While Matthijs is having fun at http://www.victronenergy.com/live/open_source:ccgx:installing_ccgx_func_on_raspberry_pi this page is about deploying packages for a Raspberry PI. This is not something officially supported nor complete. This is tested on a Rpi B+ v1.2 with Raspbian.
First of all, the Rpi 1 is based on a armv6, while armhf has a minimum of ARMv7+VFP3, yet the Raspbian image believes it is running armhf. The answer seems simply that Raspbian redefined armhf to ARMv6+VFP but forgot to rename it somehow. Since these binaries are incompatible, it won't in general be enough to compile a package for Debian/armhf and expect it to work on a Rpi 1. A Rpi 2 can run Debian armhf and would be better of doing so instead of running Raspbian.
Anyway, it seems that supporting a package for a rpi needs rpi specific packages, so that is what is done. To get it (there is only 1 for testing) the following must be done:
sudo nano /etc/apt/sources.list
And add the following line deb http://updates.victronenergy.com/feeds/raspbian/dists/wheezy/contrib binary-armhf/
sudo apt-get update sudo apt-get install vedirect-dbus
