ve.can:nmea-2000:start
ve.can:nmea-2000:start [2020-01-06 22:58] – [1. Introduction] mvader | ve.can:nmea-2000:start [2020-01-27 13:57] – [1. Introduction] mvader | ||
- | This document explains how to integrate a Victron system onto a Marine MFD, such as from Garmin, Raymarine Navico and other brands. | + | This technical |
- | This are multiple ways to do such an integration; | + | There are multiple ways to integrate, so make sure to closely read the complete introductory chapter to find the best method for your type of system. |
- | For all new installations, | + | === Systems with a GX Device === |
- | A GX Device can connected to a Marine MFD in two ways. One is by connecting | + | For most installations and integrations, |
- | Victron Energy is a member of the NMEA 2000 organisation, and we have several of our products certified by NMEA 2000. | + | A GX Device can be connected to a Marine MFD in two ways: the simple plug and play like method uses an Ethernet connection, which enables the MFD App. Available for [[https:// |
- | For brevity, this document will refer to NMEA 2000 as N2K. | + | The other type of integration is to connect the GX Device to the NMEA2000 network. See the [[https:// |
- | ===== 1. How to connect to a NMEA 2000 network ===== | + | Both connections can be made and used at the same time, and each has its advantages and disadvantages. The MFD App is by far the simplest method. It presents an easy to use system overview without requiring any configuration. The NMEA 2000 integration on the other hand, whilst being more complex, allows more customisation on the MFD: the data will show up in the data-tree of the MFD, and most MFDs then allow the user to configure various pages and combinations of information. This is not so with the MFD App, as the only available settings are to show or hide battery parameters (Voltage, SOC, Current) as well as naming the batteries. |
- | ==== 1.1 Multis, MultiPlusses and Quattros ==== | + | Note that, besides making information available on NMEA 2000, a GX Device can also tank level data from NMEA 2000. More information in [[https:// |
- | === Combining | + | === Direct connection - products |
- | Monitoring and controlling these products from both to a N2K network and a Color Control GX is possible. In that case, do not connect the Color Control GX to the VE.Bus network. Instead, connect it also to the N2K network. Use our [[https:// | + | |
- | Schematic diagram | + | Some of our products feature |
- | In above example, there needs to be a fuse in the [[https:// | + | === Using our converter interfaces (DEPRECATED!) === |
- | === Limitations === | + | * [[https:// |
+ | * [[https:// | ||
- | When the Multis/ | + | Note that the use of both those interfaces is deprecated. Use a GX Device instead. |
- | * Incompatible with Hub-4 and ESS Assistant, for Energy Storage Systems | + | === What is NMEA 2000? === |
- | * Listing the VE.Bus installed Assistants on the CCGX / VRM Portal does not work | + | |
- | Setting On/ | + | NMEA 2000 is is a plug-and-play communications standard used for connecting marine sensors and display units within ships and boats. |
- | Combining this with a CCGX on the same network is possible. Connect the CCGX to the N2K network as well, use our [[https:// | + | Victron Energy is a member of the NMEA 2000 organisation, |
- | {{ :ve.can: | + | |
+ | === Modbus-TCP Integration === | ||
+ | For larger vessels, using custom designed SCADA systems, the recommended protocol to use is ModbusTCP. See our [[ccgx:modbustcp_faq|]]. | ||
+ | ===== 2. Varia ===== | ||
- | ==== 1.3 VE.Can products (Skylla-i, Skylla-IP44, | + | ==== 2.1 VE.Can products (Skylla-i, Skylla-IP44, |
Line 56: | Line 56: | ||
Line 72: | Line 68: | ||
Line 84: | Line 81: | ||
Note that there are many more generic frequently asked questions answered in the [[https:// | Note that there are many more generic frequently asked questions answered in the [[https:// | ||
- | === Q1: What about instances? Device instances, data instances? === | + | ==== Q1: What about instances? Device instances, data instances? |
- | === Q2: Can MPPT Solar Chargers with a VE.Direct port also be connected? === | + | ==== Q2: Can MPPT Solar Chargers with a VE.Direct port also be connected? |
No, they cannot be connected. Even though the [[https:// | No, they cannot be connected. Even though the [[https:// | ||
Line 94: | Line 91: | ||
Similarly, also a GX Device does not (yet) transmit data from connected Solar Chargers on its NMEA2000-out port. | Similarly, also a GX Device does not (yet) transmit data from connected Solar Chargers on its NMEA2000-out port. | ||
+ | ==== Q3: What about terminators and network layout? ==== | ||
+ | A N2K CAN bus network needs to be laid out as in a backbone configuration, | ||
- | === Q3: What about terminators and network layout? === | + | |
- | A N2K CAN bus network needs to be laid out as in backbone configuration, | + | |
- | === Q4: What PGNs does the Color Control | + | ==== Q4: What PGNs does a GX Device |
- | Nothing. At the moment the CCGX only reads data from the NMEA 2000 network. The data it can read is: | + | See the [[https:// |
- | * Victron Inverter/ | + | ==== Q5: Can integration onto Raymarine displays also be done without Empirbus NXT? ==== |
- | * Victron Battery monitor data | + | |
- | * Victron BMS data | + | |
- | * Victron Tank sender data as well as tank sender data from other manufacturers. See chapter 1.4.7 in the [[ccgx: | + | |
- | === Q5: Can integration onto Raymarine displays also be done without Empirbus NXT? === | + | |
Yes, see [[https:// | Yes, see [[https:// | ||
- | === Q6: What about Maretron and other brand tank sensors on the Ccgx? === | + | ==== Q6: What about Maretron and other brand tank sensors on the Ccgx? ==== |
See chapter 1.4.7 in the [[ccgx: | See chapter 1.4.7 in the [[ccgx: | ||
