open_source:ccgx:commandline
open_source:ccgx:commandline [2019-08-15 11:56] – [1.1 No support warning] - VicCom link guy_stewart | open_source:ccgx:commandline [2021-03-03 11:46] – [4.4 vreg: changing settings from the command line] mvader | ||
Line 23: | Line 23: | ||
Line 39: | Line 39: | ||
==== 1.3 Connecting to the command line and file transfer ==== | ==== 1.3 Connecting to the command line and file transfer ==== | ||
Line 144: | Line 144: | ||
Line 341: | Line 343: | ||
Victron Energy B.V. | Victron Energy B.V. | ||
+ | vreg -c socketcan: | ||
