ve.can:nmea-2000:start
ve.can:nmea-2000:start [2020-01-10 10:23] – mvader | ve.can:nmea-2000:start [2021-10-07 14:36] – [3.3 Terminators and network layout] mvader | ||
- | This technical | + | ==== 1.1 Summary ==== |
+ | This document explains how to integrate a Victron system onto a marine | ||
- | There are multiple | + | There are multiple |
- | === Systems with a GX Device === | + | Make sure to closely read this full document to find the best method for your type of system. |
- | For most installations and integrations, | + | {{: |
+ | NMEA 2000 is a communications standard used for connecting marine sensors and display units within ships and boats. | ||
- | A GX Device can be connected to a Marine MFD in two ways: the simple plug and play like method uses an Ethernet connection, which enables the MFD App. Available for [[https:// | + | Victron Energy is a member of the NMEA 2000 organisation, and we have several of our products certified by NMEA 2000. |
- | The other type of integration | + | NMEA 2000 is sometimes also refered |
- | Both connections can be made and used at the same time, and each has its advantages and disadvantages. | + | ==== 1.3 What is the MFD HTML5 App? ==== |
+ | The MFD HTML5 App is a simple | ||
- | Note that, besides making information available on NMEA 2000, a GX Device can also tank level data from NMEA 2000. More information in [[https:// | + | ==== 1.4 Other integration options ==== |
+ | This document only covers integration via NMEA2000 as well as the MFD HTML5 App. There are two other alternatives, | ||
- | === Direct connection | + | First of all Modbus-TCP. Typically used on larger vessels, Modbus-TCP is a protocol commonly used for (custom) designed SCADA systems. The Victron GX devices all support the Modbus-TCP protocol. More information in the [[ccgx: |
- | Some of our products feature a VE.Can port; and can thus be directly connected to the NMEA 2000 network. No electronic converter necessary; only a plug conversion cable, | + | The other alternative is SignalK. More information about that in the [[venus-os:large|Venus OS Large manual]]. Do take note of the contents of the Support chapter. |
- | === Using our converter interfaces (deprecated) | + | ===== 2. Integration details ===== |
- | * [[https:// | + | ==== 2.1 Systems with a GX Device ==== |
- | * [[https:// | + | |
- | Note that the use of both those interfaces is deprecated. Use a GX Device instead. | + | For most installations and integrations, |
- | === What is NMEA 2000? === | + | The GX devices offer both above introduced integration options: NMEA2000 as well as the Victron HTML5 App. |
- | NMEA 2000 is is a plug-and-play communications standard used for connecting | + | The HTML5 integration |
- | Victron Energy is a member of the NMEA 2000 organisation, and we have several of our products certified | + | When connected to the onboard NMEA2000 network, the GX Device can read data from the network (tank level and GPS information). Also it can make data from Victron devices connected to the GX Device available on the NMEA2000 network. That latter feature is called NMEA2000-out, |
- | For brevity, this document will refer to NMEA 2000 as N2K. | + | Both the NMEA2000 and HTML5 App/ |
- | === Modbus-TCP Integration === | + | Each has its advantages and disadvantages, |
- | For larger vessels, using custom designed SCADA systems, | + | The MFD HTML5 App is the simpler one to setup as its plug and play. It presents an easy to use system overview without requiring any configuration. The system overview shown will automatically adapt to the type of Victron system installed. The (only) available configuration is defining the batteries as well as giving them names. |
- | ===== 2. Varia ===== | + | The NMEA 2000 integration is more complex, and allows more customisation on the MFD: the data will show up in the data-tree of the MFD, and most MFDs then allow the user to configure various pages and combinations of information. |
- | ==== 2.1 VE.Can | + | ==== 2.2 Products with a VE.Can |
- | Since the Victron VE.Can | + | All Victron |
* Skylla-i 24V Battery Chargers | * Skylla-i 24V Battery Chargers | ||
- | * Skylla | + | * Skylla |
- | * Lynx Shunt Battery | + | * Lynx Shunt VE.Can |
- | * Lynx Ion + Shunt all models | + | * Lynx Smart BMS |
* SmartSolar MPPT Solar Chargers with VE.Can communications port | * SmartSolar MPPT Solar Chargers with VE.Can communications port | ||
+ | ==== 2.3 Tank monitoring integration ==== | ||
- | ==== 2.1 Raymarine & EmpirBus ==== | + | The GX devices can measure tank levels, and make the resulting data available on the NMEA2000 network. Also, they can read tank level data from the N2K network. |
- | Besides using NMEA 2000 and/ | + | Below sections explain |
- | In the [[http:// | + | === Integration A) GX Device to MFD and NMEA2000 === |
- | Next, use the [[http://www.trigentic.com/#empirbus-graphic|EmpirBus Graphical tool]] to design | + | Some of Victron GX monitoring products feature built-in tank level inputs. For example |
- | The EmpirBus system requires the data instance of battery status | + | Also, all GX devices can also have their number |
- | ==== 2.2 Maretron ==== | + | All tank level inputs feature customisable naming, setting a type (fresh water, fuel, black water and more), configurable filtering and damping settings as well as setting up a custom tank shape for non-square tanks. |
- | All data sent out by Victron devices | + | The GX Device |
- | ===== 3. PGN overview ===== | + | === Integration B) NMEA2000 to GX Device and VRM Portal |
- | Refer to our [[https:// | + | The other way around is possible as well: the Victron |
- | ===== 4. FAQ ===== | + | The tank data will be shown in the GX device user interface as well as on the VRM Portal. Screenshots below. |
- | Note that there are many more generic frequently asked questions answered | + | Compatible tank senders |
- | ==== Q1: What about instances? Device instances, data instances? ==== | + | {{ :ve.can: |
- | See [[ve.can:changing_nmea2000_instances|]] for details on that. | + | //Above picture: GX Touch 50, showing multiple tank levels. Coming from either the NMEA2000 network, directly connected resistive tank senders or via the GX Tank 140 accessory.// |
- | ==== Q2: Can MPPT Solar Chargers with a VE.Direct port also be connected? ==== | + | //Below screenshot shows a similar system, but then on the [[https:// |
- | No, they cannot be connected. Even though the [[https:// | + | {{ :ve.can:nmea-2000: |
- | Similarly, also a GX Device does not (yet) transmit data from connected Solar Chargers on its NMEA2000-out port. | + | ==== 2.4 NMEA 2000 GPS integration ==== |
- | ==== Q3: What about terminators | + | Our GX devices can read location, altitude, speed and course from the NMEA2000 |
- | A N2K CAN bus network needs to be laid out as in a backbone configuration, | + | Note the other way around does not work. A GX Device which has a USB GPS installed does not emit GPS data out onto the NMEA2000 network as part of the NMEA2000-out function. |
+ | * [[https:// | ||
+ | ===== 3. NMEA2000 Details ===== | ||
+ | Refer to our [[https:// | ||
+ | ==== 3.2 NMEA 2000 instancing ==== | ||
+ | NMEA 2000 Instances are used to identify multiple similar products connected on the same network. | ||
+ | More information as well as how to configure them is explained in [[ve.can: | ||
+ | ==== 3.3 Terminators and network layout ==== | ||
* Use the NMEA 2000 cable as the backbone. | * Use the NMEA 2000 cable as the backbone. | ||
- | * Run a separate drop cable separately to each Victron device. The drop cable will be one of these three products: | + | * Run a separate drop cable separately to each Victron device [[https:// |
- | ==== Q4: What PGNs does a GX Device transmit | + | Or: |
+ | * Have the N2K network on one side, with one terminator. On the other end, change to the Victron network, with also one (Victron) terminator at the end. | ||
+ | ==== 3.4 Further reading on Victron and NMEA 2000 ==== | ||
+ | ===== 4. Varia ===== | ||
+ | Besides using NMEA 2000 and/or the Lighthouse App, integration onto Raymarine MFDs can also be done with an [[http:// | ||
+ | In the [[http:// | ||
+ | ===== 5. FAQ ===== | ||
- | See the [[https:// | + | === Q1: Can/must both Ethernet and and N2K connection be made between Victron GX and MFD? === |
- | ==== Q5: Can integration onto Raymarine displays also be done without Empirbus NXT? ==== | + | Both can be made at the same time. |
- | Yes, see [[https:// | + | Ethernet is needed to get the MFD App, as explained above. |
- | ==== Q6: What about Maretron and other brand tank sensors | + | And an N2K connection is needed to get data to show in other fields |
- | See chapter 1.4.7 in the [[ccgx: | + | See annotated screenshot above for which is what. |
