open_source:ccgx:commandline
open_source:ccgx:commandline [2021-01-19 13:15] – [1.2 Use a normal tool instead of the command line] guystewart | open_source:ccgx:commandline [2021-09-30 12:40] – [7. Enabling Remote Console] mvader | ||
Line 343: | Line 343: | ||
Victron Energy B.V. | Victron Energy B.V. | ||
+ | vreg -c socketcan: | ||
Line 402: | Line 424: | ||
- SSH into CCGX (make a root password by following instructions [[ccgx: | - SSH into CCGX (make a root password by following instructions [[ccgx: | ||
- | - < | + | - Enable Remote Console on LAN: < |
- | - < | + | - Create the password file. Empty file means no password: |
- Reboot CCGX via SSH: < | - Reboot CCGX via SSH: < | ||
- Now you should be able to access Remote Console feature from VRM | - Now you should be able to access Remote Console feature from VRM | ||
- If you want to set a password, go to Settings -> Remote Console -> Enable password check | - If you want to set a password, go to Settings -> Remote Console -> Enable password check | ||
- | ===== 8. Enabling VRM two-way communication (Remote VEConfigure aka vrmpubnub) ===== | ||
- | If you have a CCGX already installed, but VRM two-way communication is not enabled, follow these steps to enable it remotely: | ||
- | - SSH into CCGX (make a root password by following instructions [[ccgx: | ||
- | - VE.Configure should now be able to connect to the CCGX | ||
