ve.can:nmea-2000:start
ve.can:nmea-2000:start [2021-03-15 00:10] – mvader | ve.can:nmea-2000:start [2022-03-16 12:07] – [3.4 DC Voltage compatibility] mvader | ||
- | This technical | + | ==== 1.1 Summary ==== |
+ | This document explains how to integrate a Victron system onto a marine | ||
- | There are multiple | + | There are multiple |
- | === Systems with a GX Device === | + | Make sure to closely read this full document to find the best method for your type of system. |
- | For most installations and integrations, | + | {{: |
+ | NMEA 2000 is a communications standard used for connecting marine sensors and display units within ships and boats. | ||
- | There are two ways to connect | + | Victron Energy is a member of the NMEA 2000 organisation, |
- | - the (simpler) plug and play like method uses an Ethernet connection, which enables the MFD App. Available for [[https:// | + | NMEA 2000 is sometimes also refered to as N2K, for brevitiy. |
- | - in an the NMEA2000 network. See the [[https:// | + | |
- | Both connections can be made and used at the same time, and each has its advantages and disadvantages. | + | ==== 1.3 What is the MFD HTML5 App? ==== |
+ | The MFD HTML5 App is a simple to install | ||
- | Note that, besides making information available on NMEA 2000, a GX Device can also read tank level data from NMEA 2000. More information in [[https:// | + | ==== 1.4 Other integration options ==== |
+ | This document only covers integration via NMEA2000 as well as the MFD HTML5 App. There are two other alternatives, | ||
- | === Direct connection | + | First of all Modbus-TCP. Typically used on larger vessels, Modbus-TCP is a protocol commonly used for (custom) designed SCADA systems. The Victron GX devices all support the Modbus-TCP protocol. More information in the [[ccgx: |
- | Some of our products feature a VE.Can port; and can thus be directly connected to the NMEA 2000 network. No electronic converter necessary; only a plug conversion cable, | + | The other alternative is SignalK. More information about that in the [[venus-os:large|Venus OS Large manual]]. Do take note of the contents of the Support chapter. |
- | === Using our converter interfaces (DEPRECATED!) | + | ===== 2. Integration details ===== |
- | * [[https:// | + | ==== 2.1 Systems with a GX Device ==== |
- | * [[https:// | + | |
- | Note that the use of both those interfaces is deprecated. Use a GX Device instead. | + | For most installations and integrations, |
- | === What is NMEA 2000? === | + | The GX devices offer both above introduced integration options: NMEA2000 as well as the Victron HTML5 App. |
- | NMEA 2000 is a plug-and-play communications standard used for connecting | + | The HTML5 integration |
- | Victron Energy is a member of the NMEA 2000 organisation, and we have several of our products certified | + | When connected to the onboard NMEA2000 network, the GX Device can read data from the network (tank level and GPS information). Also it can make data from Victron devices connected to the GX Device available on the NMEA2000 network. That latter feature is called NMEA2000-out, |
- | For brevity, this document will refer to NMEA 2000 as N2K. | + | Both the NMEA2000 and HTML5 App/ |
- | === Modbus-TCP Integration === | + | Each has its advantages and disadvantages, |
- | For larger vessels, using custom designed SCADA systems, | + | The MFD HTML5 App is the simpler one to setup as its plug and play. It presents an easy to use system overview without requiring any configuration. The system overview shown will automatically adapt to the type of Victron system installed. The (only) available configuration is defining the batteries as well as giving them names. |
- | ===== 2. Varia ===== | + | The NMEA 2000 integration is more complex, and allows more customisation on the MFD: the data will show up in the data-tree of the MFD, and most MFDs then allow the user to configure various pages and combinations of information. |
- | ==== 2.1 VE.Can | + | ==== 2.2 Products with a VE.Can |
- | Since the Victron VE.Can | + | All Victron |
* Skylla-i 24V Battery Chargers | * Skylla-i 24V Battery Chargers | ||
- | * Skylla | + | * Skylla |
- | * Lynx Shunt Battery | + | * Lynx Shunt VE.Can |
- | * Lynx Ion + Shunt all models | + | * Lynx Smart BMS |
* SmartSolar MPPT Solar Chargers with VE.Can communications port | * SmartSolar MPPT Solar Chargers with VE.Can communications port | ||
+ | ==== 2.3 Tank monitoring integration ==== | ||
- | ==== 2.1 Raymarine & EmpirBus ==== | + | The GX devices can measure tank levels, and make the resulting data available on the NMEA2000 network. Also, they can read tank level data from the N2K network. |
- | Besides using NMEA 2000 and/ | + | Below sections explain |
- | In the [[http:// | + | === Integration A) GX Device to MFD and NMEA2000 === |
- | Next, use the [[http://www.trigentic.com/#empirbus-graphic|EmpirBus Graphical tool]] to design | + | Some of Victron GX monitoring products feature built-in tank level inputs. For example |
- | The EmpirBus system requires the data instance of battery status | + | Also, all GX devices can also have their number |
+ | All tank level inputs feature customisable naming, setting a type (fresh water, fuel, black water and more), configurable filtering and damping settings as well as setting up a custom tank shape for non-square tanks. | ||
- | ==== 2.2 Maretron ==== | + | The GX Device can transmit the resulting tank levels to the NMEA2000 network. See the [[https:// |
- | All data sent out by Victron devices can be picked up by the Maretron MFDs & software. See the [[http:// | + | === Integration B) NMEA2000 to GX Device |
- | ===== 3. PGN overview | + | The other way around is possible as well: the Victron system reading tank level data from NMEA2000. |
+ | The tank data will be shown in the GX device user interface as well as on the VRM Portal. Screenshots below. | ||
+ | Compatible tank senders are listed in the [[https:// | ||
+ | //Above picture: GX Touch 50, showing multiple tank levels. Coming from either the NMEA2000 network, directly connected resistive tank senders or via the GX Tank 140 accessory.// | ||
+ | * [[https:// | ||
+ | ===== 3. NMEA2000 Details | ||
- | ===== 4. FAQ ===== | + | ==== 3.2 NMEA 2000 instancing |
- | Note that there are many more generic frequently asked questions answered in the [[https:// | + | NMEA 2000 Instances |
- | ==== Q1: What about instances? Device instances, data instances? ==== | + | There are several types of instances, the most important ones being the **Device |
- | See [[ve.can:changing_nmea2000_instances|]] for details on that. | + | More information about instances is in [[https:// |
- | ==== Q2: What about terminators and network layout? ==== | + | === What settings need to be made? For example instances? === |
- | A N2K CAN bus network needs to be laid out as in a backbone configuration, | + | That is a commonly asked question. The answer depends on the used brand of MFD: |
+ | For **Garmin, Furuno, Maretron and Navico (B&G, Lowrance, Simrad) systems**: none. No instances, also not data instances such as the DC Detailed instance, need to be changed. It all works out of the box, other than configuring what field to show where on the MFD. | ||
+ | For **Raymarine**, | ||
+ | ==== 3.3 Terminators and network layout ==== | ||
* Use the NMEA 2000 cable as the backbone. | * Use the NMEA 2000 cable as the backbone. | ||
- | * Run a separate drop cable separately to each Victron device. The drop cable will be one of these three products: | + | * Run a separate drop cable separately to each Victron device [[https:// |
- | * [[https:// | + | * Only terminate the NMEA 2000 backbone. Do not install a terminator in any of the VE.Can ports on the Victron products. |
- | * [[https://nocache.victronenergy.com/ | + | Or: |
- | * Only terminate the NMEA 2000 backbone, do not terminate | + | |
+ | * Have the N2K network on one side, with one terminator. On the other end, change to the Victron network, with also one (Victron) terminator at the end. | ||
+ | The Victron VE.Can network is accepts 9 to 70VDC. | ||
+ | The NMEA-2000 network used to be 9 to 16VDC, which is, or will be, expanded to also include 24 V. Which means that some NMEA-2000 devices are 9 to 16 VDC, some are 9 to 30VDC, and some allow higher voltages. | ||
+ | Also, the Victron VE.Can network will (in most cases) be powered with battery voltage. So for a 48V system, the voltage on the VE.Can network **exceeds** the NMEA2000 accepted voltage levels. | ||
+ | Therefore, it is important to not connect those power cables. | ||
+ | The Victron cable used to connect both networks together, the [[https:// | ||
+ | ==== 3.5 Further reading on Victron and NMEA 2000 ==== | ||
+ | ===== 4. Varia ===== | ||
+ | Besides using NMEA 2000 and/or the Lighthouse App, integration onto Raymarine MFDs can also be done with an [[https:// | ||
+ | In the [[https:// | ||
+ | ===== 5. FAQ ===== | ||
+ | === Q1: Can/must both Ethernet and and N2K connection be made between Victron GX and MFD? === | ||
+ | Both can be made at the same time. | ||
- | ==== Q3: What PGNs does a GX Device transmit on N2K? ==== | + | Ethernet is needed to get the MFD App, as explained above. |
- | See the [[https:// | + | And an N2K connection is needed to get data to show in other fields on the MFD. |
- | ==== Q4: Can integration onto Raymarine displays also be done without Empirbus NXT? ==== | + | See annotated screenshot above for which is what. |
- | Yes, see [[https:// |
