ve.can:nmea-2000:start
ve.can:nmea-2000:start [2017-05-05 03:42] – [5. FAQ] mvader | ve.can:nmea-2000:start [2020-01-06 22:58] – [1. Introduction] mvader | ||
- | Many Victron | + | This document explains how to integrate a Victron |
+ | This are multiple ways to do such an integration; | ||
+ | For all new installations, we recommend to use one of our [[venus-os: | ||
+ | A GX Device can connected to a Marine MFD in two ways. One is by connecting it to the NMEA2000 network, N2K. N2K is is a plug-and-play communications standard used for connecting marine sensors and display units within ships and boats. | ||
Line 47: | Line 53: | ||
* Lynx Shunt Battery Monitors | * Lynx Shunt Battery Monitors | ||
* Lynx Ion + Shunt all models | * Lynx Ion + Shunt all models | ||
Line 74: | Line 80: | ||
- | ===== 4. Color Control GX & NMEA 2000 ===== | + | ===== 4. FAQ ===== |
- | * The VE.Can port on the CCGX only reads information from the N2K network. It does not (yet!) send any data out on the N2K network. | + | Note that there are many more generic frequently asked questions answered in the [[https:// |
=== Q1: What about instances? Device instances, data instances? === | === Q1: What about instances? Device instances, data instances? === | ||
Line 87: | Line 90: | ||
=== Q2: Can MPPT Solar Chargers with a VE.Direct port also be connected? === | === Q2: Can MPPT Solar Chargers with a VE.Direct port also be connected? === | ||
- | No, they cannot be connected. Even though the [[https:// | + | No, they cannot be connected. Even though the [[https:// |
+ | Similarly, also a GX Device does not (yet) transmit data from connected Solar Chargers on its NMEA2000-out port. | ||
- | Note that there are many more generic frequently asked questions answered in the [[https:// | ||
=== Q3: What about terminators and network layout? === | === Q3: What about terminators and network layout? === | ||
- | A N2K canbus | + | A N2K CAN bus network needs to be laid out as in backbone configuration, |
- | * Use the NMEA2000 cable as the back bone. | + | * Use the NMEA2000 cable as the backbone. |
Line 109: | Line 114: | ||
* Victron Battery monitor data | * Victron Battery monitor data | ||
* Victron BMS data | * Victron BMS data | ||
- | * Victron Tank sender data as well as tank sender data from other manufacturers. See chapter 1.2.7 in the [[ccgx: | + | * Victron Tank sender data as well as tank sender data from other manufacturers. See chapter 1.4.7 in the [[ccgx: |
=== Q5: Can integration onto Raymarine displays also be done without Empirbus NXT? === | === Q5: Can integration onto Raymarine displays also be done without Empirbus NXT? === | ||
- | No. | + | Yes, see [[https:// |
- | === Q6: What about Maretron and other brand tanksensors | + | === Q6: What about Maretron and other brand tank sensors |
- | See chapter 1.2.7 in the [[ccgx: | + | See chapter 1.4.7 in the [[ccgx: |
~~DISQUS~~ | ~~DISQUS~~ |
