ve.can:changing_nmea2000_instances
ve.can:changing_nmea2000_instances [2019-01-21 11:12] – [DISQUS] ictbeheer | ve.can:changing_nmea2000_instances [2019-05-26 07:58] – mvader | ||
Line 34: | Line 34: | ||
===== 2. Changing the device instance with Actisense ===== | ===== 2. Changing the device instance with Actisense ===== | ||
+ | Note: make sure to use a recent Actisense driver. Otherwise the instance might not ‘stick’. | ||
Changing a device instance: | Changing a device instance: | ||
Line 99: | Line 101: | ||
Device instance changed successful! | Device instance changed successful! | ||
+ | ~~DISQUS~~ | ||
ve.can/changing_nmea2000_instances.txt · Last modified: 2023-06-28 13:32 by sloges
