open_source:ccgx:setup_development_environment
| open_source:ccgx:setup_development_environment [2017-06-22 21:05] – mvader | open_source:ccgx:setup_development_environment [2019-06-22 15:50] (current) – removed mvader | ||
| Line 1: | Line 1: | ||
| - | ====== Setting up your PC as a CCGX development environment ====== | ||
| - | This page explains setting up a cross compiling environment for the CCGX. Cross compiling means that the software is built/ | ||
| - | Notes: | ||
| - | * rebuilding the whole rootfs and image from scratch is something entirely different, explained here: https:// | ||
| - | * this page assumes your host pc / virtual runs linux | ||
| - | * it is often faster to do most development and debugging of software on your pc first. So no cross-compiling required at first. See [[# | ||
| - | * when looking for ordinary packages, such as git, gdb, or something else, as opposed to your own development, | ||
| - | * another alternative: | ||
| - | To cross compile, you need to setup an SDK, which contains the gcc compiler, as well as all header files and other setup of the CCGX. | ||
| - | More info about what you are installing here: | ||
| - | http:// | ||
| - | ===== BASICS - command line cross-compile ===== | ||
| - | ==== 1. Prerequisites ==== | ||
| - | Start with the basics: cross-compile a project from the command line. This example has been made on Ubuntu. | ||
| - | Then replace dash with bash: | ||
| - | sudo dpkg-reconfigure dash (and choose NO) | ||
| - | Then install all the prerequisites. For (X)Ubuntu do: | ||
| - | sudo apt-get install gawk wget git-core diffstat unzip texinfo gcc-multilib build-essential chrpath socat libsdl1.2-dev xterm | ||
| - | For other distros, see the [[https:// | ||
| - | ==== 2. Install the SDK ==== | ||
| - | The SDK includes the gcc compiler for the ARM processor, as well as all the needed libraries and header files. | ||
| - | First, download the latest sdk [[https:// | ||
| - | * Cortex A8 for the Venus gx and CCGX | ||
| - | * Cortex A7 for the Raspberrypi | ||
| - | The file needed is the one ending with .sh. | ||
| - | There is no need to worry about it not being the same version as the latest available CCGX firmware version. Using the latest SDK available will be fine. | ||
| - | Then install it. It will ask where you want to have it installed, **make sure to install the ccgx sdk in its default location!**. And, in these examples, make sure to replace v1.40 to the version you downloaded: | ||
| - | chmod u+x ./ | ||
| - | sudo ./ | ||
| - | Make a symlink / | ||
| - | sudo ln -s / | ||
| - | Now to use this SDK, the following command is to be executed in the terminal where you also call make or start qtcreator. This has to be done every time, but you are free to automate it of course: | ||
| - | source / | ||
| - | ==== 3. Cross compile your first project ==== | ||
| - | Create a file helloworld.c with the following content: | ||
| - | #include < | ||
| - | int main() | ||
| - | puts(" | ||
| - | return 0; | ||
| - | The following is needed to compile above for a ccgx | ||
| - | # first setup the environment: | ||
| - | $CC helloworld.c -o helloworld | ||
| - | The resulting binary is now called helloworld. This is an ARM executable, this can be checked with | ||
| - | file helloworld | ||
| - | This should report something like: | ||
| - | helloworld: ELF 32-bit LSB executable, ARM, EABI5 version 1 (SYSV), dynamically linked (uses shared libs), for GNU/Linux 2.6.16, not stripped | ||
| - | ==== 4. Cross compiling QT projects ==== | ||
| - | QT projects, which are projects using 1 or more QT libraries, rely on the qmake engine. Compiling a projects works like this: | ||
| - | # change directory to the location of the qmake file (.pro extension) | ||
| - | cd <path to project file> | ||
| - | # Run qmake to create a makefile. Use the qmake supplied with the SDK! | ||
| - | # Build the project | ||
| - | make | ||
| - | ===== LUXURY - now that you have done the basics, go for the IDE ===== | ||
| - | Now that you have successfully compiled a project from the command-line, | ||
| - | ==== 0. Install QT Creator ==== | ||
| - | sudo apt-get install qtcreator (or take latest from qt website) | ||
| - | To start QTCreator, start a new terminal, and execute the command\\ | ||
| - | source / | ||
| - | And then start qtcreater: | ||
| - | make sure to start it from the same terminal where you typed source / | ||
| - | qtcreator | ||
| - | ==== 1. Configuring QT Creator ==== | ||
| - | === 1.1 Add the cross-compiler === | ||
| - | Goto Options-> | ||
| - | Result will look like this: | ||
| - | === 1.2 Add the debugger === | ||
| - | Same screen, but one tab to the right: Debuggers. Click add and point it to: | ||
| - | === 1.3 Add the Qt version === | ||
| - | Same screen, but then one tab to the left, Qt Versions. Point it to | ||
| - | === 1.4 Prepare your CCGX === | ||
| - | * set your own root password on the CCGX in Settings-> | ||
| - | * enable the ssh daemon on the ccgx: Settings -> General -> Remote Support -> Enable. | ||
| - | * install gdbserver: login to ccgx with ssh, and run opkg install gdbserver | ||
| - | root@ccgx: | ||
| - | Installing gdbserver (7.5-r0.0) to root... | ||
| - | Downloading http:// | ||
| - | Installing libthread-db1 (2.16-r17+svnr20393) to root... | ||
| - | Configuring libthread-db1. | ||
| - | Configuring gdbserver. | ||
| - | === 1.5 Add the device to qtcreator=== | ||
| - | Add device, see screenshot. | ||
| - | === 1.6 Add a Kit === | ||
| - | Next add a new kit: | ||
| - | * select the Compiler, Debugger and Qt Version which you have created in the previous steps. | ||
| - | * select a sysroot: / | ||
| - | End result will look like this: | ||
| - | === 1.7 Try it === | ||
| - | Now you are ready to start compiling. Open a QT project file (.pro extension) and chose the CCGX kit, and chose Build-> | ||
| - | After a successful build deploy the executable to the CCGX (Build-> | ||
| - | svc -d / | ||
| - | Cross-compile run:\\ | ||
| - | Executable on device: / | ||
| - | === 1.8 Notes === | ||
| - | When working on a velib project, make sure to change these settings in the Kit: | ||
| - | - Remove qmake from build steps in the kit | ||
| - | - Disable shadow build | ||
| - | - Add ARCH=arm HOST_ABI=gnueabi to the Make arguments of the build steps | ||
| - | - For the debug build, also add BUILD=debug | ||
| - | - Add the same to the clean steps | ||
| - | And if you are going to build release builds with qtcreator, do more or less the same for that build config. | ||
| - | ===== More bits and pieces that might come in handy ===== | ||
| - | === Mount CCGX file system locally === | ||
| - | To save yourself some time copying files back and forth between your PC and your CCGX, for example while editing Python code, use sshfs to mount the CCGX drive to your local machine: | ||
| - | mkdir ~/rem | ||
| - | sshfs root@ccgx:/ | ||
| - | Use fusermount -u PATH to unmount it again. or just reboot your machine. | ||
| - | ==== Mounting a ubifs image ==== | ||
| - | To get the right tools in ubuntu, install mtd-tuils: | ||
| - | sudo apt-get install mtd-utils | ||
| - | Info can be found on this page: http:// | ||
| - | However, don't use mtdram, but use nandsim. | ||
| - | sudo modprobe ubi | ||
| - | sudo modprobe nandsim first_id_byte=0x20 second_id_byte=0xac third_id_byte=0x00 fourth_id_byte=0x15 | ||
| - | sudo flash_erase /dev/mtd0 0 0 | ||
| - | sudo ubiformat /dev/mtd0 -f ubi.img | ||
| - | sudo ubiattach -p /dev/mtd0 | ||
| - | sudo mount -t ubifs /dev/ubi0_0 /mnt/ubifs/ | ||
| - | ==== Developing and running on your PC instead of immediately on the target ==== | ||
| - | Developing, running, debugging a module on your (Linux) PC is often much faster than first having it uploaded to the CCGX everytime you want to run it. And the good news is that it is perfectly possible. | ||
| - | Most of our modules will run perfectly on a pc: localsettings, | ||
| - | Most -perhaps even all- of our D-Bus implementations (C, Cpp, Python, etc) automatically choose the Session D-Bus instead of the System D-Bus which is used on the ccgx. This is done at either compile- or run-time. To see what is going on on the D-Bus, use the [[http:// | ||
| - | For some modules you'll need to run localsettings on your pc. Github repo including explanation of what it is [[https:// | ||
| - | ===== DISQUS ===== | ||
| - | ~~DISQUS~~ | ||
open_source/ccgx/setup_development_environment.1498158349.txt.gz · Last modified: by mvader
