ve.can:nmea-2000:start
ve.can:nmea-2000:start [2016-12-01 09:51] – [1.1 Multis, MultiPlusses and Quattros] mvader | ve.can:nmea-2000:start [2019-04-03 17:39] – external edit 127.0.0.1 | ||
Line 26: | Line 26: | ||
When the Multis/ | When the Multis/ | ||
- | * Hub-4 and ESS Assistant | + | * Incompatible with Hub-4 and ESS Assistant, for Energy Storage Systems |
- | * Listing the installed Assistants on the CCGX / VRM Portal | + | * Listing the VE.Bus |
- | * Alarm information per phase (generic alarm information still works) | + | * Alarm information per phase does not work (generic alarm information still works) |
- | * Forwarding charge-current information of MPPTs. Solution: always install a BMV, which is needed anyway in a Marine installation. | + | * Forwarding charge-current information of MPPTs to the VE.Bus system does not work. Solution: always install a BMV, which is needed anyway in a Marine installation. |
Setting On/ | Setting On/ | ||
==== 1.2 BMV Battery Monitors ==== | ==== 1.2 BMV Battery Monitors ==== | ||
- | Use the [[https:// | + | Use the [[https:// |
Combining this with a CCGX on the same network is possible. Connect the CCGX to the N2K network as well, use our [[https:// | Combining this with a CCGX on the same network is possible. Connect the CCGX to the N2K network as well, use our [[https:// | ||
Line 110: | Line 110: | ||
* Victron BMS data | * Victron BMS data | ||
* Victron Tank sender data as well as tank sender data from other manufacturers. See chapter 1.2.7 in the [[ccgx: | * Victron Tank sender data as well as tank sender data from other manufacturers. See chapter 1.2.7 in the [[ccgx: | ||
+ | === Q5: Can integration onto Raymarine displays also be done without Empirbus NXT? === | ||
+ | No. | ||
+ | === Q6: What about Maretron and other brand tanksensors on the Ccgx? === | ||
+ | See chapter 1.2.7 in the [[ccgx: | ||
