open_source:ccgx:commandline
open_source:ccgx:commandline [2021-03-02 09:30] – [4.4 vreg: changing settings from the command line] mvader | open_source:ccgx:commandline [2021-09-30 12:40] – [7. Enabling Remote Console] mvader | ||
Line 344: | Line 344: | ||
- | Example of switching a solar charger | + | Switching all devices on VE.Can |
- | OFF: (vreg 0x0200, value 4) | + | vreg -c socketcan:can0 -s 0x0200 |
- | ccgx:~# vreg -n 0x45 -s 0x0200 | + | </ |
- | # NAD 0x45, reg=0x200 | + | |
- | 0x04 0x00 0x00 0x00 | + | |
- | ON: (vreg 0x0200, value 1) | + | switching a specific device off: |
- | root@ccgx: | + | < |
- | # NAD 0x45, reg=0x200 | + | vreg -c socketcan: |
- | 0x01 0x00 0x00 0x00 | + | |
- | root@ccgx: | + | |
+ | vreg -c socketcan: | ||
Line 416: | Line 424: | ||
- SSH into CCGX (make a root password by following instructions [[ccgx: | - SSH into CCGX (make a root password by following instructions [[ccgx: | ||
- | - < | + | - Enable Remote Console on LAN: < |
- | - < | + | - Create the password file. Empty file means no password: |
- Reboot CCGX via SSH: < | - Reboot CCGX via SSH: < | ||
- Now you should be able to access Remote Console feature from VRM | - Now you should be able to access Remote Console feature from VRM | ||
- If you want to set a password, go to Settings -> Remote Console -> Enable password check | - If you want to set a password, go to Settings -> Remote Console -> Enable password check | ||
- | ===== 8. Enabling VRM two-way communication (Remote VEConfigure aka vrmpubnub) ===== | ||
- | If you have a CCGX already installed, but VRM two-way communication is not enabled, follow these steps to enable it remotely: | ||
- | - SSH into CCGX (make a root password by following instructions [[ccgx: | ||
- | - VE.Configure should now be able to connect to the CCGX | ||
