.2 Products with a VE.Can port ==== | ||
- | Some of our products feature a VE.Can port; which can be directly connected to the NMEA 2000 network. No electronic converter is necessary. The conversion cable required is the [[https:// | + | All Victron |
- | These products include our Skylla-i | + | * Skylla-i |
+ | * Skylla IP65 Battery Chargers | ||
+ | * Lynx Shunt VE.Can | ||
+ | * Lynx Smart BMS | ||
+ | * SmartSolar MPPT Solar Chargers with VE.Can communications port | ||
- | ==== 2.3 Tank monitoring ==== | + | {{ :ve.can: |
- | When discussing integration of tank level data, there are two topics to separate: one is to have tanklevels measured by a Victron tank level adapter sent out to the NMEA2000 network, to display on an MFD for example. | + | ==== 2.3 Tank monitoring integration ==== |
- | And the other is for Victron monitoring systems to read tank level data available on the NMEA2000 network | + | The GX devices can measure |
- | Both are possible, an below two sections explain the details of each. | + | Below sections explain the details of each integration type. |
- | === GX Device to MFD and N2K === | + | === Integration A) GX Device to MFD and NMEA2000 |
- | Some of GX devices | + | Some of Victron |
+ | Also, all GX devices can also have their number and types of tank level inputs expanded by adding one or multiple [[https:// | ||
- | Note that, at this moment, the MFD HTML5 App does not include showing | + | All tank level inputs feature customisable naming, setting a type (fresh water, fuel, black water and more), configurable filtering and damping settings as well as setting up a custom |
- | === N2K to GX Device and VRM Portal === | + | |
- | Here explain that tank levels | + | The GX Device can transmit the resulting |
- | And the other way around: tank data available on NMEA2000, originating from non-Victron | + | === Integration B) NMEA2000 to GX Device and VRM Portal === |
+ | The other way around | ||
+ | The tank data will be shown in the GX device user interface | ||
+ | Compatible tank senders are listed | ||
+ | //Above picture: GX Touch 50, showing multiple tank levels. Coming from either the NMEA2000 network, directly connected resistive tank senders or via the GX Tank 140 accessory.// | ||
==== 2.4 Using our converter interfaces (DEPRECATED!) ==== | ==== 2.4 Using our converter interfaces (DEPRECATED!) ==== | ||
Line 79: | Line 101: | ||
Note that the use of both those interfaces is deprecated. Use a GX device instead. | Note that the use of both those interfaces is deprecated. Use a GX device instead. | ||
+ | ===== 3. NMEA2000 Details ===== | ||
+ | Refer to our [[https:// | ||
+ | ==== 3.2 NMEA 2000 instancing ==== | ||
- | ===== 3. Varia ===== | + | NMEA 2000 Instances are used to identify multiple similar products connected on the same network. |
+ | More information as well as how to configure them is explained in [[ve.can: | ||
- | ==== 3.1 VE.Can products (Skylla-i, Skylla-IP44, | + | ==== 3.3 Terminators |
- | Since the Victron VE.Can communication protocol is based on N2K, the following products can all be connected directly | + | A N2K CAN-bus network needs to be laid out as in a backbone configuration, using drop cables |
- | * Skylla-i 24V Battery Chargers | + | * Use the NMEA 2000 cable as the backbone. |
- | * Skylla IP44 Battery Chargers | + | * Run a separate drop cable separately to each Victron device [[https:// |
- | * Lynx Shunt Battery Monitors | + | * Only terminate the NMEA 2000 backbone, do not terminate on the VE.Can |
- | * Lynx Ion + Shunt all models | + | |
- | * SmartSolar MPPT Solar Chargers with VE.Can | + | ==== 3.4 Further reading on Victron and NMEA 2000 ==== |
+ | * [[https:// | ||
+ | ===== 4. Varia ===== | ||
- | ==== 3.2 Raymarine & EmpirBus ==== | + | ==== 4.1 Raymarine & EmpirBus ==== |
Besides using NMEA 2000 and/or the Lighthouse App, integration onto Raymarine MFDs can also be done with an [[http:// | Besides using NMEA 2000 and/or the Lighthouse App, integration onto Raymarine MFDs can also be done with an [[http:// | ||
Line 109: | Line 139: | ||
- | ==== 3.3 Maretron ==== | + | All data sent out by Victron devices |
- | All data sent out by Victron devices can be picked up by the Maretron MFDs & software. See the [[http:// | + | |
- | ===== 4. NMEA2000 PGN overview ===== | + | |
- | Refer to our [[https:// | + | |
===== 5. FAQ ===== | ===== 5. FAQ ===== | ||
- | Note that there are many more generic frequently asked questions answered in the [[https:// | + | === Q1: Can/must both Ethernet and and N2K connection be made between |
- | ==== Q1: What about instances? Device instances, data instances? ==== | + | Both can be made at the same time. |
- | See [[ve.can: | + | |
- | ==== Q2: What about terminators and network layout? ==== | + | |
- | A N2K CAN bus network needs to be laid out as in a backbone configuration, | + | |
- | * Use the NMEA 2000 cable as the backbone. | + | |
- | * Run a separate drop cable separately to each Victron device. The drop cable will be one of these three products: | + | |
- | * [[https:// | + | |
- | * Only terminate the NMEA 2000 backbone, do not terminate on the VE.Can side. | + | |
- | ==== Q3: What PGNs does a GX Device transmit on N2K? ==== | + | Ethernet is needed to get the MFD App, as explained above. |
- | See the [[https:// | + | And an N2K connection is needed to get data to show in other fields on the MFD. |
- | ==== Q4: Can integration onto Raymarine displays also be done without Empirbus NXT? ==== | + | See annotated screenshot above for which is what. |
- | Yes, see [[https:// |
