open_source:ccgx:commandline
open_source:ccgx:commandline [2019-08-15 11:56] – [1.1 No support warning] - VicCom link guy_stewart | open_source:ccgx:commandline [2021-03-02 09:30] – [4.4 vreg: changing settings from the command line] mvader | ||
Line 23: | Line 23: | ||
Line 39: | Line 39: | ||
==== 1.3 Connecting to the command line and file transfer ==== | ==== 1.3 Connecting to the command line and file transfer ==== | ||
Line 144: | Line 144: | ||
Line 340: | Line 342: | ||
Victron Energy B.V. | Victron Energy B.V. | ||
+ | Example of switching a solar charger off, and then on | ||
+ | OFF: (vreg 0x0200, value 4) | ||
+ | ccgx:~# vreg -n 0x45 -s 0x0200 un8:0x04 | ||
+ | # NAD 0x45, reg=0x200 | ||
+ | 0x04 0x00 0x00 0x00 | ||
+ | ON: (vreg 0x0200, value 1) | ||
+ | root@ccgx: | ||
+ | 0x01 0x00 0x00 0x00 | ||
+ | root@ccgx: | ||
===== 5. VE.Direct products ===== | ===== 5. VE.Direct products ===== |
