ve.can:changing_nmea2000_instances
ve.can:changing_nmea2000_instances [2019-01-22 10:16] – external edit 127.0.0.1 | ve.can:changing_nmea2000_instances [2019-05-26 07:58] – mvader | ||
Line 34: | Line 34: | ||
===== 2. Changing the device instance with Actisense ===== | ===== 2. Changing the device instance with Actisense ===== | ||
+ | Note: make sure to use a recent Actisense driver. Otherwise the instance might not ‘stick’. | ||
Changing a device instance: | Changing a device instance: |
ve.can/changing_nmea2000_instances.txt · Last modified: 2023-06-28 13:32 by sloges
